Question about Bruder Cat Skid Steer Loader
I think I need a wiring harnesses for 7753 bobcat. Have power to the starter. I can cross the solenoid and the engine startts p, but as soon as I remove the screwdrive (used to cross the sld) the engi
I have a BObcat 7753. Nothing happens when I turn the key. Good battery. Power to the starter. Lights work.
  • Bruder Master
  • 2,760 Answers
What makes you think it's the wire harness (visably chewed up?)
how about a simple key switch they go bad all the time on my stuff Poor design by these companys (or is it?) to make the key switch on top, right where rain water runs down off top cage
Posted on Mar 22, 2014
Testimonial: "Good morning J.D., Thank you for responding. I absolutely can't beleive it, but I discovered last night that I hooked the battery up backwards. Yep, positive to negative and vice-versa. Sheer stupidity. So, now my problem is much bigger than I thought. Trying to find any fuses. I located one to the left of the engine next to two relays. The fuse was good, but I replaced it anyway just in case. No luck. Took off the covers for the ignition switch and the Boss system. No fuses there either. I'm thinking I cooked some wiring. After you get done shaking your head back and forth in disbelief over my stupidity, do you have any suggestions? Thanks, Bill"
  • J.D. Browning
    J.D. Browning Mar 24, 2014
    well if this was built after 92 it's got a engine control module you most likely destroyed it by reverseing power
2 Suggested Answers
SOURCE: Bobcat 553 f - traction lock problem...help
sounds to me like a bad connection or a weak solenoid causing the voltage drop. a good alt charges at 14.25-14.50. it takes voltage to open solenoids not close them.
Posted on Sep 05, 2009
How to crank a John Deere Bobcat without a key
you have to cross out the large and small wiring bolt stems on the starter solenoid to bypass ignition switch to crank an engine.
Sep 02, 2014 | Garden
Bobcat 7753
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Bobcat 7753 Skid Steer Loader Service Repair Workshop Manual INSTANT...
Jul 30, 2014 | Bobcat 773
Won't do anything when I press the starter thumb switch on the throttle. Replaced the ignition key switch, new battery, but nothing starts. Starter turns when I take a screwdriver and contact the two...
Check your starter button it may be dirty. You can spray it with electrical contact cleaner or WD-40 and work it to clean up the contacts. David Mazon
Aug 11, 2013 | 2007 Qlink Legacy 250
I have a 1998 ford f-150 and my truck wont start.
check fusible link also check for power at starter first..make sure trigger wire is good at starter
Feb 06, 2013 | 1998 Ford F150 Regular Cab
Car won't start, seems to have power, all lights working. when I turn the key nothing happens. this only happens sometimes
Could be a bad alternator.. It may not be holding charge. Or your starter could have failed.
Though I've had the same problem and it was a dead battery in my vehicle. Had enough power, but to keep the car on..
Oct 22, 2012 | 1997 Saturn SL
Bobcat starter stays engaged
Trace the wire from the "st" on the ignition switch to the small post on the starter relay or solinoid. If you find another wire going off from there follow it to the diode. It is likely covered with insulating sleeve at one end of the wiring harness. It is about 3/8" in dia and 3/8 long.Please note the colored band at the end which denotes the cathode.It must be replaced with one going the same way..
Hope this helps, Robert
Aug 16, 2012 | Bobcat Welding Tools
I have an 82 xj650 turbo. My problem is when i shut the key off it does not kill the engine. If i use the kill switch the bike will shut off along with the tail light but all the lights on the front of the...
I think your bike is being powered through the starter solenoid by a defective starter button. The starter button is on the right switch assembly and normally turns the headlight off when depressed halfway. A wire may be plugged in wrong in the headlight (Two wires are crossed). Take apart the right switch assembly and check for shorts and power from the solenoid ). Check the main wire harness to the handle bar switch for crossed wires (they are color coded).
Mar 15, 2011 | 1982 Yamaha XJ 650
I need a Manuel for a 1984 35 Mercury. I just replaced the starter cylenoid but it still wont start; however if you cross the cylenoid it turns over. I think I may have misplaced some wires while...
Your solenoid should have 2 large posts and 2 small posts. One of the large posts will have a cable from battery. The other large post has cable to starter. One of the smaller posts has a yellow wire with red stripe on it, the other I believe is black and is a ground. The yellow wire is the one that when the key switch is activated to crank engine, it supplies power from battery cable side of solenoid to starter side, thus making the starter function. Test to see if you have power to yellow wire at solenoid when someone tries to turn ignition key. Also as a side note, your remote contol has a neutral safety switch inside it which won't allow the engine to crank if it is in gear or broken.
Feb 09, 2011 | Light Outboard Motor Boat Bass Fishing...
When you turn key nothing happens,lights,horn,radio works
check the battery conections for tightness then check continuaty to starter motor.. if power is getting to starter , could be starter. however if any of the dash lights go dim when turning key , suspect the battery.
Feb 02, 2011 | 1993 Jeep Grand Cherokee
Wont start with ignition when key is turned but is not the ignition or starter silonoud ?
There is a starter solenoid on the starter and another one on the firewall or inner fender.Follow the positive cable from the battery to the solenoid.Remove any covers that may be hiding it.Now,with the car in park or neutral and the park break set on you should be able to get it to crank by crossing the two large copper posts with a screw driver.If it cranks over now then you need to check for power to the small post with the black an red wire going to it.If you have power with the key in the start position then you need to replace that solenoid.If the is no power in that wire then you could either need a neutral safety switch or an ignition switch.If nothing happened when you crossed the posts on the solenoid then you either need a starter,the cables need to be cleaned or replaced,the nut on the starter solenoid could have loosened off,the small wire on the starter solenoid may have a bad connection or your battery does not have enough amperage in it to turn over the engine.Hope this helps.
Sep 12, 2010 | 1990 Ford Thunderbird
Bruder Cat Skid Steer Loader Logo
298 people viewed this question
Top Bruder Toys Experts
ptpumpman
Marc Taylor
Colin Stickland
Colin Stickland
Are you a Bruder Toy Expert? Answer questions, earn points and help others
