Question about Samsung NP365E5C 15.6"" LED Notebook - AMD A-Series 2.50GHz
How do I connect samsung np365e5c to hw191d
Connect notebook to computer monitor a Hanns.G hw191d using a VGA 15-pin cable failed
    Top Expert:
  • Samsung Master
  • 21,338 Answers
Did you enable the external monitor?
Posted on Mar 22, 2014
I have a hanns.g hw191d monitor which has vga and dvi, how do i switch between the two
Generally speaking this monitor will start up in "auto" mode which will detect which in put has a signal and select that input. If you have both cables connected and active, hit the menu buton and scroll down to select the input.
Dan
Jan 27, 2011 | Audio Players & Recorders
No video signal, says my HannsG HW191D LCD monitor
This message occurs when the signal from the computer is absent, as in the computer is shut down or the cable is unplugged etc.
Apr 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
My Hanns-G hw191d monitor quit coming on. The green light at the side is on, indicating that it is receiving signal from the computer, but nothing displays on the screen. Is there a fix, or should I just...
First, flip the switch for your power surge protector, to see if that resolves. Then, test the monitor on another computer and see if it works. If the monitor still doesn't work, look for another one. Hope that helps.
Jul 06, 2009 | Hannspree HW191D LCD Monitor
I am unable to connect my IBM Think Pad Laptop to samsung 37lcd
you should be configure the display option , as extended monitor (2nd) output ,
Feb 24, 2009 | InFocus VGA Cable - 15 pin male-male, 4...
HOW TO CONNECT SAMSUNG LCD TV TO ACER ASPIRE
Atlast I got some help from the right people (Samsung)! I would like to share it with others facing the same problem:
If you are using the D-sub 15 pin jack (VGA Monitor Cable: make sure its 15 pin and NOT 14 pins), follow these steps:
  1. Make sure your TV and computer are off.
  2. Using a 15 pin D-sub (standard) video cable, connect the Video Out jack on your computer's video card to the PC In jack on the back of your TV.
  3. Using an audio cable with a min-stereo plug on one end and two RCA jacks on the other, connect the Audio Out jack on your computer to the left and right PC Audio In jacks on your TV. (Note: If you have your computer connected to separate speakers, you can skip this step)
  4. Switch on the Notebook and Adjust the Resolution (800 x 600 pixels would do). You can go to Control Panel and Adjust the screen resolution. (Keep ‘Screen Refresh rate’ at 60hz in the Monitor Settings)
  5. Switch on the TV and try to Select the Source as 'PC' (you can do this by either pressing the 'Source' button several times on your TV remote or go to the Menu - Setup and Select the 'PC' as source there).
  6. In most cases, after following the above steps, the TV would start to show 'Auto Adjusting' message and it will start showing your Desk top on the TV. But incase it doesn't work, you can do the following:
a. Mostly the problem lies with the VGA cable. Make sure you have the right one (15 pin) and its securely attached at both ends. If you are not using the right VGA Cable, it means that there is no connection between your TV and Notebook. Your TV will show 'PC' in Grey in the Source Input list (Go to ‘Menu’ from the TV remote).
b. Both your Notebook and TV should be switched off when you are connecting the cable otherwise one of them might have a problem detecting the other one.
c. Try Pressing Fn + F5, F6, F7 (depends on which Notebook brand you are using) on your Notebook several times. At times, you will see some signs that the Notebook and TV are trying to connect. Select 'CRT' from list of displays available to you.
May 09, 2008 | Televison & Video
LCD Monitor
Mine had the same problem. Sometimes it worked, sometimes it didnt. It really annoyed me. I tested my PC on another monitor, it was fine. I checked my monitor on another PC, it worked fine. We eventually found out it was just the VGA cable. So i would advise just trying another VGA or DVI cable and see if it works.
Hope this helps. Good Luck
Mar 04, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Connection problems??
Check all power connections and surge arrestors to the ON position. Or if possible, try hooking up the monitor to a different source. You can use for instance, a laptop, some dvd players using s-video, etc. If the monitor works, then try a different video card. When buying components for assembly at home, it's not uncommon for them to arrive unoperational or DOA. Use a reputable dealer that has a good return policy. Hope this helps.
Feb 24, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Samsung NP365E5C 15.6"" LED Notebook - AMD A-Series 2.50GHz Logo
42 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
