Question about Kenmore Dishwashers
Kenmore elite dishwasher model #665 1726 won't run
I have a kenmore elite dishwasher model #665 1726 2401 that stopped working. There is power, we checked the breaker. When you press the cancel & drain button the light comes on and it runs for about one minute. The hi temp wash , sani rinse and heated dry buttons will light up when pressed but the machine won't start. Also if you press the pots and pans button, the cancel/drain button lights up and runs for about one minute. Any thoughts?
jyackle5
  • 8197 Answers
SOURCE: I have a Kenmore Ultra Wash 15632/34/37/39. The
Try to Press and hold AIR DRY for 4 seconds, to reset the dishwasher
Posted on Nov 15, 2010
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
  • 949 Answers
SOURCE: Glasses look filmy and fingerprints are still
It sounds like you have a serious wash problem. A couple things to check.
Be sure you are using fresh detergent. Old dish washing detergent looses its power and will not work. Be sure to use a name brand like Electrosol or Cascade they both contain the chemicals need to dissolve and clean properly. Use more detergent if you have hard water or use an additive such as lemi shine or glass magic to boost the water softness.
Try running the hot water faucet at your kitchen sink unit hot prior to starting the dishwasher this will help with the thermal energy needed to clean.,
If you still have trouble send me your complete model number from the tag on the tub so I can help trouble shoot the machine better.
Posted on Apr 25, 2010
  • 11 Answers
SOURCE: pots and pans light, quick
Try to pull the fuse or turn off the breaker for 30 seconds. This should reset the electronics and possibly fix the problem.
Posted on Sep 08, 2010
Kenmore elite dishwasher mdl 665.16919001 all lighs out, won't come ont
try a simple step to reset unit unplug and then plug back in
May 26, 2012 | Kenmore Dishwashers
Won't turn on
unit will only run on cancel cycle
Jan 29, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Door won't close
you will need to replace the strike and the catch. you can try adjusting it but that probably wont work.
Nov 20, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Model 655-15974990 won't wash or drain
What DOES it do? Just fill with water? Or doesn't it even do that? Do you have any lights on or flashing? Do you hear any noises when you try to run it?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwashers Logo
284 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
