Question about Sharp CD-SW330 Shelf System
How to turn off demo mode without remote
I got the system for free from a department in my school. People donated a lot of systems and they didn't need them. problem is I don't have a remote and the demo thing is really annoying (esp since I'm using them as computer speakers), and replacement remotes are going for $30+ dollars (which is ridiculous). Is there any way to turn if off without the remote? What about turning off the lighting effect? and changing the bass and general sound settings?
james klgr
  • 362 Answers
SOURCE: Sharp Aquos rattling bass
the sharp some models dont put a spacer between the speaker and the case causing the speaker to hit the case at med to high volume you can check this and make you a spacer out of washers on each screw that mounts the speakers between the case and peaker frame make sure that the washers or spacers you use dont contact the speaker core. and dont do anything that will void the warrenty if nothing else let the store fix it.
Posted on Dec 12, 2007
  • 17 Answers
SOURCE: Remote Control Problem
take the batteries out of the Sharp remote press and hold the POWER button on the top of the remote for 5 seconds. Put batteries back in. Make sure that function is set to TV. Should work - if not call Sharp. If you are inside the original manufacturer warranty they will replace remote
Posted on Dec 22, 2007
  • 4 Answers
SOURCE: Changing the Recording Speed without manual or remote
when you are programing the shows and you highlight the tape speed use your channel up and down button to change tape speed.
Posted on Mar 07, 2008
SOURCE: how do u turn off the demo mode?
WITH THE SYSTEM OFF. PRESS "X-BASS" ON YOUR CINEMA COMMANDER. SHOULD DO THE TRICK.
Posted on Aug 27, 2008
  • 1214 Answers
SOURCE: How to acess set-up menu without factory remote
The manual can be found near the bottom of the Product page for this TV.
From the manual, pg 11 -
If you misplaced your Remote Control you can still access most settings via the MAIN MENU screen when you press both CH UP (8) and DOWN (9) on the TV set. Some features of your TV Set will not be accessible without the Remote Control. If you lost your Remote Control, contact a Sharp Authorized Servicer by calling 1-800-BE-SHARP for a replacement.
Let us know if this fixes it for you.
Posted on Feb 11, 2009
It is stuck in demo mode how do I fix the problem
SELECTED PRODUCT: (change your search)
How to disable the demonstration (DEMO) mode.
Article ID: 42707 ' Last Updated: 03/11/2014
Sony® stereo systems will enter the DEMO mode the first time you power on the system or if you do not operate the unit shortly after turning on the power to the system.
To disable the DEMO mode, while the stereo system is powered off, press the DISPLAY button repeatedly until the demonstration display disappears.
NOTES:
  • Depending on your model, some units have a DEMO button that is used to disable the demonstration mode. If your unit has this button, with the power to the system off, press the DEMO button until the display disappears.
  • If applicable to your unit, setting the clock on your stereo system will also disable the DEMO mode.
  • Using the buttons on a supplied remote control will not disable the demonstration mode.
If model-specific information is needed to complete any of these steps, refer to the operating instructions supplied with the product. Manuals, Specifications and Warranty information for your Sony product is available online.
May 27, 2015 | Sony Audio Players & Recorders
Won't turn off... keeps turning itself back on
are you sure it's not just going into demo mode after you turn it off? There should be a button on the remote to turn on/off demo
Jul 21, 2014 | Sharp CD-MPX850 Shelf System
Got a Panasonic CD stereo system SA-AK410 When I turn it off after a few seconds it turns back on. Is this normal?
That's because you haven't set the clock on the system. I jumps to DEMO mode once you turn it off without the clock set. Clock can be set through your remote. Hope this helps. Cheers.
Oct 04, 2013 | Panasonic Remote Control Eur7710020...
I can't turn demo mode off or Standby from flashing on my Sony CMT-MX550i, can't turn unit off without unplugging it.
Sony CMT-MX550i -- I had good results by pressing the "TIMER MENU" button on the remote and simply setting the time. After that, no more demo.
Jan 16, 2013 | Sony CMTMX500i Desktop Micro System
I can not leave the system plugged in.If I do the display is in constant motion with information,i.e.hello,good;bye,sleep,etc. I have tryed several times to clear memory without sucess.What do I need to...
I was just having the same problem and figured out how to fix it. When the unit is off (in standby mode) hit the X-BASS/Demo button on the remote. This will solve the problem!
Dec 17, 2010 | Sharp Multi-System Mini Component System...
Turn demo mode off on Sony Bravia TV
Press and HOLD (5 sec) the MENU button located on the SIDE of the TV. A message will appear; (Demo Mode: OFF).
Mar 30, 2010 | Sony BRAVIA® DAV-HDX576WF Theater System...
How do i turn offthe demo mode on a philips
On any appliance that has demo mode the solution is usually to hold down the stop button for like 3 seconds.
Sep 23, 2009 | Audio Players & Recorders
I have a Pioneer XC-F10 Stereo CD Tuner. I keep trying to turn it on and it keeps turning off immediately...?
I Have managed to solve my instant turning off fault. As its been mentioned before, this is a demo mode fault, heres what I did...
Leave the Unit in standby, and press and hold the "system menu" button you should see the words "demo mode" flash up on the display briefly, at this point press the "set" button to enter demo mode selection finally press the "+" or "-" button to turn the demo mode off.
You have to be quick with the remote buttons when getting into the demo mode, might take a few trys.
I'm not sure if this will fix everyones fault, but certainly helped with mine. Good Luck.
Oct 11, 2008 | Audio Players & Recorders
I have a jvc compact component system MX-C220 (old school, i know), and it wil shuffle through the different audio options without being prompted to do so. i don't have a remote and i keep having to run...
yeah i have the same stereo and i know what u are talking about. to fix this all u have 2 do is press the demo/fm mode button next 2 the power button. that turns off the demo which is y it switches through the different audio functions. but i have another problem with mine it works and everything but 4 sum reasons it has problems playing burned cds, it works pretty well with cds bought but burned cds usually never work or takes min or hours 2 work. any suggestions
Sep 01, 2008 | JVC Audio Players & Recorders
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
Sharp CD-SW330 Shelf System Logo
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
