Question about Arctic Cat 2009 Bearcat 570 XT
My arctic cat bearcat 570xt 2010 stops when idle running. seems it gets to much fuel? Any suggestions?
The engine runs, but when pulling the throttle, it stops
SOURCE: my arctic cat 400 atv 4x4 auto idles fine but when
Clean carbuator
Posted on Oct 07, 2013
5keepers541
  • 3497 Answers
SOURCE: Arctic cat xtx 700 2010 Jumps when you take off
Clutch wear (springs) or the belt needs replacing.
Posted on Jul 26, 2014
  • 46307 Answers
SOURCE: My 2004 arctic cat pantera starts with the pull cord but not with the electric start. Turn the key and no response whatsoever. Any suggestions?
it could possiblly be the starter has dumped too
Posted on Feb 03, 2015
5keepers541
  • 3497 Answers
SOURCE: 2004 arctic cat 500 4x4 starter turns doesnt engage starts with pull cord
1. Never jump start an ATV, Motorcycle, UTV..etc from a automobile! The amperage is TOO high, you can damage a lot of expensive electrical components!! ..very quickly!
You cannot home trouble shoot without a new battery or fully charged battery with good solid clean connections!!
2. Have the battery tested or simply buy a GOOD new one!
3. Does the starter spin at all? Is there a clicking noise when you push the start button? No - solenoid is bad(?) . you can check this by jumping the two large connectors on the solenoid... A good screwdriver works well...(CAREFUL - SPARKS WILL FLY!) If the starter works while jumping, the solenoid is bad - just replace it (disconnect battery while replacing).
4. If the start spins while "jumping" and nothing happens the starter may need rebuilding if the new battery/fully charged battery/jumping solenoid does not expose/solve the problem.
Do this and repost.
Steve
Posted on Mar 11, 2016
  • 40 Answers
SOURCE: I have a 2005 Arctic Cat 500 that will crank and run great. Push the throttle acts starving for gas. I have replaced the fuel filter, fuel line, and cleaned the tank. Also replaced carb. NEED HELP!
did u buy a used carb to replace old one sounds like the fuel pump/or the pump mech built into the carb also check the jets in the carb make sure there not obstructed in any way.also could try taking float bowl off and make sure the gas is flowing into the bowl like it should couple things to try hope this helps
Posted on May 22, 2016
Testimonial: "The Carb is brand new. I'm thinking it could be electrical because spark plug spark is yellowish, orange."
2010 Ford F150 would suddenly loose power and only idle. Pull over shut off sit a couple minutes crank and run fine for a while then do same thing again. Wrench would show up on instrument panel
Sounds like the catalytic converter or muffler maybe getting plugged up and the computer is putting the truck in limp home mode. Did you put a scanner on the truck. You might try to remove the 02 sensor ahead of the cat and see if it runs a little better it will not be perfect but should stay running if so do an exhaust check. When the cat or muffler gets plugged it puts back pressure on the engine and won't allow the fuel to be pulled into the engine properly.
May 19, 2017 | Ford Cars & Trucks
My 550 arctic cat '2010' hard to start,turns over strong will eventually start idles fine but when throttle is applied it revs up briefly then gags to the point of stall. no codes up
Sounds like a fuel blockage or your fuel pump is worn to the point that it can no longer provide the correct pressure.
May 07, 2017 | ATVs
Starts and idles fine runs half throttle when fuel is applied
Harry, dirty carb or injectors.
Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 06, 2016 | ATVs
2012 arctic cat idles fine but cuts out when given throttle... any ideas?
are the fuel lines clear? also check the float in the carbureter. if it has a hole it will sink causing fuel starvation
Nov 30, 2014 | Arctic Cat 2013 Prowler 700 HDX
2007 arctic cat jag z1 efi. Hard to start, will only run at higher idle. Just had it serviced prior to that. running fine. got it off trailer. idling fine. quit. now won't idle. only runs at higher...
Sounds like you may have gotten some bad fuel.Get the machine in a nice warm garage over night then take a sample off the bottom of the tank. A glass ball jar works great. The water if any will settle to the bottom of the jar. I have pulled quarts of water out of sleds before,believe it or not.
Mar 14, 2014 | Arctic Cat 2007 Jaguar Z1
Engine will not idle, stalls when throttle released
Make sure your drive clutch is disengaging all the way.
Mar 07, 2014 | Arctic Cat 2004 T660 Turbo Touring
Engine runs rough and misses at both idle and accerlation
Water in the fuel Timing out of synch ?
Here are the service manuals for all Arctic cat ATVs
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
Feb 16, 2014 | Arctic Cat 2014 Wildcat 1000
Arctic cat 500 dies when you give it gas but idles fine!
You still have a carb issue, doesnt take much trash to chock it out when giving throttle. if you done the carb clean twice, try seafoam, does pretty good at cleaning the carbon out. use it as directed while running. it will smoke bad while preforming this proceedure so dont panic whens it smokes the neighborhood out.
Apr 07, 2013 | Arctic Cat 2007 500 4x4
Arctic Cat 2009 Bearcat 570 XT Logo
63 people viewed this question
Top Arctic Cat Winter Sports Experts
J.D. Browning
J.D. Browning
ka4iup
ka4iup
Arnie Burke
Arnie Burke
Are you an Arctic Cat Winter Sport Expert? Answer questions, earn points and help others
