Question about Water Heaters
Oil furnace only produces cool water intermittedly and only when heat is actively on
If furnace not actively running to produce heat it does not produce hot water for a shower. I do not have hard water but the furnace is 14 years old. Could the furnace hot water tank heating element need to be cleaned???? What other things could be wrong????? thankyou for your help. I do get my furnace serviced every year.
    Novelist:
  • 83 Answers
For clarity, a Furnace produces HOT AIR for heat while a boiler produces HOT WATER for heat. Just remember...boil = water. You said your "furnace" does not produce hot water for a shower and because furnaces do not product hot water unless they have some model that do???? Usually people with a furnace have a seperate hot water heater. People with boilers though can produce hot water for use as both their sinks/showers hot water and their heat (by heating water that goes through baseboards) in their house. I don't believe any furnaces produce hot water most of the time a furnace just produces hot air for heating. So figure out what you first have.
Having said that, I'll assume you have a boiler like I do and my Weil McClean(sp?) stopped working a while back and wasn't turning on to "boil" any water. I took apart the burner and there is a light sensing photo resistor as part of the controls. If this phto resistor goes bad, the boiler will not start. The resister is cheap, I think it was $8 but you have to know what you're doing to change it. So you may be better to call someone who can work on such equipment.
Boiler's themselves are not overly complex. Home heating oil is the same diesel fuel that you can buy in a gas station only the government has "oil" companies put a RED die in home heating fuel which is usually cheaper then Diesel fuel because diesel fuel is taxed to death. The reason they do that is so that if you try putting RED tinted home heating fuel in your truck and you get pulled over (because you're a trucker with and 18 wheeler and they typically do inspections of these trucks) you will be a huge fine if they see you're running home heating fuel and NOT paying your taxed by purchasing Diesel fuel. A little bit of background so you know the fuel you are dealing with here. So it's dieslel fuel without the tax you run in your boiler. Gasoline on the other hand is VERY explosive as you know, but diesel fuel (if you're ever tried to light it) takes some coaxing to get lit. When it's cold out, diesel fuel is very hard to light and that's why trucks use glow plugs. You don't need those in your home though.
But because diesel fuel/home heating oil is hard to light, it's sprayed as a msit into your boiler, so that it can light more easily.
But because it is a fuel, you should know what you're doing when messing with it. FInd out what you have, and then have someone work on the issue if you haven't already. I'm guessing you have had it fixed by now?
Posted on Jun 29, 2014
motor1258
  • 6674 Answers
SOURCE: I have a GSW Series 5 water heater (electric). I
It may be one of 2 elements not working, a thermostat problem, scale build up in tank, to name a few possibilities. You'll need to shut off power to water heater before doing anything to it, and perform a few tests, and check a few things to determine which one is the cause. After power is off, you remove cover(s) on side of tank and peel back the insulation to get access to element(s). Keep in mind that should you need to change one of the elements, or both (assuming it has 2 otherwise you wouldn't have any hot water at all if only 1 element and not working.) This is where it would be good to have a voltage meter ( or multimeter ) and know how to use it. Is that possible? Before you reply, please shut off power and remove cover(s) to be sure whether single or dual element. If it's single, it may just be thermostat adjustment, or faulty, or scale build up around element. Keep in mind that water to tank will need to be shut off and tank drained down below element before removing/replacing. Get back to me with info on single or dual element. Thanks
Posted on Jan 10, 2011
  • 104 Answers
SOURCE: Combi Boiler - Running warm & then cold!? HELP!
mixing valve must be replaced
Posted on Nov 02, 2008
  • 9 Answers
SOURCE: 12-year old Rheem residential single-thermostat
TIME TO REPLACE TODAYS ARE MORE EFFICIENT
Posted on Sep 08, 2009
rick_stokes_
  • 61 Answers
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Posted on Sep 19, 2009
  • 193 Answers
SOURCE: Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Posted on Apr 21, 2010
Testimonial: "It is very good advice. I bought a tester to check out both upper and lowre thermostat and heating element; I've replaced the lower heating element "
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
Feb 14, 2015 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
No running hot water in house.
These have a photoelectric eye , much the same as a motion sensor on an outside lamp, just pull this out, clean with a wet wipe, dry with a towel & replace, press the reset switch & your boiler should fire up producing lovely hot water
Nov 11, 2014 | American Standard 3-pass Oil-fired Boiler...
I just had my furnace cleaned it is a gas rheem. The service guy said it was overheated because of a#3 tube he said the furnace heat exchange is black. What can be do regarding this
I presume you're talking about a gas furnace, even tho the title says Rheem gas water heater. Either way, it works the same for both.
Any black coloring on the heat exchanger is *not* from overheating. Black is from a sooty flame caused by a mis-adjusted burner. (In fact, a sooty flame is less hot). There is an adjustable "air intake plate" for air to enter the burner where the gas enters the burner. A proper flame is made by adjusting this air opening so the proper gas/air mixture feeds into the burner. If the air vent is closed too much it produces a sooty flame.
The age of the furnace is the most important aspect, and that helpful to determine a likely condition of the heat exchanger and burners. Other than a badly adjusted flame, the main thing to watch for is a badly rusted out heat exchanger. But black does not mean rust.
Oct 28, 2014 | Rheem 50 Gallon FVR NATGAS Water Heater...
How do i get even heat thru out the house with a daka wood stove
http://www.hearth.com/talk/categories/main-hearth-forums.4/
You burn wood, and smoke goes up flueway.
You're not running chimney smoke through ductwork so you have a heat exchanger.
What kind of heat exchanger?
probably air since you're running through ductwork?
How much hot air or hot water is coming off heat exchanger?
How big of a space can be heated with that amount of heat?
Is the exchanger located in optimal location?
Considerations.
One room log cabin with fireplace will not stay very warm.
One room house with big wood burning stove in center, with hot flue pipe running across the room and exiting on far wall, will get warm-hot, but will cool off fast.
Why?
Because the BTU output of firewood is much less than electric, coal, oil, or gas.
Otherwise they would have made wood-burning steam locomotives. But the locomotive boiler cannot get hot enough with wood ... the boiler needs coal to produce enough BTUs to boil water fast enough to rotate the turbine and turn the wheels.
Maybe your wood stove output should be measured.
Don't forget a huge percentage of fire heat goes straight up flueway.
Mar 16, 2013 | Lux Tx500 Series Smart Temp Electronic...
Atwood gc10a-4e only producing luke warm water
make sure bypass on back isn't open or half open then see if mixing valve on shower or outside shower off if all ok possible bad temp sensor
Feb 19, 2013 | Atwood Mobile Products Atwood 10 Gallon...
What is the gray gravely discharge coming from my PowerStar AE125 when using the hot water? It plugs up the faucet and shower heads within minutes and almost completely blocks the water flow.
Heating water can peculate chemicals out of water, such as metals and organics.
Especially above 138 degrees.
Have well water tested.
Turn down thermostat temperature.
Or reasonably harmless well-water bacteria can react with anode rod, or other reaction in softener, to produce colored water, and smells.
Different water can produce different sludges, brown, red, gray, black, yellow.
The sludge can also combine with deteriorating pipe flakes to clog water flow.
Sludge can accumulate over years in low spots in pipes, or at elbows and constrictions.
Have plumber flush pipes.
Or run new pipes.
Also delime tankless yearly, and flush with white vinegar as shown in product manual, and treat bacteria with H2O2 hydrogen peroxide.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Oct 29, 2012 | Bosch PowerStar AE125 AE125 Whole House...
Pilot light lights but goes out when i turn valve to on
Near the pilot there should be a small metal bulb at the end of what looks like a wire which leads back to the control valve. It's called a thermocouple and it produces a small electrical current when heated. Non-electric heating units have a similar device which does the same job using pressure produced by heating a fluid within the bulb but for our purposes here the difference between the two doesn't matter. The function of the thermocouple is to hold the gas valve open for normal operation of the pilot. If the pilot flame goes out the thermocouple cools and disables the valve so that when the thermostat calls for heat, the gas will not be released if there is no pilot to light the burner. Check to make sure the bulb is being heated by the pilot flame, it may need to be repositioned or the pilot may need to be cleaned of carbon buildup to make it produce an adequate flame. If the thermocouple is close enough to an adequate pilot flame and still you cannot sustain the pilot flame when going from "pilot" to "on" position, the thermocouple is probably the problem so replace it. If the problem still exists, assuming you have already made certain that you have an adequate fuel supply, the problem is in the burner control valve. Changing that is something you should consider leaving to a qualified service person.
Jun 30, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a Heatslave 12/14 oil-fired combi boiler installed approx 8 years ago. A problem has just developed on the domestic hot water side. My local heating engineer has investigated but so far hasn't...
Symptoms sound like crossover might be part of problem:
Crossover is when cold water enters hot water line due to faulty plumbing part like check valve, mixing valve, or bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
Jun 12, 2011 | Bosch Water Heaters
Water Heaters Logo
104 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
