Question about Samsung Galaxy S GTI9000 Smartphone
Charging problem My Samsung galaxy 1.It is dead when i plug it in and hold own the power button some times the phone turns on but sometimes it doesn't if u leave it alone plugged in for a few minutes it turns on. What do u think my problem is and what is the solution"
    Master:
  • Samsung Master
  • 561 Answers
It looks like it's quite discharged
Posted on Jul 28, 2014
270rexton
  • 762 Answers
SOURCE: samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Posted on Jul 16, 2009
mmnhltm
  • 695 Answers
SOURCE: my samsung corby plus wont
Its a problem in the Power Button
It may be stuck ,it needs to be released,try to release it by some pin ,if you couldnt ,you need to send it to a repair store.
Posted on Jun 01, 2011
  • 63 Answers
SOURCE: My Samsung galaxy s2 is just dead it doesn't even charge hw do I get it wrk
HI DEAR
IF YOUR S2 IS DEAD THEN IT MAY BE DUE TO 2 CONDITIONS
SOFTWARE: IF YOU WERE TRYING TO FLASH IT WITH CUSTOM ROMS OR IF YOU WERE UPDATING THE FIRMWARE AND THE THE PHONE DRAINED THE BATTERY IN BETWEEN THEN PROBABLY YOUR PHONE BOOT AREA HAS BEEN DAMAGED.IN THIS CASE IT CAN BE REPAIRED BY A PROCESS CALLED RESSURECTION.IT REQUIRES PROFESSIONAL TOOLS LIKE GPG JTAG,RIFF BOX,MEDUSA,ORT JTAG ETC PLUS PROFESIONAL SOLDERING SKILLS.FOR INFO GOOGLE IT WITH ONE OF TOOLS NAME
2)HARDWARE:IN THIS SITUATION YOUR MOBILES PCB HAVE FAULTS LIKE SHORTING,WATER LOGED,DAMAGED CHIPS ETC.IN THIS CASE YOU CAN VISIT HARDWARE REPAIR PERSON/SERVICE CENTER
Posted on Apr 06, 2012
  • 547 Answers
SOURCE: samsung admire shuts off on its own reads 0% when its fully charged
try to buy original battery and original charger, then try again, if problem persist show some oficial repairer maybe it is a charging ic problem due to waterdamage.for further help post comments.
Posted on Jun 28, 2012
Testimonial: "Thank you for your help."
SOURCE: my galaxy always thinks its plugged in to charge
I don't think anyone understands the initial question. The battery is fine and it even charges like it's supposed to. The question here is- how do you get rid of the icon in your notification box that is telling you that your battery is full? It seems to be stuck.
Posted on Jul 04, 2012
My power button is not working my phone was switched off could you pls help me to switch on my phone. power button is not at all working my battery is full and it was switched off.
Sometimes plugging in the phone (into the charger) allows the phone to boot. Maybe your battery is simply empty? Charging the phone is a good idea regardless.
Also, try booting to safe mode to test the power button:
  1. Turn "OFF" the Galaxy S6
  2. Press and hold the Power/Lock button at the same time until you see the "Galaxy S6? logo
  3. When the logo shows up, immediately hold the Volume Down button, while releasing the Power button
  4. Keep holding the Volume Down until your phone finishes rebooting
  5. If it was loaded successful, a "Safe Mode" will show on the bottom left corner of the screen
  6. Let go of the Volume Down button
  7. To exit "Safe Mode" press thePower/Lockkey and then touchRestart
Dec 14, 2015 | Samsung Galaxy S6 Edge
Hello / I have a Galaxy S. I am having problems getting the phone to charge When plugged into the charger, I see the picture/LED of a dead battery and then it blacks out... or I see a picture/LED of a
I have a hard time keeping the cables working. Try changing the cable out. Also try holding the cable and putting slight pressure upwards on the bottom of the connector. The charging symbol has to be on if it is charging.
Feb 08, 2015 | Samsung Galaxy S Cell Phone
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Jan 31, 2015 | Samsung Galaxy Tab Tablet PC
My Samsung Galaxy Infuse won't turn on or charge.... it just keeps flashing the Samsung screen and then the Roger's screen. Is it my phone, or my battery that needs fixing?
Have you tried a hard reboot? Hold down the power button, don't click on anything on that screen that pops up, just keep holding the button down until it reboots on it's own.....
Jan 26, 2015 | Samsung Galaxy S 4G Cell Phone
Im not sure
It's discharged or battery is dead.
Mar 21, 2014 | Samsung Galaxy S GTI9000 Smartphone
I have samsung galaxy I. my phone was turned off and when i turn it on it doesn't start as it stucks on samsung and doesn't start up. i took off the battery off and on but it still not working
hi,
try to hard reset your phone first by doing this procedure...
To Hard Reset Samsung I9000 Galaxy S
1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
2. Hold the Volume Down button
3. Press and release the Power button
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If YES is selected, all data including third-party applications will be deleted from your Samsung I9000 Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
if you do the above procedure and nothings happen ,its time now to re-flash your phone to its original version and a certified mobile technician will do that for you...thanks for trusting fixya
Oct 01, 2012 | Samsung Galaxy S GTI9000 Smartphone
Why Samsung Galaxy S keeps freezing and crashing. Like 5 times a day. Sometimes it is just me wanting to open up a application or just in the middle of texting. What is happening?
You should backup your contacts and perform a reset on the phone.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password, then tap Yes to confirm
If that doesn't work, or if your phone is frozen:
If you selected YES, all data including third-party applications will be deleted from the Samsung Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
Aug 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
How to reset my samsung galaxy
METHOD TO RESET GALAXY
STEP 1: Switch off your phone, remove its battery, and then place it back.
STEP 2: Now, hold the Volume Down button and Power button. And then release the Power button while still holding the Volume Down button.
STEP 3: Now you will get a list of options to choose from. Which would be like:
  • Fastbook
  • Recovery
  • Clear Storage
  • Simlock
STEP 4: There, choose the Clear Storage option.
NOTE: Use Volume UP and Volume Down keys for navigation and Power or Home button for selection.
STEP 5: Now confirm by pressing Volume Up button (YES) or Volume Down (NO).
That is it! Now, you Galaxy S will reboot and you will find that you have reset your Galaxy S to factory settings.
Jun 30, 2011 | Samsung Galaxy S GTI9000 Smartphone
I have been trying to turn on my galaxy tab but it just wont turn on. I have tried charging it for a full day but still nothing. i dont even know if it is charging.
Most likely that it's faulty. Sometimes it takes awhile before it charges itself, specially it you drained. But if you left it plugged in for a day and still nothing happened then I think it's gone dead.
Try the following though and see if it helps.
1. Press and hold the power for about 10-15 seconds. or
2. Press and hold the power and the Volume up or Volume down at the same time for about 10-15 seconds.
If nothing happens then I suggest you send your tab for a repair.
Hope it helps.
Apr 30, 2011 | Samsung Galaxy Tab Tablet PC
Samsung Galaxy S GTI9000 Smartphone Logo
19 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
