Question about Yamaha Emx68s Powered PA Mixer System
Yamaha EMX62M PA - WON'T TURN ON
It just went out the other day. Do these things possibly have a fuse that I can replace??
I went to start my 2001 yz125 an on about the third kick the kick start locked up. i took it apart an tried it again still the same thing have you seen this before an if so could u tell me what it mite be
Hi, Todd for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Won start Kick start won even go down it like it stuck Banshee Repairs and...
Dirt Rider Magazine
YAMAHA YZ125 Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 21, 2013 | 2003 Yamaha YZ 125
V star 950 won't start
Hi, Joe you may have fried the ECM while trying to jump it from the Jeep otherwise the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
VStar 650 won start
Frustrated Yamaha Star Won x27 Start
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
YAMAHA XVS950A Owner Manual
May 31, 2013 | 2011 Yamaha V Star 950
Changed coil ignition module cap and rotor a week ago, now doing same thing again, it'll turn over all day long has fire but won't start like it has no fire.
are you getting FUEL ? are you sure ? you might need to replace both the air& fuel filters !!!!!!!!!!!!!!!! fuel pump may be bad !
Mar 08, 2013 | 2000 GMC Jimmy
Yamaha Msr250 (10" Biamped PA Speaker) It's like new, possibly even new but I can not figure out why the sub will not play. The PA horn works and plays high treble. I see 3 good fuses on the board
Remove the back, follow the 10" speaker wires and check if you can see any obvious bad solder. If you find a bad solder just resolder it and give it a try. You can also check for burnt discrete components like capacitors.
Oct 18, 2012 | Yamaha MSR250 Speaker System
The headlight low beam went out, a few days later the high beam went out. I replaced the bulb, the headlight still dosent work. What do I do now? 1996 Yamaha Virago xv 1100
have you checked your fuses? next thing is to check for voltage at your connecter. if now voltage start tracing wiring back to fuse block.
Jul 25, 2011 | Yamaha Vino Motorcycles
Headlite don't work. I replaced the bulb but didn't help.
Hi, Freebird8282 if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
Headlight Indicators Not working
Why won my headlights turn on
Yamaha XV 535 DX Virago Service Manual
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
May 12, 2011 | 1990 Yamaha XV 535 Virago DX
2003 yzf600r 7.5 amp ignition fuse blows. Day after washing and 3 days after replacing CDI. When fuse blows CDI shorts internaly. Why dosnt the fuse protect the CDI and what could be cusing it to happen.
Hi, Kc6hkd for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZF600R Forums View topic Please help my Ignition fuse keeps blowing
http://www.r6-forum.com/forums/57-garage-mechanical-help/212794-ignition-fuse-blowing-when-i-turn-bike.html
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
Yamaha YZF600RP Owner Manual
Sep 07, 2010 | 2001 Yamaha YZF 600 R thunder cat
Motor cycle over- heating, cooling system problem
it could be a few different things, first thing i would check is the fuse, if the fuse is ok, unplug the fan and jump it stright from the battary to make sure your fan is still ok. if the fan dont turn stright from the battary then replace the fan. if it does turn ok then you have a thermo switch that sences heat and tells the fan to kick on, what you need to do to check this switch is, unplug the switch, take a peice of wire maybe about 4 to 6 inches long, strip both ends and connect them to the leads inside the plug.. kinda like direct connect, turn on the ignition and see if the fan turns.. if not, replace the thermo switch. the only other possibility is in the cooling system wireing witch i dont know much about.. i just went threw the same thing with my 2001 yamaha r6 and i changed the fan and it was still popping fuses when the fan was supposed to come on. After 2 days of checking and trying i made the descovery that a wire harness was hitting the fan blade causing it not to turn.. i hope this helps you out and good luck..
Apr 26, 2009 | 1996 Triumph Trident 900
When I turn it on the fuse blows up.
Hi..
It will need service.
I would call the music store closest to you that sells PA gear and ask who fixes theirs.
Jan 10, 2009 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha Emx68s Powered PA Mixer System Logo
127 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
