Question about Maytag MER5765RAW / MER5765RAQ / MER5765RAB Electric Kitchen Range
Range over door does not close tight
Door is open more on one side than the other and when using self clean the door turned yellow/brown at the top
josh1856
  • 105 Answers
SOURCE: Admiral electric range with self cleaning oven
There is an automatic lock feature on this unit that after 1 hour will unlock itself.
hope that helps!
Posted on Jan 30, 2008
  • 409 Answers
SOURCE: self cleaning gemini electric range with no maual
hi there,
can you tell me the complete model # please? i will look for the use and care guide.
thanks
Posted on Sep 26, 2008
huuum
  • 750 Answers
SOURCE: KITCHEN RANGE
Hello r-stamper,
Welcome to Fixya,
You said, SELF CLEANING NOW DOOR WILL NOT OPEN
Lets try to reset the system.
Turn off the range.
Now throw the breaker in the electric box off for 5 minutes.
After waiting 5 minutes turn the power on and try the range!
If there is a cancel or release button you may have to hold this in firmly for 3 seconds.
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Posted on Oct 06, 2008
SOURCE: locked door
try unplugging the stove and plug it back, that release the door on many of those models.
Posted on Dec 12, 2008
EllaWatson25
  • 725 Answers
SOURCE: after the self cleaning process the door open up
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Posted on Mar 11, 2010
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I have a tappan millennia range, self cleaning- somehow it is locked, and it is open, tried to unplug it, but didn't work. How do I get it unlocked?
lift up the top and in the left hand side at the back is a cam assembly the locks the door, using a phillips head screwdriver, unlock the cam and turn it manually, this will move the arm that handles locking. after you get the door open, leave it open so you can play with the locking mechanism because you have to shut off that damn blinking light, then relock the cam and close the top.
Jan 18, 2011 | Kitchen Ranges
The door has turned brown around the top after 2 uses in 5 years of the self cleaning process. How do I clean that off or can it be? Is it possible to replace the door on the stove?
You can easily clean it with easyoff oven cleaner available at most grocery stores.. Yes you can replace the door but the cost would be prohibitive.
Jun 29, 2010 | GE 30" Self-Cleaning Freestanding Electric...
Ranges self cleaning instructions
Hi
An oven is a standard piece of equipment in the kitchen of a home or apartment. Often, the original instructions for operating and cleaning the oven have been lost or are not included with the lease of an apartment or purchase of a pre-owned home. To get the most use out of your oven and keep it functioning properly, it is important to know how to use it.
Adjust the racks to the desired position. Some Frigidaire models feature heating elements on the top of the oven while others are located on the bottom. Generally, moving your dish farther away from the heating source will result in a slower cooking time or reduced browning. Choose the desired oven temperature and set by turning the temperature knob or manual punching in the numbers followed by the "Enter" or "Start" button. Allow the oven to pre-heat before placing dishes into the oven to bake.
How to use..
Open the door while standing to the side of the oven. Standing directly in front can result in burns from the hot air. Wearing a dry oven mitt, place pans onto the desired oven rack. If baking more than one dish, stagger the pans on different racks, so that one is not directly on top of the other. This will help ensure even heating. Close the door and set the timer, using the numeric key pad or up-and-down arrows followed by the "Start" or "Enter" button. If you want to encourage additional browning on top of the dish, set the oven to "Broil" after the dish has cooked through. Monitor the dish carefully, as food can burn quickly. Remove the dish when completed using dry oven mitts, and turn off the oven.
How to Clean..
Do not attempt to clean the oven until it has cooled completely. The oven's exterior and the interior frame can be cleaned using a sponge dampened with hot water and dish detergent. The glass portion of the door may be cleaned with paper towels and glass cleaner. For ease of cleaning, wipe spills as soon as possible after they occur. Wait until the oven has cooled and then clean using the sponge method. If this does not work, a spray-on oven cleaner can be used, according to the manufacturer's directions for a manual cleaning oven, or for a self-cleaning oven, push the self-cleaning button and allow the oven to cycle through the automatic cleaning, usually about 1 hour. Never scrub the rubber seal around the over door, as this can lead to deterioration and prevent the oven from sealing properly.
hope you will be helpfull
Thanks for contacting Fixya.com
Sep 09, 2009 | Kitchen Ranges
Self-cleaning oven door won't open
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 15, 2009 | Ovens
Door won't open after cleaning
After self cleaning the range the door won't open....
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Apr 01, 2009 | GE Kitchen Ranges
Self-cleaning leaves a brown stain on the white part on my oven
Perhaps the door gasket is not sealing well enough. In self clean mode the oven get very hot and vaporizes the fat off the sides. With a leak I think some of the fat is redepositing on on the outside where the leak is. You may need a new door seal.
Jan 30, 2009 | GE 30" Self-Cleaning Freestanding Electric...
My rf367 range gets so hot during the self cleaning cycle that the top of the range is to hot to touch and the fan on my otr microwave comes on.
Normal operation. If in doubt place a high temp theromoter on range top to see if it exceeds 600-900 degrees
The basic idea is "burn baby, burn!" Self-cleaning ovens use an approximately 900 degrees Fahrenheit (482 degrees Celsius) temperature cycle to burn off spills leftover from baking, without the use of any chemicals. A self-cleaning oven is designed with a mechanical interlock (patented in 1982) to keep the oven door locked and closed during and soon after the high-temperature cleaning cycle, which can be approximately three hours. The door stays locked to prevent burn injuries. You can open the oven door after the oven cools to approximately 600 F (315 C).
Dec 14, 2008 | Whirlpool Kitchen Ranges
Top of oven door is turning brown
DeBruce Polish will remove these problems on both stainless steel and enamel finishes. DeBruce Polish also works wonderfully on ceramic cook tops. DeBruce Polish is non-toxic, odor-less and non--abrasive, a true eco-friendly multi-surface cleaner. We get DeBruce Polish at debrucepolish.com.
Nov 22, 2008 | GE Profile 30" Self-Cleaning Freestanding...
Self clean oven door lock will not unlock accidentally pushed clean button, cancelled clean but oven door will not unlock. it's been two days now.... what should i do? tried unplugging unit, that...
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
Sep 09, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Maytag MER5765RAW / MER5765RAQ / MER5765RAB Electric Kitchen Range Logo
22 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
