Question about Protron PD-800 DVD Player
HELP HELP HELP
Picture has wavy lines across the screen when DVD is played.
    Scholar:
    New Friend:
  • 67 Answers
Lines may be caused by AC pickup. if so, usually the lines move slowly up the screen, and two major sets are usually displayed. wavy lines may also be caused by a local TV station transmitting on the same output channel, either 3 or 4. If you can change the output channel, this may help. Also, try disconnecting all cable or satellite signals and see if the problem goes away. May be an adjacent channel bleeding over. If the lines go away when putting the dvd on pause, the problem is probably in the dvd power supply. Cool the unit down by unplugging it for a while and then try it. If the problem goes away then, separate the dvd player from other devices to prevent overheating
Posted on Nov 30, 2007
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
There are wavy colored lines an the screen all the
A problem like yours is NORMALLY NOT the TV set's fault....it's the Cable.
I'll bet you see thin lines moving across the entire picture...they are slanted like this >> \ \ \ \
That's generally caused by a bad ground on the antenna cable OR it can be the cable box's MODULATOR.
Try using your VIDEO OUTPUT off of your Cable box and see if the wavy lines are still present. If they are the Cable box needs swapped with a good unit.
You can also verify this problem by checking your TV with a DVD player...no lines indicate the TV is fine.
If you have problems with the DVD player's picture, then you must have dried out filtering capacitors on the Video board IN the TV set...
And THAT is not an easy fix if you do see lines with your DVD player.
Mar 27, 2009 | Sony KP-51WS500 51" Rear Projection...
Red red wavy lines across the TV screen
I did not fix the problem, but you have the model number wrong, it is KP-46WT510
I do need some help.
Nov 23, 2008 | Sony KP-43HT20 43" Rear Projection...
Wavy lines across the digital screen of DSC-V1
Can u mail me 1 photo at welcomejee@yahoo.com to understand what exactly happening with your camera?
May 27, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
Wavy picture on all video inputs except component video toshiba 57h82
make sure you replace all the 10uf caps and that the connections are good....
Sep 20, 2007 | Toshiba 57H82 57" Rear Projection...
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Emerson TV EWT2721 27"
Did the TV get pink with the wavy lines all at once, or did it start out gradual? If all of a sudden, then a defective part on the CRT control board or the picture tube itself could be going bad along with some components in the video section of the set. Probably not a cheap and easy fix I'm afraid.
Jan 01, 2007 | Emerson EWF2703 27" TV
Protron PD-800 DVD Player Logo
225 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
