Question about Krups Coffee Makers & Espresso Machines
Krups fmf5 coffee maker won't let me program and won't turn on to brew
I keep trying to set the time and the start time and I can set the time then it'll go back to blinking all '8888' s it's completely unresponsive....
SOURCE: Broken Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker?
My Krups was not working after I accidentally forgot to place the black plastic lid on the coffee carafe BEFORE starting to brew a new batch of coffee. The coffee will not drip into the carafe without the lid
in place. Because the lid is hidden when placed in the coffee maker, it's easy to forget! The coffee all backed up in the filter area and overflowed. The display got wet. Not good.....
If your buttons and or display is not working ( mine got wet with coffee) simply flip the coffee maker over. Unscrew the bottom. expose the display circuit board carefully, DRY it with a HAIR DRYER and put the unit back together! Presto! Mine is working again.
If you need a new circuit board, you can get one for $35 from Appliances.com I found. They also have the Duo filter and extra parts cheaper than the Krups website.
Posted on Feb 23, 2009
SOURCE: Krups Coffee pot stopped brewing after programming
OH Yeah!
That is the number one failure in these machines. (owned four of them)
The problem is one or both of the "twin" thermal fuses or the thermostat for water
heating and hotplate,( one in the same) has gone open. I have tried for a long time to locate correct replacement parts to no avail. I would STRONGLY not recommend trying to bypass as these are not only controls but a safety feature as well. I was lucky a wile back and found one without a carafe at a garage sale. used it for parts, now those have failed also. Really miss them. If I ever find a source for parts I will post it here with replacement procedure.
EfACTOR
Posted on Jun 13, 2009
  • 109 Answers
SOURCE: how do I program the krups fmf5? no manualQ@
More info here:
http://www.krupsusa.com/NR/rdonlyres/F32A6510-090E-48A2-85FF-4699D5486470/8008/FMEFMF.pdf
Posted on Jun 17, 2009
Sebin
  • 712 Answers
SOURCE: Krups FMF5 coffeemaker- coffeemaker begins to brew
Check for any blocks in the route of water from the reservoir. And do not try to run the machine several times before the problem is rectified. It may cause further damage.
Posted on Oct 08, 2010
headstrong56
  • 493 Answers
SOURCE: Coffee maker won't brew
the pump inside the unit it either clogged or broken
Posted on Jul 15, 2012
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
How do I program my fmf5 krups coffee maker
http://www.manualslib.com/manual/288811/Krups-Fmf5.html?#manual
Oct 04, 2014 | Krups Coffee Makers & Espresso Machines
Can get maker to run on manual
hmm get cute with it and just set it to brew in a minute from now. try that I'll be back after some homework, Did it use to run on manual? my last coffee maker had to push auto on twice for it to brew on the spot.
Mar 05, 2011 | Krups FMF5-14 Stainless Steel 10-Cup...
Feb 22, 2009 | Krups FMF5-14 Stainless Steel 10-Cup...
Lost manual
The manual is here: http://www.wholelattelove.com/manuals/Krups/FMF5%20Manual.pdf
Here is the relevant information from it:
Setting Auto On
This programs the coffee machine to start automatically at the set time each day.
• Press the prog button (o) briefly : the display will blink “prog“ for about 1 second, followed
by “8888“.
• Press the prog button  briefly: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button briefly: the minutes will blink “XX 88“.
• Adjust the minutes in steps by pressing the h/min button .
• Confirm the setting by pressing the prog button briefly:
• The display (q) will show the time and a “ “.
• Press the h/min button to cancel the programming.
Aug 19, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
How to set time
with the power off press down the program button untill the hour flashes then set it press the program button again and do the mins
Aug 02, 2008 | Krups FMF5-14 Stainless Steel 10-Cup...
Coffe does not stay hot in carafe
The wavy lines indicate the carafe pre-heat function. When it is ON the red light blinks for several minutes and the goes on solid. It doesn't start brewing until the light is solid red.
Mine also doesn't seem to keep hot also.
Mar 19, 2008 | Krups ProAroma 453-71 Coffee Maker
Coffee Makers & Espresso Machines Logo
66 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
