Question about Health & Beauty
POWER MIN LIGHT IS ON BUT BED WILL NOT TURN ON
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Change brake light bulb on a 2000 Nissan Frontier
The entire bed line will need to be removed. The long screws that hold the metal bracet where the bed extender attaches also hold the tail light assembly in place.
I pulled the bed liner up at a 45 degree angle and layed it on top of the cab. This revealed the screws. Take both screws out and lay to the side along with the metal bracket for the bed extender.
Now firmly grab the edges of the tail light assembly and pull...there are 2 hard rubber nipples that snap in to hold the assembly. You will feel like you might break it but you won't..just pull straight back hard. The assembly will "POP" out and then you can just twist the back of each bulb there are (3) and pull out..now you will see the bulbs..just pull the bad bulb straight out and push the new one into place. Now just reassemble. Total time will be 30-45 min. for this repair.
Mar 30, 2010 | 2000 Nissan Frontier
I have a GE 52 inch projection screen TV. I have replaced three CP's: 150, 114, 120. I also replaced the flyback. The TV worked only a couple of times. I turned it on, then off, and right back on. I only...
You can start with resolder deflection board around Hori output, coils and Big diodes also make sure 2 ribbon connectors are pushed in correctly and in good CK Both Ribbons .
Mar 24, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
My monitor will not turn on, it was working fine yesterday and then I turned it off when I went to bed and when I woke up this morning, the power light is weakly flashing a dim yellow, but it wont turn on.
kmbass24, Could be "black screen of death" problem. The problem is inside the monitor! Most likely a power supply problem. If not handy with soldering iron, solder wick, removal/install of bad filter capacitors, and use of DVM then a tech will need to troubleshoot unit. Some units can be repaired for less than $12 in parts!!! It's the charge for labor that gets you in the end. $20 min per hr. Your monitor is no different than any other brand. Go to YOUTUBE and view some typical BSoD repair vids of "LCD monitor disassembly" LCD monitor repair" FYI and learn what the 2 common ROOT CAUSES of BSoD are. Hint for you is this: Have you seen the NEW style screw-in, curlie-Q, energy saving compact fluorescent LIGHT BULBS! Very similar technology is used to light-up your LCD panel to enable you to SEE what is on the display!
If this was of some interest, rate this response on fixya. bye for now.
12fixlouie
Nov 24, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Toshiba satellite a65 will not turn on at all!
Make sure that when you plug the power cord in, a light comes on, on the power cord! If a light dosnt come on, on the power cord, the cord is busted and she needs a new one! Most power cords have lights on them!
Oct 21, 2008 | Toshiba Satellite A65-S1065 Notebook
Phillips HTS3400 blinking red light
there is a capacitor on the power supply that has gone bad, it is a 1000 mf 16v cap and you will notice the top is bulged up a little bit. there are three in a row and this is the center one. Radio shack replacement part for $1.73 and you are back in business. Tim
Jun 22, 2008 | Audio Players & Recorders
Jl audio 500/1 amp
You may have the amp set to turn on via an audio signal. Set the Signal Sensing switch to OFF.
Jun 13, 2008 | Jl Audio 500/1 Car Audio Amplifier
Health & Beauty Logo
78 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
