Question about Singer 14SH654
Looper problem on 14SH644 Singer Ultralock Serger w/differential
How do you adjust the timing and align the lower thread loopers? Where can I locate a MAINTENANCE manual?
  • nata_jane May 11, 2010
    Does your needle hit your lower looper, or slide behind it? Let me know because that is what mine is doing... I'd love to hear your answer if you get one on this.
  • Tanya Arcuri-Gout
    Tanya Arcuri-Gout Dec 07, 2013
    did you ever get an answer?? my lower looper just broke and that must be why
    Guru:
  • 351 Answers
You can find free manuals to down load from singer ..
http://www.singerco.com/accessories/manuals.html
Please vote !!
Posted on May 14, 2010
    Problem Solver:
  • 16 Answers
Try www.sergerparts.com there you can find a nice tutorial on how to set the timing.
Posted on Aug 19, 2010
Singer 14T967dc serger runs but does not stitch
Hello Laura
Make sure that the lower looper thread is in front of and over the upper looper thread when threading the serger; when threading for overlocking.
Please let me know how this worked out for you
Happy serging
Feb 24, 2017 | Singer Sewing Machines
I have a white speedy lock serger model 7340. I completely pulled all threads out and now trying to re-thread new thread. I have tried around 15 times. It will not loop. Threads don't interlock at all
Be sure that you are threading each thread in the correct order. The manual should have those instructions.
ALWAYS RAISE the presser foot when threading the machine!!!! For most machines, the upper looper is threaded first, the lower looper second (the lower looper thread finishes by draping OVER the top of the upper looper and then pulled toward the back of the machine), then thread the needles. Give each thread an extra little tug when threading the tension disk to make sure it is seated completely.
Even if you are unable to locate a tutorial for your particular machine, most models from the same era will thread the same.
Don't be surprised if it doesn't work the first, second, or even the third try. It took me most of a day to get mine threaded correctly the first time!!! Patience!
How to Thread the White Superlock 534 Serger Serger Machine Series Ep 2
How to thread White Superlock serger
Sewing Machine Instructions White Speedylock Differential 1800
You can search YouTube for other videos.
Jan 06, 2017 | Sewing Machines
Can I replace the plate needle on the singer profinish serger myself
Laura's Blog: Do it yourself serger repair - How to adjust ...
bangerlm.blogspot.com/2007/.../do-it-yourself-serger-repair-how-to.htm...
Jan 30, 2007 - So I recently did something awful to my serger and the needle broke, the ... Plus it isn't really generic, it is basically some notes for some various olderSinger sergers. ... There were two screws on the bottom plate, plus 4 screws in each of ... If you thread the machine and you can't get the lower looper thread ...
How to fix timing on serger - YouTube
? 4:36
https://www.youtube.com/watch?v=BT6kiYyG2bw
Jul 21, 2013 - Uploaded by Jasmine Harris
Up and close detailed view of how to fix timing on your sergermachine ... looper and lower looper should be when the needle is up or down. .... way I can ever take it into the shop, so unless Ican fix it myself I'm out of luck. .... How to fix the upper looper timing on a Singer serger/overlocker - Duration: 11:02.
[PDF]Singer 14CG754 Serger Commercial Grade Manual.
www.sewingmachinesplus.com/media/.../singer/.../Manual_14CG754.pdf
Jan 10, 2016 | Singer Sewing Machines
I have a singer ultralock 14u34. The lower looper will not stay threaded when I try to sew, just works for an inch then nothing is catghing and the looper is no longer threaded.
Some sergers will unthread themselves if the thread is not threaded through the throat plate right. Especially the lower looper because there is not a lot of space for it to move. Try bringing the thread from the looper straight up through the hole in the throat plate, not to the side of the plate. You can also talk to the professionals at the link that I have attached. They are very helpful and easy to work with. Good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Jan 25, 2015 | Singer Sewing Machines
Stitching is too loose on the Juno Janome Serger Model 3434D
sergers the most frustrating machines. Every time you change fabrics you go through a tension adjusting phase.
First make sure you have threaded the machine in the proper order. upper looper, lower looper, then needles from right to left. Always thread any machine while the presser foot lever is in the UP position.
If you ever break a thread... you MUST pull all threads and rethread using the proper order.
Ok that's out of the way. Pull all your threads and get out several pieces of the same fabric scrap. Thread each pathway with a different color. This will help you determine which thread is giving you fits. Sew a test strip. Which thread is loose? tighten/loosen that tension. Keep doing this until you have a well balance seam. Then clip the colored threads starting with the upper looper thread, tie off to your proper color for your seam pull the thread through and up through the throat plate. proceed in this manner with lower looper, right needle, left needle. Sew a test seam.
Good luck.
Aug 08, 2012 | Janome Sewing Machines
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
My serger will only sew a few inches, then the thread on the lower looper breaks. I have checked threading, rethreaded many times.
Been there, done that. Old serger almost went out the window more than once.
Raise the thread antenna and loopers to their highest positions.
Set the tensions to zero. If your serger has auto-tension, raise the presser foot as this also opens the tensions.
Begin threading from the right as indicated in your manual or on the door of the serger.
If this continues, the serger may need to be serviced as the timing could be the problem.
Ask before leaving the serger as the service cost usually starts around $100.
I finally gave in and bought a Babylock with instant jet-air threading.
Apr 01, 2010 | White Sewing Speedylock 1600 Mechanical...
Lower looper problems
Some sergers require they be threaded in a particular order. If not, they do not "knit" the threads.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the tension settings are automatic, raise the presser foot to open the tension settings.
Turn the handwheel so the loopers are at their highest position. There may be a mark on the side of the serger to match up with a mark on the hand wheel for this.
Open the front of the serger and the threading guide should be printed on the inside of the serger door, or on the serger.
Start at the right and note which looper is threaded first and then the needles.
You can find more information and manuals at the Singer Co website.
Mar 24, 2010 | Singer 14SH654
I had to rethread my Singer Ultralock serger and now it won't sew correctly. Best I can tell the lower looper keeps coming unthreaded, but this doesn't happen until I put material in. I have rethreaded it...
I had read where someone said their lower looper tension dial had pulled apart. Sure enough, mine had too. We snapped it back together and Voila problem solved!
Dec 06, 2009 | Singer 14SH654
Could not adjust both looper thread tention on singer ultralock
When servicing these machines I have found that the cover over the tensioners needs to be removed so you can see if there is more adjusting possible. If its a newer serger you would hold the knob somewhere in the middle (4-5) and adjust the knurled part that goes through it. Many times I have had to rebuild these tensioners as they get dirty and need cleaning and adjusting. It may take many tries until you have it adjusting correctly. But it needs to be done.
Feb 12, 2009 | Singer Sewing Machines
Singer 14SH654 Logo
2,568 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
