Question about Meade LS 8" ACF 08100310 Telescope
Meade problems My Meade 8"Ls say it has a flash driver error, and I can not seem to be able to connect my auto star to my laptop any suggestions?
Only a year old should be able to connect to auto star on my hand control to my laptop, and I get a flash drive error not sure what to do please help!
SOURCE: LX200 EMC MEADE 8 INCH
By doing this trick--
Do a FAKE alignment-- (I assume that the scope is trained and has the proper date, time, and site)-- just push the buttons for the alignment stars that you cannot see. Then do a GOTO to a star that is in your field of view--- center the star and SYNC. Your gotos will now be OK in your limited field of view.
Posted on Dec 28, 2008
SOURCE: ASCENSION DRIVE WON'T STOP TURNING.
If you will post this question on the Yahoo LX200 forum group the experts there may be able to diagnose this problem.
Many folks there with the same telescope.
Posted on Jul 09, 2009
SOURCE: I have a Meade LX10 that won't track objects
Go online to the Yahoo LX90 or LX200 Group an post your question -- also you could have a broken clutch in the base.
Posted on Aug 01, 2009
  • 921 Answers
SOURCE: cannot find a manual for meade telescope model #226w
http://www.meade.com/ or if they cant give you the info try .
http://www.go-astronomy.com/astronomy-club.php?ID=388
if these guys cant help you out...just buy a decent pair of binoculars...i like them better and they get more use!
Posted on Sep 13, 2009
SOURCE: Screen on Starfinder Handbox will not work
Contact Meade here:
http://www.meade.com/support/index.html
Posted on Oct 01, 2009
We have a Meade LS telescope. When power on ... no sound or instruction is heard ... the hand box only power on with red background led but nothing is appeared ... what the problem
Two possibilities- corrupted firmware and or a bad hand controller cable. Re-load the firmware; if that does not do it then get a new hand controller cable. Beyond that it will be bad electronics inside the scope and it will need to be sent back to Meade for repair.
Clear skies,
TelescopeMan
Feb 03, 2015 | Meade LS 8" ACF 08100310 Telescope
Can you tell me what is meade part S582
Ask Meade ! They made the dam thing.. they don't have it use something else... make one or fix it, use something from another model.
Jul 24, 2014 | Meade Ls 8" Acf Lightswitch Telescope
How to collimate the Meade 8 Inch LS telescope?
I believe the LS models have to be collimated by Meade.
Mar 14, 2013 | Meade 8 Inch LS Telescope with LightSwitch...
Recently I purchased a Meade LS6 SC telescope and it works well until the message "Firmware Error" appear on the handheld. I managed to get a miniSD card. I need to know the exact steps in (a) Getting...
The SD card update is explained in the manual, here:
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/LS%20Software%20Update%20Instructions%20v16%20(26-Oct-2009).pdf
Both methods of updating are discussed.
Aug 11, 2010 | Meade LS6 06100310 Telescope
Meade LX200GPS The scope does not complete the 'Auto Alignment'
Once the scope has taken a GPS fix and knows TIME, and SITE, and you do a two star alignment your alignment stars overide any automatic alignment issues.
You could turn off the GPS put in Time, Date, and Site, do a two star alignment and everything would be fine. Centering the alignment stars is the "trick". Apparently the scope also finds NORTH OK, or the alignment stars would be way off. Since you pre-level the tripod already the software can FAIL on "tilt" and you still get good gotos.
I would not worry about it, especially since your gotos seem perfectly fine.
May 28, 2010 | Meade LX200GPS Telescope
Meade/auto star problem
You never said what model. The CD ROM only contains free planetarium software which you can also down load on Meade's web site here:
www.meade.com look under the Customer Service link.
Motor Faults are usually caused by low power and or a broken part.
If you have CALIBRATE MOTORS feature in the hand controller do this first. If it still does not work, RESET the hand controller, reenter date, time, and SITE, and calibrate motors again.
If this does not work something is broken inside the scope.
Apr 18, 2010 | Meade 80mm Refractor Telescope
Do you have a bolt that holds the focus lense in place on a Meade Tele Star MDS114 D114mm F-910mm1/8?
You might be able to buy this from Meade:
or find a replacement at a well stocked hardware store.
Oct 13, 2009 | Meade Optics
Problem with alignment of Meade LX90 8" telescope
Start from scratch-
RESET the hand controller.
Calibrate motors using the same power source you will use outside.
Re-train the drives
Calibrate sensors on Polaris
Use either the 110 volt power cord, or buy a 12 volt power pack and the proper Meade 12 volt cable. (www.scopestuff.com carries the right 12 volt cable)
If your scope is NOT the LNT or GPS model you must level the tripod before you align. Go to home depot and buy the $3 small plastic two way bubble level, or the bulls-eye style bubble level.
Further trouble, I suggest going to the LX90 Yahoo group forum, and asking questions there.
Good Luck
Aug 30, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
Lpi issues with windows xp
Did you install the driver (CD) that came with the camera-- and are you using Windows XP-- there are known issues with Vista.
Mar 26, 2009 | Meade ETX-90PE (325 x 90mm) Telescope
Vista will not work with autostar 494
I did some research on meade 506 astrofinder software
Read this...
Customer Review:
Rating: stars-1.0.gif
Summary: outdated software
The software this kit comes with is old and outdated. It is not supported by Windows XP nor Windows Vista. The latest supported version of Windows is Windows 98.
It also appears that the included software is a limited trial software. It is limited to the included 3 catalogs (star maps). The complete set of catalogs must be purchased additionally at quite some expense.
The cable connection kit couldn't be reviewed because it was missing from the package I received, but keep in mind when you order this kit, that neither Windows XP nor Windows Vista support serial ports anymore. The additional USB to serial adapter would be required.
That last line would suggest to me that if one had a USB to Serial adapter it might work? but I really do not know for sure. checking into some more stuff...
Found another article that states "It requires a PC running Windows 98SE through Windows XP. It will not run under Windows 95 or earlier, nor will it run under Windows Vista."
OK I found this site, you might be able to make some sense of it. But I did read in there that they do make USB serial adapters that will work with Vista OS.
Good Luck and happy star gazing! If you find something new out there maybe you could name it after me if you get it working. lol
Mar 07, 2009 | Meade DS-2114 ATS (325 x 114mm) Telescope
Meade LS 8" ACF 08100310 Telescope Logo
43 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Meade Optic Expert? Answer questions, earn points and help others
