Question about Graco Ready2Grow Classic Connect Stand & Ride Stroller - Forecaster
I put the brake pedal on wrong, how do I take it off to fix?
Put the brake pedal on incorrectly. I have yet to figure out how to take it off to fix the problem. Can someone please tell me how I would go about doing this. I just got it today!
    Sergeant:
  • 223 Answers
Pull it off. the opposite the way you put it on
Posted on Mar 22, 2014
I put the brake pedal on wrong, now how do I take it off to correct it?
Hi Ajjr,
We would be unable to advise you how to repair this - you must speak with Graco.
Contact Us Graco
Mar 21, 2014 | Graco Baby Gear
The brake pedal on my 1984 Honda Shadow 500VT needs to be pressed deeply to apply brake, how do I adjust it so as to take the play out of it.
Replace the rear brake pads. The thicker pad will require less pedal movement. The other option is to tighten up the rear brake actuator at the rear hub. Put it up on the center stand and adjust away until you figure it out. Make sure it is in neutral and the rear tire spins freely when the brake is not applied. Push the brake pedal to see how it all works, you'll figure it out.
Aug 25, 2011 | 1984 Honda VT 500 C Shadow
My passat has no brakes, changed pads still no help how do i figure out weather its the master cylinder or the brake booster?
to check the booster
put some pressure on brake pedal with engine stopped
keeping the pressure on pedal start engine pedal should move down if booster is working
Feb 14, 2011 | 1999 Volkswagen Passat
I have a 94 ferrari 348 spider and everytime I press my clutch pedal down my brake pedal moves down alittle also, where when I am trying to leave at a light it feels like something is holding me back,...
Check the pedal assembly bolts they may be loose or a weld has broken under dash . Check under hood have some one depress pedals watch for movement that may not be normal .
Nov 03, 2010 | Ferrari 348 Cars & Trucks
No brake lights, checked mfuses,replaced brake light switchwhat now 1999 jrrp grand cherokee
next step is to run continuaty check on the wiring, boring and tedious i know
Jul 17, 2010 | 1999 Jeep Grand Cherokee
Audi A4 tail lights come on at night and drain my battery
its the sensor in the brake pedal, happens mostly at cold nights since cold weather loosens up the pedal it causes the pedal to go down by itself if like you were braking, I used to roll up the matt and put it underneath the pedal and that would put pressure upwards while i was researching on how to do it myself found out is complicated and decided to take it to the mechanic for a 200$ fix.
Nov 13, 2009 | 2005 Audi A4
Ford f150 2002 has no brake lights
yes there is. Above the brake pedal there is a switch tat turns the lights on when you press the pedal. It is tough to replace due to the lack o room to put your hands. but is an inexpensive part.
Oct 06, 2009 | 2002 Ford F150 Regular Cab
Brakes on 2000 regal motorhome (F350 V10)
Last time I had a low brake pedal, the wrong front wheel bearings were installed. Ford Dealer did not want to own up to it, but put the right bearings in and all fixed.
Hand brakes?
The factory used a small diameter drum on the pickups (even though the main rear bake is a disk). The parking brake pedal has to do full travel to hold the truck. It is just a pedal, cable and shoes so something is wrong with one of them.
If this is a hand brake on the transmission, I don't know what to say except that it is still pretty simple.
Jul 28, 2008 | 2000 Ford F350 Super Duty Super Cab
Graco Ready2Grow Classic Connect Stand & Ride Stroller - Forecaster Logo
60 people viewed this question
Top Graco Baby Gear Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
