Question about Jeep 2006 Grand Cherokee Laredo
Replace starter how do you remove bayanett slide on electrical connecter?
I have a 2001 pontiac montana and am trying to figure out how to change the starter.
STARTER REPLACEMENT (ENGINE ELECTRICAL) Document ID# 688149 Starter Replacement
Removal Procedure
Important: This vehicle uses the PG260 F1 starter motor. The starter motor is serviced only as a complete unit.
  1. Disconnect the battery ground (negative) cable from the battery. Refer to Battery Negative Cable Disconnection and Connection.
  2. Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
  3. Remove the starter motor BAT terminal nut and electrical leads.
  4. Remove the starter motor S terminal nut and electrical lead.
  5. Remove the torque converter cover. Refer to Torque Converter Cover Replacement in Automatic Transaxle - 4T65-E.
  6. Remove the starter motor bolts.
  7. Remove the starter motor.
Installation Procedure
  1. Install the starter motor.
  2. Notice: Refer to Fastener Notice in Cautions and Notices.
  3. Install the starter motor bolts.Tighten:
    Tighten the starter motor bolts to 47 [n-m] (35 lb ft).
  4. Install the torque converter cover. Refer to Torque Converter Cover Replacement in Automatic Transaxle - 4T65-E.
  5. Install the starter motor S terminal electrical lead and nut. Tighten:
    Tighten the starter motor solenoid S terminal nut to 3 [n-m] (27 lb in).
  6. Install the starter motor BAT terminal electrical leads and nut. Tighten:
    Tighten the starter motor solenoid BAT terminal nut to 10 [n-m] (89 lb in).
  7. Lower the vehicle.
  8. Install the battery ground (negative) cable to the battery. Refer to Battery Negative Cable Disconnection and Connection.
Aug 05, 2016 | 2001 Pontiac Montana
How to replace starter on audiA6 1.8 petrol 2001 C5
If I understand it correctly, you are talking about the starter motor replacement. In that case here it is how you can do it. Hope this helps.
1) Remove the feed to the battery & remove the driver side (right hand drive) road wheel.
2) Remove the shroud around the drive shaft (held on with 3 Allen bolts)
3) Remove the two bolts holding the starter motor
4) From under the caricon1.png (once the underbody tray is removed) you can get your hand in to undo the support bracket and the two nuts holding the electrical connection. this is quite hard as the top nut is hard to get to. but because you have already undone the other retaining bolts you should be able to turn the motor to some degree.
5) Once all undone, a few grazed knuckles later an you should be able to wiggle/push/pull the starter motor out of the bell housingicon1.png.
6) you should now be able to slide this out through the wheel as the area is just big enough (with the drive shaft shroud removed) to do so.
7) In true Haynes manualstyleicon1.png - refitting is the reversal of removal - except be patient when trying to do up the electrical connections.
Jul 24, 2013 | 2001 Audi A6 1.8
Removal and installation of starter of 2002 mercury mountainer
Here's the generic starter replacement directions.
Engine should be cool, parked on level surface. Remove negative cable from battery. Remove electrical connections at starter (Sometimes starter may need to be partially removed to access all electrical connections.) Remove any brackets, parts, or accessories that obstruct access to the starter motor mounting bolts. Remove mounting bolts and remove starter. Clean the mounting surface, and install new starter and tighten the mount bolts evenly. Replace wires on starter. Connect battery.
Good luck.
Nov 20, 2011 | 2002 Mercury Mountaineer
How to change a starter 1995 3.4 v6 eng: Chevy camero automatic
First make sure to disconnect the battery. Remove the wires connection of the starter and mark the connection it will useful to connect it again with the new one. Remove the mounted bolts. Now starter slide out of flywheel assembly. You can replace your starter at http://www.buyautoparts.com/autoparts/Chevrolet/Camaro/Starter.html
Aug 02, 2011 | Chevrolet Camaro Cars & Trucks
2003 Kia RIO WHEN TURNED TO ON CAR starts and the starter will not stop turning
Replace the starter.
Removal & Installation
1.5L & 1.6L (VIN 5) Engines
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable.
  3. Remove the 4 upper intake manifold stay bracket bolts.
  4. Disconnect the starter electrical connections.
  5. Remove the upper starter bolts.
  6. Remove the lower starter mounting bolt(s) and the starter.
    Fig. Starter mounting-1.5L and 1.6L engines
To install:
  1. Install the starter.
  2. Install the lower starter bolt and tighten to 27-38 ft. lbs. (37-52 Nm).
  3. Connect the starter electrical connections.
  4. Install the intake manifold support bracket and finger-tighten the 3 mounting bolts. Tighten the lower bolt to 27-38 ft. lbs. (37-52 Nm).
  5. Install the 4 upper intake manifold stay bracket bolts and tighten to 27-38 ft. lbs. (37-52 Nm).
  6. Install the upper starter bolts and tighten to 27-38 ft. lbs. (37-52 Nm).
  7. Connect the negative battery cable.
1.6L (VIN 3) Engine
  2. Remove or disconnect the following:
    Negative battery cable Air intake assembly Shift cable and bracket Starter electrical connections Starter
To install:
  1. Install or connect the following:
    Starter Starter electrical connections Shift cable Air intake assembly Negative battery cable
May 04, 2011 | Kia Rio Cars & Trucks
How do you remove a 1999 Nissan Altima starter?
Nissan Car Altima & Sentra 1999-06 StarterRemoval & Installation
  1. Remove or disconnect the following:
    Negative battery cable Air duct Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.0L Maxima with a manual transaxle
    Fig. Starter location and mounting detail-3.5L Maxima
To install:
    Starter and torque the long bolt to 57-72 ft. lbs. (77-98 Nm) on Altima and Maxima and 41 ft. lbs. (55 Nm) on 350 Z. torque the short bolt to 22-30 ft. lbs. (30-41 Nm) Starter wiring Harness protector Air duct Negative battery cable
    Negative battery cable Air inlet tube Harness bracket Wiring at the starter Starter
To install:
    Starter and torque the bolts to 60 inch lbs. (7 Nm) Starter electrical connectors Harness bracket Air inlet tube Negative battery cable
1.6L & 2.0L Engines
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    Negative battery cable Wiring at the starter Bolts attaching the starter to the engine Starter
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negaative battery cable
1.6L, 1.8L & 2.0L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
To install:
    Starter and torque the bolts to 70 inch lbs. (8 Nm) Starter electrical connections Negative battery cable
1.8L & 2.0L Engines
To install:
2.4L & 2.5L Engines
To install:
2.4L Engine
To install:
2.5L Engine
    Negative battery cable Air cleaner cover and duct Harness bracket Wiring at the starter Starter
To install:
3.5L Engines
    Negative battery cable Air cleaner case (upper) and air cleaner to electric throttle control actuator tube. Harness protector from the harness Starter wiring at the starter Starter-to-engine bolts Starter from the vehicle
    Fig. Starter location and mounting detail-3.5L engine
continue...
Apr 05, 2010 | 1999 Nissan Altima
How do I change a starter in a 1989 5.2 liter dodge ram truck?
REMOVAL & INSTALLATION
Gasoline Engines
Fig. 13: Disconnect the wires attached to the starter solenoid to facilitate removal
  1. Disconnect the negative battery cable.
Fig. 14: Unbolt the starter from the vehicle
  1. Remove the cable from the starter.
Fig. 15: Once detached, remove the starter from the vehicle
Fig. 16: Exploded view of the starter mounting-2.5L engine
  1. Disconnect the solenoid leads at their solenoid terminals. If necessary, tag then to avoid confusion when re-installing.
Fig. 17: Attach the starter wire connector to the terminals as shown-V6 and V8 engines
Fig. 18: To remove the starter, unbolt the mounting hardware shown-V6 and V8 engines
On 4WD Dakota models with the V6 engine, the starter is removed from above. On these models you will have to disconnect the steering gear and position the shaft out of the way to gain working clearance.
  1. Remove the starter attachment bolts and withdraw the starter from the engine flywheel housing. On some models with automatic transmissions, the oil cooler tube bracket will interfere with the starter removal. In this case, remove the starter attachment bolts, slide the cooler tube bracket off the stud, and then withdraw the starter.
Fig. 19: When detached, pull the starter away from the engine and remove it from the vehicle-2WD Dakota model shown
To install:
  1. Be sure that the starter and flywheel housing mating surfaces are free of dirt and oil to make a good electrical contact.
Fig. 20: Install the starter motor on the 4WD Dakota from above as shown
  1. Slide the starter in place, secure using the bolts and washers removed. Tighten the bolts to 50 ft. lbs. (68 Nm). Connect wires and battery cable end at the starter.
  2. If removed for clearance, reconnect the steering column shaft.
  3. Secure the oil cooler bracket if equipped. Connect the negative battery cable on the battery.
When tightening the mounting bolt and nut on the starter, hold the starter away from the engine for the correct alignment.
Diesel Engines
  2. Raise the truck and support it safely on jackstands.
  3. Disconnect and label the wires at the starter motor.
  4. Remove the attaching bolt, nut and washer, then lift the starter and solenoid assembly from the engine.
To install:
  1. Before installing the starter motor, be sure the mounting surface on the drive end housing and the flywheel housing are clean, to ensure good electrical contact.
  2. When tightening the attaching bolt and nut, hold the starter away from the engine to ensure the proper alignment. Tighten the bolts to 32 ft. lbs. (43 Nm).
  3. Attach the wiring at the starter. Tighten the solenoid connection to 44 inch lbs. (5 Nm). Tighten the battery cable at the starter motor to 16 ft. lbs. (22 Nm).
  4. Attach the negative battery cable.
SOLENOID REPLACEMENT
Chrysler Corp. for 1989-91 models did provide replaceable solenoids for the starter motors covered by this information. However since 1992, the manufacturer no longer recommends replacement of individual components, even if the later unit has the same part number of a formerly serviceable unit. Chrysler now simply calls for replacement of the entire starter assembly if the solenoid is found faulty.
Fig. 21: Starter electrical connections and mounting bolt locations-diesel engine
Hope helped with this (remember rated this post) Good luck.
Mar 05, 2010 | 1989 Dodge Ramcharger
How do I replace my starter?
Open hood.
Disconnect negative (-) batter cable
Locate the starter (under vehicle).
Remove electrical connections. (be sure to remember/take a picture/ make a drawing/ or mark which wires go to what posts)
Remove mounting bolts.
Remove starter, replace with new starter
Install mounting bolts
Install electrical connections
Jan 06, 2010 | 1990 Chevrolet S-10 Blazer
How do I replace the starter on my 2004 Grand Am?
Alero, Grand Am 1999-2005 Repair Guide
Starter - Removal & Installation
2.2L Engine
  1. Before servicing the vehicle, refer to the precautions section.
    Negative battery cable Starter electrical connector Starter motor
    Fig. Starter mounting-2.2L engine
To install:
    Starter motor. Torque the bolts to 30 ft. lbs. (40 Nm). Starter electrical connectors Negative battery cable
3.1L Engine
    Negative battery cable Starter electrical connectors Starter motor
To install:
    Starter motor. Torque the bolts to 32 ft. lbs. (43 Nm). Starter electrical connectors Negative battery cable
3.4L Engine
    Negative battery cable Flywheel inspection cover Starter electrical connectors Starter motor
To install:
Starter motor. Torque the bolts to 32 ft. lbs. (43 Nm). Starter electrical connectors Flywheel inspection cover. Torque the bolts to 89 inch lbs. (10 Nm). Negative battery cable
I hope helps with this. Good luck (remember rated this help).
Dec 29, 2009 | 2004 Pontiac Grand Am
I need to replace the starter in my 1982 Honda GL 1100 Goldwing .
Step 1.) Remove negative battery terminal.
Step 2.) Remove electrical connection on starter.
Step 3.) Remove shifter lever screw gently pry the shifter open a little then slide off.
Step 4.) Remove top screw from starter, then remove bottom screw from starter.
Step 5.) Pull starter forward toward the front of the motorcycle. You may have to gently tap on the starter with a rubber mallet.
May 31, 2009 | 1982 Honda GL 1100 Gold Wing
Jeep 2006 Grand Cherokee Laredo Logo
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
