Question about ASUS Computers & Internet
Asus X53e can't access the wifi card
Asus X533 lost access to wifi Device manager report no wifi card Radio button not functioning Ctrl F2 Try to install drivers from Asus. No luck yet Is there a physical key to enable the card How can I know witch wifi card is install? Other thing I could do ? Any help appreciated Martin
  • Martin Theriault
    Martin Theriault Mar 22, 2014
    Resolved Finally found the proper drivers
  • Anonymous Mar 29, 2014
    to turn on wifi
    Top Expert:
  • ASUS Master
  • 21,532 Answers
If you have the correct drivers installed and you still don't see it in device manager, maybe it is faulty and needs replacing.
Posted on Mar 22, 2014
Testimonial: "Was not the solution, but thanks for your kind help. Finally found the proper driver, her system was a 64 bits Windows instead of the 32 version"
How to turn on wifi? Its been 2 -3 days wifi isnot being loaded?
Press and Hold the FN function key then hit F2 while holding the FN Key down.
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
May 25, 2012 | ASUS Eee PC 1000HE Netbook
WiFi not working...Function F2 is not turning WiFi on...Can't get blue WiFi light to turn on...HELP!
Sounds like the internal wireless card my have gone bad.They tend to do that from heat exposure.You can try uninstalling the card then rebooting, to maybe see if it will bring your wireless back to functioning.If your f2 key stopped working and it was at the time the wireless was turned off, this may also help.A bad wireless card can also effect other components attached to the motherboard as well.Its either a keyboard malfunction or most likely the card has gone bad.Hope this helps a little.Thanks
Oct 26, 2010 | ASUS Eee PC 900 Notebook
Is there a way to turn on the WiFi function
Try to disable the network card using the Device Manager.
Apr 13, 2010 | ASUS Eee PC 900HD Netbook
Can't enable Dell Wireless 1390 WLAN Mini-Card
I had the exact same problem and went through the same steps that he did. It was only when I searched for a physical wireless switch (on the left side of my Dell D630) that the problem was solved. I didn't even know it was there and must have inadvertently knocked into the off position.
Dec 12, 2009 | Dell Inspiron 6400 Notebook
Dell insiron 1520 does not respond to driver downloads, to connect to broadband
Make sure it's turned on. Use the Fn plus that antenna looking function key. If still no response,replace the wifi card accessible at the bottom of the laptop.
Nov 19, 2009 | Dell Inspiron 1520 Motherboard
My wireless is not working
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Sep 27, 2009 | Gateway MX6920 Notebook
My Dell Inspiron E1505's wireless switch is off.
This happened to me using a Dell Inspiron laptop. The wireless switch was disabled and the answer was supposed to use both the blue Fn and regular F2 function key to enable wireless connection. I tried Fn and F2 together and it did not work. I tried just F2 alone and it worked.
Jul 25, 2009 | Dell Inspiron E1505 Notebook
FN + F2 did not function in my ASUS laptop.
Restart> press F2 on boot = BIOS
Wireless device > ENABLE
Mar 14, 2009 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
Lost the software cd for my asus wireless adaptor
Hello Greg,
Check to make sure the device drivers are installed properly, and the device is functioning correctly, and enabled by doing the following:
1. Start
2. Right Click on "My Computer"
3. Select Manage
4. in the left column of the new window that appears, select "Device Manager"
If you don't see any yellow caution signs or red "x" then your device should be ok.
Make sure your wireless radio is also turned on.
What model is the laptop?
What model is the wifi adapter?
Are both from Asus?
Feb 27, 2009 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
