Question about C3RS915 SST Remote Car Start Vehicle Security System with 2way L
RS 915 says ot of range
The remote works....it just says out of range and will not give me an indication on the screen
    Problem Solver:
  • 5 Answers
The antenna could be loose either on the transmitter from your vehicle or the antenna on your remote.
Posted on Mar 28, 2014
What rs remotes will work with a rca rs2610 book shelf stereo?
Remotes.com has a replacement remote that will work here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=+rs2610&uuid=14001121456810 . The original remote has the part number: ZA90459 . If you can find this remote, it would work. The other models of RCA RS stereo remotes won't work.
I hope this helps.
May 14, 2014 | RCA Televison & Video
Indicates "waiting" and will not show menu
try turning off rs system turn off pda turn rs system back on then turn on pda reboot
Oct 03, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
The remote just says set 2 and does nothing
Does the TV screen say Set 2 or the display area on the DVD recorder? The original remote for the DMR-ES35VS doesn't have a screen. (If you are using a universal remote, I'm not sure how to reset the unit.)
The Set 2 indicates that the unit was set to listen to a remote on the second wavelength available on these remotes. Your remote needs to be set to the same wavelength. Press and hold Enter and then press and hold 2 (for about 2 seconds) on the remote to set it to this option. Press Return to move back through the menu or exit the screen. (Panasonic provided this feature for those with several devices so that each remote wouldn't control a nearby device at that frequency.) To get the recorder to respond to the remote, they must be set to the same range. To check, press the Functions button. Under Other Functions > Setup > Remote Control Code, you can adjust the wavelength that the receiver is looking for. (Use the up/down arrows to select a sub-menu and the Enter key to enter the sub-menu. Use the left/right arrows to select options in the secondary menu.) If the unit doesn't respond, try a different wavelength. (Press and hold Enter and then press 1 or 3. There are only three possible options for the remote/receiver.)
For a screen capture of this, see page 19 of the manual; it is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRES35V.pdf . An original remote is available from Remotes.com: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DMR-ES35VS&uuid=13262363222670 . It probably comes pre-programmed for Remote Code 1.
I hope this helps.
Jan 10, 2012 | Panasonic DMR-ES35VS
Aeg b5741-14 oven has code f5 -what does this mean?
Here is a list of oven error codes for your model Kenmore oven.
  1. F0 indicates a Stuck key pad.
  2. F1 and F7 may mean relay is turned on.
  3. F2 indicates that the oven is over temperature in one of the following modes within either cooking or cleaning mode of operation. The control is sensing over 615 degrees with the door lock circuit in the unlock mode. Control senses oven temperature above 915 degrees with the door in the locked mode.
  4. F3 and F4 indicates an open or shorted oven sensor or sensor circuit.
  5. F5 indicates a loss of relay drive circuit.
  6. FF indicates a loss of door motor safety switch.
  7. FC indicates a door lock circuit problem.
If the display of your control is flashing "F" followed by a number or letter its a range malfunction. Press the clear/off pad. Let the range cool for 1 hour and place the range back into operation.
If the problem repeats, call for service.
Jul 16, 2011 | AEG B5741-4 Electric Single Oven
I lost the remote and cant change my speaker settings on my coby dvd 915
Unfortunately, you'll need a new remote. Try a universal if you have one. If not, might just buy a new remote. eBay has a bunch listed cheap enough. Just search the model number of the remote for your system. I was able to find this remote, although $20, a universal MAY work and cost less. make sure you can return any universal you do buy in case you can't return it. Although for the dvd-925 system, the remote looks exactly like the one show in the manual for you dvd-915 model. Hope this helps.
http://cgi.ebay.com/COBY-DVD-925-REMOTE-CONTROL-/120691246947?pt=LH_DefaultDomain_0&hash=item1c19c24763
Mar 27, 2011 | Coby DVD-915 System
Heater is off-line
If you are talking about the RS Online indicator, this just means you are not hooked up to a "RS Control system" aka remote sensor or control. Does the heater work?
Jul 12, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
It shows an error reading indicating to switch off . But it does ot work. When i go to click, ther is an indicator Busy odesilva@hotmail.com
This usually means the lens is jammed in some way. Lens repairs can range from $180 - $$$ depending on the original selling price of the camera. Contact Canon for a reputable service company.
Mar 20, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
Sportline 915 heart rate watch 2nd mode questions
the number is for your age, the F or M is for female or male. this will give a more accurate percentage for your heartrate
Jan 12, 2010 | Sportline Watches
C3RS915 SST Remote Car Start Vehicle Security System with 2way L Logo
63 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
