Question about Innovative Technology ITRR501 Audio Shelf System
How, or where can you go, to get a vinyl record player made my it. (innovative technology) fixed?
The product is the "Wooden Music Center with Recordable CD Player" (model ITRR-501) and it seems more complicated than the turntables that are shown being repaired on the youtube tutorials I've seen. Also I've deduced that it's a problem with the belt but in trying to fix it myself I'm pretty sure I made everything much worse.
  • Andrew Guertin
    Andrew Guertin Mar 22, 2014
    I think initially the only problem was the belt. I found some tutorials on youtube showing how to replace belts yourself so I attempted to. This record player must be a little different though because the instructions I was getting weren't all applicable, so in my failed attempted to fix it myself I think I caused additional problems. I'm having trouble finding a company that brands itself as an audio repair business but there are a couple of appliance repair businesses. I hope they can help.
4 Suggested Answers
  • 5379 Answers
SOURCE: NEED operators manual for ITRR-501
The unit will record to CD from the turntable, cassette or the AUX port. Place a blank CD-R or CD-RW in the CD tray. (Note: CD-RW discs may not play on other CD players.) Press the Phono, Tape or Aux button to select your audio source for recording. (For Aux, you will need to connect the source device to the AUX port in the back of the ITRR-501.) Wait for the CD disc to load and check for any indicator lights (you should see the "NO TOC" and "CD" or "CD-RW" lights lit). Select your Track increment (or Auto Manual for unattended track formation).Press Record button and the up arrow to adjust the recording level.
If you are recording from an LP, put the tone arm down on the record. For all sources, press Play. Press Stop to end recording or Pause to temporarily break the recording. Press the Track Increment button to advance the track number if you are doing so.
To finalize your CD-R to make it readable on all players: after stopping the recording, press the Finalize button.
The manuals for Innovative Technology products are available here: http://www.ithomeproducts.com/support . The products are listed in alphabetical order. The direct link to the ITRR-501 manual in English is http://www.ithomeproducts.com/sites/default/files/pdf/ITRR-501.pdf .
I hope this helps.
Posted on Sep 19, 2011
SOURCE: ITRR-501 The turntable does not
Turntable belts can be found on EBAY.
Posted on Mar 10, 2012
  • 42870 Answers
SOURCE: Innovative Technology ITRR-501 music center turn table for records is slow
The motor may be weak or there could be a dry bearing.
Posted on Jun 07, 2017
Record player doesn't move when I pick up the needle but it sounds like the motor starts. I hear a clicking noise when I move the needle to the record. Model ITRR-501
You can use a small screwdriver to remove the C clip in the center of the platter. Then remove the platter and reinstall the belt. It can be a little tricky to get the belt back on. If that fixes the problem, then I would look online and order a new belt as yours may have stretched out and will keep falling off. Here is a link to purchase the belt if needed.
NEW INNOVATIVE TECHNOLOGIES ITRR 501 ITRR 700 ITVS750 TURNTABLE BELT D001RX
Dec 14, 2017 | The Audio Players & Recorders
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
I have a Kenwood KR V6090 tuner amp. Can anyone please tell me if I need a record deck with or without a pre amp fitted.
Hi. Some amplifiers provide power for a record deck (or you mean a vinyl record player). Some vinyl record player have their one amplification system, some don't. Those with the amplification system work fine on older amplifiers but others require a back-up power, like a transformer to provide power for the record player. You need to enquire with the store person on the type of record deck or record player you can use directly with the V6090. I had an early Pioneer Amplifier and a matching record player so that I could play the vinyl disc and LP's on full volume. Later I switched to digital Pioneer 7 channel. This couldn't accept the record player because it did not have a power substitute like the older Pioneer. So, when the record player plays, no signal is being sent to the amplifier and therefore, no music is heard, except from the needle.
Dec 12, 2014 | Kenwood Audio Players & Recorders
NO SOUND
This is almost for sure just a connection that came out when moving or during shipping. Pull the back, off and look for some wires just hanging. Most likely it is an input.
Apr 14, 2014 | Innovative Technology Elect IT 5-in-1...
Itrr-501 user manual
You may download a copy of the manual here.
Dec 19, 2012 | Innovative Technology Elect IT 5-in-1...
My innovative technology mp3 music player wont turn on it will only stay at the blue screen
hi my innovative technology "IT" has stop showing it's program on the cumputer and it says its full even though its blank
Apr 13, 2008 | Audio Players & Recorders
Innovative Technology ITRR501 Audio Shelf System Logo
46 people viewed this question
Top Innovative Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Innovative Audio Player and Recorder Expert? Answer questions, earn points and help others
