Airtec S-24H E5 error
My split aircon displays E5 and blows air but won't heat it despite displaying sun (heat mode) what could the problem be ?
SOURCE: blows hot air
My 2003 chevy suburban just started blowing hot air...it was working find , then i stopped to eat lunch, when I came out it started blowing hot air
Posted on Jul 01, 2009
shastalaker7
  • 1515 Answers
SOURCE: have a reverse cycle split system LG aircon
Hi, dealing with these ductless split systems on a daily basis, I can say you have checked some of the things I would have wanted you to check, which is good on you're part.Blowing Room Temp. air in both heating and cooling indicate that the compressor is not running even though the outdoor condenser fan is on.There are several things that could cause this. You have a compressor run capacitor that starts the compressor, but I am thinking on you're unit, it has a dual capacitor that runs the compressor and fan together. Fan is on, so I will rule this out.These units are notorious for leaking freon as the Liquid line and suction lines are not brazed, they are put together with connectors that tend to leak over time. If it is low enough on Refrigerant gas, the compressor will shut off and stay off on low pressure. This unit has a low pressure switch that has normally closed contacts, that opens and stops the compressor from any damage which in turn, you will have no cooling or heating.Do this for me, turn the unit on in cooling, lower T-stat way down so outdoor unit comes on. Go to the out door unit and where the elect. wiring and lines go into unit you will see to copper lines. The largest of the 2 lines is the low or suction line.Wrap you're hand around it and it should be nice and cold. If it is warm, just touch the smaller line, it should be rather warmer, almost hot.If both lines are of normal temp. you are either out of freon or the compressor isn't running.You can remove panel to get to it and put your hand on it to see if it is on. If the lines were of normal temp. and the compressor is not on, more than likely you have lost the charge.Look it over, the wiring to see if you see anything burned or connections burned off and so on. You can check the 3 wires going into the compressor by turning off the power at breaker and removing the cap covering wires just to make sure these wires are intact. sometimes one will get hot from power and burn off. If you see this problem, it would be something you could fix.If all looks good, go back to the copper lines and being this is a Heat-Pump, you should have 3 fittings where we install our gauges to check and fill systems with freon. Look for one that is on the unit itself and remove the plastic cap.Don't be alarmed if you do as nothing will come out.If you look inside the valve, and you see a Schrader core, you can depress it with a nail or something small, just enough to see if it has a lot of pressure in it.If very little or none, the system is out of freon. You will have to call a tech out to find leak and evacuate and re-charge system.I wanted to give you many things to check so you and I would know what the problem is, a process of elimination. If you have a lot of pressure, then more then likely you have a faulty compressor. If you feel that you would rather not check the electrical or depress the Schrader, I fully understand.You can at least check the temp. of the lines and listen to see if the compressor is running, and if it is with warm lines it is still low on freon.Please keep me informed, and again the long explanation was for you to understand more about you're system operation. Sincerely, and best of luck,
Shastalaker7
Posted on Nov 23, 2009
Myminisplit
  • 11 Answers
SOURCE: LS-L1210CL 12000 BTU Cooling Only Mini Split Air Conditioner: Cannot get aircon to heat up the room...
Sure, you can get one at http://myminisplit.com
Posted on May 21, 2010
SOURCE: Samsung AQV12VBA error cod displayed E5 54
Check the freon...
Posted on Jun 09, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a Carrier Aircon.
E5 Outdoor activation of compressor over heatprotection or motor lock
Please clean the condenser coil. And also check out door fan motor rpm. Rpm may be less due to weak capacitor. Replace it.If motor locked you have to replace new motor only.
If helpful, please write.
Posted on Dec 20, 2010
I have a Carrier Aircon. Model 42QH12-C and it is displaying error code 5. The aircon stays on for a while (anywhere between 10-60mins) and then turns off and displays E5. If I just press the 'on/off'...
Dec 20, 2010 | Carrier 38CKC042 Air Conditioner
My air conditioner blows air but it is not cold? What can be the problem?
It could lacking refrigerants (freon). contact your local aircon tech; I do not recommend DIY.
Hope this helps!
Fix14
Jun 16, 2010 | Turboair TAS-24H Split System Air...
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
I have a sanyo aircon split system and i need to know the icons
the icons are snowflake = cool, raindrop = de humidification, fan blade = fan, sun = heat. hope this helps.
Jun 11, 2009 | Sanyo Split System Air Conditioner
Cant make it blow out hot air.
You do not mention the model. Most aircon remotes have a mode button which has three or four icons. On cooling there will be a ice crystal icon on the lcd display. Pressing the mode button (sometimes behind a cover on the remote) this icon will change. You want to set it to the "sun" shaped icon
Jun 02, 2009 | LG Heating & Cooling
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
