Question about U-Line Refrigerators
Beverage refrigerator freezes cans
Temperature is set at 38 but cans keep freezing and exploding
  • 3 Answers
The "Setting" is only a guide. Use a refridge thermometer and set at approx 40/50 degree.
Posted on Mar 22, 2014
fridgetech
  • 473 Answers
SOURCE: food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Posted on Oct 14, 2007
  • 29 Answers
SOURCE: Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Posted on Jan 28, 2008
SOURCE: The refrigerator temperature keeps dropping
I had the same problem with my GE GSS25LGMB and after some googling I learned that the damper door might be broken. Indeed after I took off the damper assembly the door appeared to be broken at the hinge. This door has its own thermostat and controls the influx of cold air into the fridge which explains the frozen food. I am trying to glue the broken piece back on. See if it works. Othwersie you'll have to replace the entire damper assembly which costs about $91. (http://www.pcappliancerepair.com/cgi-bin/detail.cgi?item=WR49X10091&brand=GEH)
Posted on Apr 28, 2009
  • 10865 Answers
SOURCE: refrigerator gets too cold and freezes all the food
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Posted on May 26, 2009
  • 27 Answers
SOURCE: danby freezes all beverages
check position of thermistat bulb it should be on the plate
Posted on Jul 29, 2009
Cooler keeps freezing product
You killed the messenger! The refrigerant charge is probably the problem. The thermostat senses the coil temperature and not the cabinet temperature. If somebody put gas in it, the gas has to be removed, a vacuum drawn on the system and then the refrigerant charge weighed in by the ounce. It takes a critical charge and needs to be weighed in by an accurate scale that weighs in ounces. Hope this helps and good luck.
Jul 17, 2014 | Beverage-Air MT27 Beverage Cooler...
Refrigerator become freezing
If the temperature control adjustment wont warm it up my guess is that someone has been on the system with gauges and the refrigerant charge is wrong. Make sure the temperature sensor is attached securely and properly placed. The refrigerant charge is critical and if it isn't weighed in by the ounce exactly it will freeze.
Temperature control measures coil temperature not cabinet temperature. Hope this helps and good luck.
Feb 25, 2014 | Beverage-Air DP93 Refrigerator
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
What is the temperature for the thermostat settings?
i usually set mine at 38 or 40 that way things wont freeze but stay cold.
Dec 17, 2010 | Beverage-Air MT27 Beverage Cooler...
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
LG LFX25960ST refrigerator food freezing above the pantry draw. Made all the tempature adjustments and still happening.
I have the same problem and I know the solution.
For LG to get their "in the door icemaker" to work, they have to blow cold air into the door's icemaker compartment. This air travels through two vents located just inside the refrigerator on the left side. The problem LG has is that the seals between the door and the refrigerator for these vents leak. This means that cold air is vented into the refrigerator compartment. Any sensitive food placed on the bottom two shelf on the left side will freeze. I can place two bowls of water in my refrigerator and make ice in 6 hours, even though the refrigerator is set to 38 degrees. The good thing is that LG knows there is a design problem and they know they can not fix it. After calling LG repairmen out for my freezing problem and not getting the seals fixed, LG gave up. Of course LG will try replacing the seals, and then replacing the door; but the real problem is a bad seal design. Just keep putting bowls in your refrigerator and as long as they continue to freeze up, keep calling LG back and demand that they fix the problem. LG can not fix the problem because it is a bad design, so now I am getting a new refrigerator Model LFX 29927, which is better and has dual icemakers. If you an LG refrigerator with their in the door icemaker, place two bowls of water inside the refrigerator, and if your seals are bad and they freeze; complain to LG until they give you a new refrigerator.
Nov 10, 2009 | LG LFX25960ST Stainless Steel French Door...
The beverages in my True refrigerator are frozen
Definitely a thermostat problem. Make sure that it is set on #3, make sure you have something in the box to provide a constant load (if you are worried about product freezing just put several gallons containers of water in there), set a thermometer on a shelf and let it run for several hours. Temperature should run 35-40f If it still freezes I recommend changing the thermostat. Not the easiest job on a True but the only real option. If it is too warm then raise the setting to #4 and run for several hours more and double check the temperature. It is normal for these box temperatures to "swing" quite a bit especially if empty. The thermostat actually senses coil temperature and not unit air temperature. Typically it cycles off when the coil reaches around 14f and then back on when the coil gets to around 38-40f.
Jul 01, 2009 | True GDM-23FC-RF Refrigerator Commercial
What temp should the fridge and freezer each be?
According to FDA safetey specs bacteria can grow at 40 to 140 F degrees .Refrigeration must be below this number but above 32F to keep from freezing. I maintain commercial refrigeration and they run at 34 to 38 F degrees. I have deep freeze set at -10F which keeps ice cream very solid but can go up to +2 F which renders softer ice cream...
Jun 25, 2009 | Kenmore 64802 Top Freezer Refrigerator
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
True freezer gdm 35f to cold
you just have to change the temperature control. I recommend using a white rodgers part no. 1609-105 set the cut out to about 33 cut in at 38 or 39 you might have to set defrost time to less minutes about 5 or 6 if coils dosent frezze with the setting i gave you. the bulb of the temperature control can be placed on the border dof the difusser.
Apr 14, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Refrigerators Logo
62 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
