Question about Peavey Pv 118 Pv118 Single 18" Subwoofer Sub Passive Pa
Replaceing subwoofer which is the hot wire
Which wire is hot
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
The red or white one, and polarity of the speaker is red+ black - if it is a black widow, The stamped steel peavey has the + - sign stamped into the terminal pad. you can always trace the hot wire as the one that connects to the tip of the 1/4 inch input or pin one of the speakon 4 connector. This works on any speaker.
Posted on Mar 24, 2014
KLH HPS 1100 powered subwoofer. as soon as plugged into AC we get a loud hum from spkr. had unit for 8yrs.
Hum usually indicates a power supply problem. If it has an internal supply you will need someone to check it's producing clean DC. Alternatively if you do open it (beware risk of shock!!) initially visually check condition of /replace any bulging electrolytic capacitors.
Jun 27, 2014 | Audio Players & Recorders
yellow is positive, blue is negative, they are both electrically hot when the amp modulates.
Mar 21, 2014 | Peavey Pv 118 Pv118 Single 18" Subwoofer...
Have poewr going to radio but it will not play but the clock works and the lights
YOU HAVE TWO HOT WIRES ON THIS UNIT ONE FOR THE CLOCK AND ONE FOR THE RADIO,,,THE HOT WIRES SHOULD BE MARKED,,,BUT IF NOT THEY ARE RED AND YELLOW,,,HOOK UP THE OTHER HOT WIRE AND YOUR GOOD TO GO,,,HOPE THIS HELPS.
Jul 15, 2011 | Car Audio & Video
The YST SW305 amplifies both sound and undesired noises. Is there a means so as to prevent its response to go below 30hz?
Yes you can cut off the low frequency response by putting a capacitor in series with the input. Cut the RCA cable connected to the input and connect a .047MFD capacitor in series to the "hot" wire.
The hot wire is the wire inside the braided shield wire, this is the signal positive and the outer shield wire is the signal negative.Leave the negative intact. And experiment with various values of capacitors between .047 to ..22MFD till you are satisfied. The rating of the capacitor need be only 50volts.
Apr 23, 2011 | Yamaha YST-SW305 Subwoofer
When hooking amp directly to battery, you hook battery hot cable and power hot cable then hooking ground cable up the ground cable becomes hot and pops the fuse
your amp is bad. you should have a 12v, ground, and remote wire. if these are hooked up correctly, your amp is more likely broken, and needs to be repaired or replaced.
Jan 30, 2011 | Car Audio & Video
I need to get my alpine swx-1043d subwoofer vioce coils replaced were can i do this at
I would try alpine and/or do a web search for speaker repair or speaker rebuilding. In most cases vc replacement involves replacing the whole cone, vc, spyder, and maby the surround. Bassically all the moving parts in most speakers are glued toghther with high-temp epoxy glue.
If it's a type-x it's worth rebuilding. My guess is around $100
There are a few places out there that can hot-rod the rebuild with larger gauge vc wire and thicker lead in wire and other mods that will make sure this doesn't happen again. Do a thorough webb search. The more competant people out there do repairs and also custom build their own subs.
Apr 02, 2010 | Alpine SWX-1043D Car Subwoofer
The subwoofer works sometimes and does not work sometimes
Hi it sounds like your voice coil is going out on your speaker. This happens if you drive them hard and the coil gets too hot it will burn the wires inside of the coil. You can have the voice coil rebuilt cheaper than it is to replace the speaker, but if they are under warranty then I would take it back.
Aug 11, 2009 | Infinity Reference 1230W Car Subwoofer
IC with number missing
use a bigger gage power wire
Aug 08, 2009 | Car Audio & Video
Installing a pioneer and can't identify constant hot or accessory
who told you about a hot wire. all need to do is go to walmart, or any store who sells car stereo accessory. an d buy a wire harnet. then just follow the color code.
May 03, 2009 | Car Audio & Video
Audiobahn 15s smell and stoped working
google "subwoofer wiring diagram" that will help you out,....you put in how many subs, DVC, SVC, and the ohms of the subs.....good stuff to know b4 hooking up a system....hopefully you didnt fry your subs or amp.....let me kno.....
Mar 14, 2009 | DHD NTX-6612 Car Subwoofer
Peavey Pv 118 Pv118 Single 18" Subwoofer Sub Passive Pa Logo
61 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Steve
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
