Question about Genie garage door opener series ii wall control
I don't know what size led diode to replace on Genie II Receiver model mobile ACSR3 wall console
I need to replace the led diode in the circuit board in the wall console of the Receiver model mobile ACSR3 and I don't know what size it is or where to purchase it. I know it is much smaller than a 5mm diode. Please help!
    Problem Solver:
  • 25 Answers
I would just buy a new wall control unit. The pic above is common (I have 6 on my truck). Just check amazon or your local genie dealer. Unless, of course you felt like reworking a 1x1.5" board. T-d-ous, in my opinion. Doubt it would be much cheaper, considering time, solder, and the fact that the led is NOT the problem......there's a switch on the top left of that unit.....check that its in the unlocked position. Check that the wires aren reversed. Then buy one online for like 10 bicks. Good luck!
Posted on Apr 12, 2015
    Sergeant:
  • 223 Answers
Its probably better to just buy a new unit or universal opener.
Posted on Mar 22, 2014
Rca 39" lcd full hdtv 39lb45rq picture comes through approximately 20-30 seconds and then black screen. Sound is ok.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 04, 2016 | RCA 39LB45RQ 39" LCD TV 1920x1080, 60 Hz,...
I cannot program my receiver Genie ACSR3 to work with a remote Genie GITR-3
check age difference, every so often the codes change and older parts will not work with newer parts
Nov 03, 2014 | Building Materials
Entry pad quit working on my Genie Excelerator model #H8000D. Changed batteries.Can this be reprogramed or should I purchase a new one?
The relay on the "unit's" circuit board was causing my light to stay on. If I tapped the unit with a stick the vibration would be enough for the contacts in the relay to open allowing the light in the unit to go out. Call The Genie company; the H8000D Genie garage door opener has a lifetime warranty but only if you are the original owner of your home. If you are the original owner you'll need to have a receipt for proof of purchase. If you don't have the receipt then a copy of your HUD-1 form that you received at closing when you passed papers on your home will be accepted as proof of (original ownership of your home). I have had my Genie H8000D for 12+ years now and so far I have replaced the black indoor wall switch, the out door mounted remote control and both internal circuit boards. After removing both old boards I found that the solder on both ends of one "blueish in color" resistor had come loose from the board because he solder failed. I installed the new replacement boards Genie sent me and the unit works as is should. On the old board the resister didn't look bad so I soldered it back onto the board and I'll keep it for a back up.
Aug 25, 2013 | Genie Company Genie Garage Door Opener...
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
Genie Garage door will not close. Receiver Model: ACSR3 FCC ID: BBQ ACSR3
If you hit the button on the remote and nothing happens then you may need to code in the remote. On the motor head press the learn button and then press the button on the remote 3 times.
If it looks like the remote will work the opener or it opens the unit but not close it you are experiencing safety sensor problems. Make sure they are aligned. There will be a light on each and each should be on. Check the wiring to them too. They are not polarized. Thanks BB
Aug 20, 2010 | Genie Company Genie Intellicode 1-Button...
Genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
Jan 21, 2010 | Genie Company Genie PowerLift Excelerator...
Genie Screwdriver, garage remotes won't work, batteries are fine.
Your receiver has quit working. A call to your local Genie dealer should get you back in business.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie remotes stopped working
The receiver can go bad and that would stop all remotes from working. The wall control would still work because it does not use the receiver.
Sep 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 21, 2009 | LG WM-2277HW Front Load Washer
TV does not respond to Remote
possible defective rf receiver led defective in the tv.
Nov 21, 2006 | Toshiba 32AF43 32" TV
Genie garage door opener series ii wall control Logo
114 people viewed this question
Top Genie Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Genie Building Material Expert? Answer questions, earn points and help others
