Question about Frigidaire FEX831F Top Load Stacked Washer / Dryer
Washer will not start
Evenin folks, I've got a stackable frigidaire washer center - FEX831FS2 - that will not start a cycle. A while back we had some freezing temperatures. I tried to start a cycle and got a low hum but no response from the valve. Figuring the pipes were frozen, I left it at that. My roommmate, however, tried to start a cycle and repeatedly pulled the timer in and out attempting to start a cycle. When I returned home and confirmed the pipes were thawed, I tried to start another cycle. No water, but also no low hum this time. So on to my question... folks who may have seen this a few more times than I have - did we burn out the timer or the valve? I tried to put a generic valve on it to see what would happen and had no luck, albeit the valve in the machine ( http://s.sears.com/is/image/Sears/PD_0026_417_134890600 ) has two additional small single wire harnesses on top of the valve instead of the typical two red/white double harnesses you see. The generic valve did not have anything to plug those into. Additionally, if I turn the timer to try and drain/spin/rinse, there is also no response. This leads me to thinking it's the timer. (and yep I checked the fuse. dryer works fine.) Thoughts?
  • Frigidaire Master
  • 15,639 Answers
The valve is the best place to start looking, you should get a meter to measure voltage and ohms. There is nol guarantee that the valve you used is the right wattage so it is of no help.
Posted on Mar 22, 2014
  • 37 Answers
SOURCE: Frigidaire Washer/dryer combo
Dtronics,
A part called a (wig-wag) its a part that consists of two selonoids, one is bad. It switches the transmission from the wash cycle to the spin cycle,at the same time it opens the pump for draining.
hope this is helpful
handiman518
Posted on Jan 17, 2008
  • 25 Answers
SOURCE: Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Posted on Jul 20, 2008
huuum
  • 750 Answers
SOURCE: frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Posted on Dec 05, 2008
  • 50 Answers
SOURCE: Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Posted on Feb 26, 2009
  • 8 Answers
SOURCE: Frigidaire Affinity ATF6000FS1 model I recently
E20 means clogged drain pump, slow drain . What you need to do is to remove the screws on the back that holds down the top panel and slide it back to remove then the 5 screws on the Ctr panel and pull that off and then remove the spring around the door seal on the front panel and remove the 4 screws on the bottom of the front panel and then the 2 screws for the Door catch on the front and then the 3 or 4 screws on the top part of the front panel to removed the front panel then underneath you will see a black rubber flexible hose coming off the tub loosen the ring clamp at the top of the hose with a Phillip screwdriver and reach in the hose and grab the filter on clean it out and reinstall and put everything back together and you should be all set
Posted on Feb 02, 2011
Frigidaire fex831fs2 stackable dryer takes too long to dry and leaves clothes damp
Good Afternoon Famties4,
I understand that the dryer portion of your laundry center, model#FEX831FS2, takes too long to dry, even after making sure the vents are clear. First, I suggest checking the exhaust duct, making sure it is at least 4 inches in diameter and made of rigid or flexible metal. Secondly, make sure the duct has no more than two 90 degree bends and must not exceed length listed in the INSTALLATION INSTRUCTIONS. Lastly, make sure your dryer is connected to a 240 volt circuit. Drying time will be 20% longer than drying on a 240 volt circuit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
May 17, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
What's the resistance value in stackable dryer motor model fex831fs2?
There should be some for both the motor and the heater coil. Don't know how much don't have schematic. Hope this helps
May 18, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
Dryer hot but not drying quickly.
Sounds like you have a clogged vent. Hopefully you've gotten this repaired.
Feb 25, 2012 | Frigidaire Washing Machines
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Washer wont start
unplug from the wall and count to 10 and then plug is back in. If that doesn't work, you need a service call.
Jul 05, 2017 | Frigidaire ATF6000ES Front Load Washer
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831F Top Load Stacked Washer / Dryer Logo
59 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
