Cda c1830 washing machine
Hi ,I have an 1830 washer dryer, could you tell me if there are two settings for the dryer as it seems like the clothes take forever to dry
SOURCE: How do you get the dryer to actually work?
That button with the 1/2 on it and then the time dial works and it sounds as if it is washing your clothes, but it is actually drying the clothes but heats up water in order to do it. It is kind of insane actually but it does work and that is the way to do it.
Do you know if there is a place to clean a lint filter? Is there a lint filter somewhere?
Posted on Oct 15, 2007
SOURCE: washes clothes fine, drying cycle no heat
Hi, we had the same problem with a WD420P. After a washing machine repair man plugged in the diagnostic machine and found that there was no fault, my boyfriend had a look. The nut securing the cooling fan inside the heater element was not tight so the heater overheated and tripped it's stat. This was a 5 month old part fitted after the original was replaced under warranty.
Posted on Jan 14, 2008
SOURCE: My WVF 2402 washer/dryer washes clothes ok but doesn't dry them.
Sorry I'm way late with this but I've only just noticed it. Unplug the machine from the mains! Remove the lid (with a torx screwdriver) and you'll notice a small circular device with 2 leads attached on the top of the machine, in the centre there's a small button, press it and it should click......you've fixed it This is a thermal cutout safety device designed to switch the drying heater off if it becomes too hot. The probable cause for this is that you've over filled the machine and the air didn't circulate freely. as a rule of thumb, dry 1/2 as many clothes as you wash.
Posted on Apr 26, 2008
SOURCE: Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Posted on Jul 23, 2009
  • 6277 Answers
SOURCE: My LG washing machine smells like rotten eggs when
Washer first!
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
The other possibilty for the source of the smells is the u-bend into which the washer drain goes. Either its own 'u-tube' or maybe it shares a sink's?
Dryer now-
Does that have a clear filter? I don't know your particular model but if it is like ours it may have a double heating element, one for 'low' and both for 'high'. If so it could be that the 'high' element has failed and everything is being dried on 'low'.
Hope this assists you with both and good luck!
John C
Posted on Feb 21, 2011
There is only enough water to cover the clothes in the washer on the wash cycle, is this normal
Hi Judy, This is quite normal for modern machines. It's an eco friendly thing.
Jul 12, 2015 | Washing Machines
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
Hi, I had purchased second hand MARGHERITA 2000-AB63 Washine Machine. BUt i dont have manual to operate. Pls Help.
i have ariston marghrita 2000 AB 63 it does not clean cloths and does not dry cloths.whenever i takeout cloths they are so wet that water drops out of these cloths. pl tell me what shall be position of different buttons and knob when i wash wash cotton/tetron mix cloths
Oct 25, 2010 | Ariston Technologies Ariston AWD12 Front...
Do you know why the dryer on the CDA C1992 not drying the clothes effectively? What we doing wrong? Stuff coming out wet
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 18, 2010 | CDA CI592 Front Load All-in-One Washer /...
Dryer does not stop. time shows flashing rectangle.Is this normal
Hi There
I have this for you to read this should get you on the right track. Let me know how it went.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you for writing to fix ya.
Best Regards Richard
Dec 23, 2009 | Samsung WF203ANW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
