Question about Electrical Supplies
Power to fan pulses and other out lets on that line are out
That's all
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
This plug could be faulty or has to much plugged in at once but it could even be a bad ground or motor check the wiring to make sure nothing is loose or grounding out also shut off the power from the breaker box to that aeria and take out the outlet to see if the outlet is bad or loose and put it all back together and see what happens from there
Posted on Mar 23, 2014
Toshiba model 62MX196 t.v. 62 inch rear projection...turns on then goes black and mute after 5 secs then red led continually blinks. Unplugging and rebooting power button causes a voice to say "fan st
I'M ASSUMING THIS IS A DLP? IF SO "ANY"
I REPEAT IF ANY OF THE FANS ARE SEIZED OR DRAGGING
SLOWER THAN THEY ARE SUPPOSED TO
IT WILL SHUT DOWN THE Tv!!!!! EVERYTIME AND THAT GOES FOR ALL OTHER DLP/LCD PROJECTION AS WELL!
BY DESIGN THEY DEPEND ON THOSE FANS, WITHOUT THEM THEY WILL BURN UP THE PARTS THAT THEY ARE ASSIGNED TO COOL. THE 3rd WIRE ON THE FAN PLUG SENDS A PULSE EVERYTIME THE FAN COMPLETES A 360 degree REVOLUTION, TO A CIRCUIT THAT MONITORS IT.
Nov 15, 2013 | Toshiba 46H84 46" Rear Projection...
How do i find out if a injector is gone on my 1990 neisan 300 zx tt
get a NOID light and plug in line with the injector or the new power probe that will let you get close to read the magnetic pulses without disconnecting.
Sep 16, 2012 | Cars & Trucks
I have 5 Hampton Bay ceiling fans originally installed in my 2001 home. 3 have light kits and work great. I am trying to install lights on the remaining 2 but get no power. The 2 wires (blue and white)...
The supply power to the fan from the house should be HOT 24 / 7. The two lines going to the fan normally have wire nuts for connecting the leads on the fan to the house power supply line and the house common line. You want to tie the blue line on the light into the same wire nut that goes to the Fan switch. White is COMMON. Just add the lights COMMON (White) line to the wire nut that has the other two white lines in it. The blue goes to the Power line from the house. Add it to the BLACK (HOT) lines wire nut that has the fans wire in it. Use your meter to be sure of what color is common and witch is hot. If you have any trouble, let me know in detail what all the colors are from the house, fan and light. I'll put it in order for you. thank you. Please vote. Roger
Apr 14, 2011 | Hampton Bay Heating & Cooling
What is principle behind pulse dialling mode & tone dialling mode in technical terms
Pulse dialing is a holdover from Rotary phones, which when the rotor is turned and let go, counts out the number you entered in clicks on the telephone line. Pulse, or DTMF (Dual-tone multi-frequency), uses two overlaid tones (one for row and one for column) to signify a button press.
DTMF frequencies:
http://en.wikipedia.org/wiki/Telephone_keypad
Mar 19, 2011 | Cell Phones
Hello, I just installed the Maestro Fan/Light switch (MA-LFQHW) to my cieling fan/light. The fan works perfectly however, the light after a moment or two will start to pulse (dim) then return to normal....
Thank you for including the Manufacturer, Model and Model number
Lutron makes a long list of products.
I found the product manual at Lutron: and am looking at the instructions
http://www.lutron.com/TechnicalDocumentLibrary/033100b.pdf
The Lutron device replaces an ordinary single pole switch.
It is not made to control compact florescent bulbs, just incandescent bulbs.
The switch has to have a ground wire.
Lutron tech assistance 1-800-523-9466 (included just in case I cannot find the trouble)
Troubleshooting in manual: They mention 'upper LED on wall control cycle rapidly.'
The solution is to check wiring, which we will review.
The fan and lights are supposed to be on high (this means your pull chain controls located on fan)
Let's review the wiring.
The switch wires connect to either brass screw.
The switch wires are usually black. Let's say they are black.
One of the black switch wires travels to fan in a cable.
This cable has 2 wires: a black and white.
This cable goes to fan.
The black wire carries power to the fan.
The power wire, or Hot wire from switch connects to the Module-black wire.
The Module-white wire connects to the Neutrals (which are white and usually twisted together and covered with a wire nut).
So all your Neutrals are joined together and covered with wire nut.
The Module-red wire connects to light-wire
The Module-yellow wire connects to fan-wire.
I'm looking at this wiring and it seems so straightforward, I can't find a problem.
According to the troubleshoot, the fan could NOT work properly if the wires were reversed at the Module.
The switch wires connect to either terminals, so there's no confusion there.
1) Unless you forgot the ground wire, or 2) you're using compact florescent bulbs, or 3) the light is not on high, I can't see where the problem is.
I suggest you call the Lutron tech support number.
They may suggest a circuit analyzer, for example a small voltage ground fault in the line might affect their device.
In any case, I want to know how this turns out because I specialize in electrical devices.
Add a comment and keep me updated.
Nov 05, 2010 | Lutron Electrical Supplies
Sound is pulsing.
You probably have the power bar thing too close to the sub woofer, this will cause a pulsing sound! :D
Apr 04, 2009 | Creative Labs I-Trigue 2.1 3300 Computer...
Sportline pulse rate watch
Have you tried looking up the instructions on line? Sometimes you have to hold down the buttons for a few seconds (up to 5). Do you see any wording around the edging like "mode" , "adjust" sometimes they are hard to see. Try this and if you still have problems PLEASE let me know I will research this further for you.
Aug 04, 2008 | Watches
GE 29439GE2
Copy directly from the manual: TONE/PULSE Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which type of service you have (pulse or tone), check with your phone company. To program TONE/PULSE for all 3 lines: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press TONE To program TONE/PULSE for each line individually: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press LOWER 5. Press line number (1, 2, or 3)
Jan 11, 2007 | GE 29439GE2 Corded Phone
Electrical Supplies Logo
48 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
