Sony bravo ,
The tv did not have sound or imagine the scrin is black
How do i find my TV's pairing code?
It's either in your TV settings or you could try some of the generic codes such as 0000 1234 9999
Aug 10, 2014 | Sony Bravo 7011Vi34 Core2Duo 2.2GHz 2GB...
My tv sony bravo does not have sound or imagine
check the lamp first
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Mar 22, 2014 | Sony XL-2100U Projector Lamp for...
Left side of screen is dark until tv warms up
Sounds like you have a defect LCD panel tab !!! These are also common with Samsung LCD's as well. The only permanent fix is the replace the panel which will cost as much as a new TV in most cases.
Sep 03, 2012 | Sony KDL-52XBR9 52 in. LCD HDTV
Sony google tv makes sizzling sound
Even after switch off, there can be some discharge of static charges present in and around TV, hot plastic parts can contract and make some noise. Some sets have the cooling fan run for a few seconds more to reach a particular temp, before it is turned off. Just try switching off the power outlet, and removing the plug and see.
Aug 19, 2012 | Sony Google TV NSX-32GT1 32 in. LCD HDTV
I have a Sony sound bar mod# sa-32se1 connected to my Sony 32 in bravos, sounds great but shuts down after a few minutes of use what might be the problem
I had the same problem. I found that my sound bar can't be too close to the TV. I have my samsung TV on a platform ( not mounted) and the sound bar in front of it. In this configuration, the sound bar kept shutting off. I returned it as a faulty unit and the second one did the same thing. By chance I happened to move the sound bar off of the tv platform and the problem ceased.
Dec 18, 2011 | Sony Televison & Video
Can i use vinegar instead of fabric softener? would it harm the mashine?
I cant imagine vinegar harming your machine, if anything it would clean it! But i can imagine walking round in vinegar smelling clothes phewww :-)
Mar 22, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravos washer that sounds like airplane
u need to replace the tub. includes the bearings
Feb 11, 2010 | Maytag Bravos MTW6600T Top Load Washer
SAMSUNG SYNC MASTER 910MP
Solution for this problem is to re-set the settings for color, contrast end brightness.
The have had a spontanious reset to 0.
Just go to custumsettings for picture: menu, picture,custom, customsettings and tune up the settings .
voila picture is there again...
greetings H. Huizer
Nov 19, 2007 | Samsung SyncMaster 910MP 19" LCD Monitor
85 people viewed this question
jasbo
jasbo
