Question about Samsung Galaxy S GTI9000 Smartphone
Im not sure
My Samsung galaxy 1.It is dead when i plug it in and hold own the power button some times the phone turns on but sometimes it doesn't if u leave it alone plugged in for a few minutes it turns on. What do u think my problem is and what is the solution"
    Master:
  • Samsung Master
  • 561 Answers
It's discharged or battery is dead.
Posted on Jul 28, 2014
SOURCE: Samsung SCH-a870 turning off and on
i have the same deal with the metropcs and it turns on to load and then it turns off
Posted on Oct 31, 2008
270rexton
  • 762 Answers
SOURCE: samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Posted on Jul 16, 2009
mmnhltm
  • 695 Answers
SOURCE: my samsung corby plus wont
Its a problem in the Power Button
It may be stuck ,it needs to be released,try to release it by some pin ,if you couldnt ,you need to send it to a repair store.
Posted on Jun 01, 2011
  • 63 Answers
SOURCE: My Samsung galaxy s2 is just dead it doesn't even charge hw do I get it wrk
HI DEAR
IF YOUR S2 IS DEAD THEN IT MAY BE DUE TO 2 CONDITIONS
SOFTWARE: IF YOU WERE TRYING TO FLASH IT WITH CUSTOM ROMS OR IF YOU WERE UPDATING THE FIRMWARE AND THE THE PHONE DRAINED THE BATTERY IN BETWEEN THEN PROBABLY YOUR PHONE BOOT AREA HAS BEEN DAMAGED.IN THIS CASE IT CAN BE REPAIRED BY A PROCESS CALLED RESSURECTION.IT REQUIRES PROFESSIONAL TOOLS LIKE GPG JTAG,RIFF BOX,MEDUSA,ORT JTAG ETC PLUS PROFESIONAL SOLDERING SKILLS.FOR INFO GOOGLE IT WITH ONE OF TOOLS NAME
2)HARDWARE:IN THIS SITUATION YOUR MOBILES PCB HAVE FAULTS LIKE SHORTING,WATER LOGED,DAMAGED CHIPS ETC.IN THIS CASE YOU CAN VISIT HARDWARE REPAIR PERSON/SERVICE CENTER
Posted on Apr 06, 2012
SOURCE: my galaxy always thinks its plugged in to charge
I don't think anyone understands the initial question. The battery is fine and it even charges like it's supposed to. The question here is- how do you get rid of the icon in your notification box that is telling you that your battery is full? It seems to be stuck.
Posted on Jul 04, 2012
How to turn it on
Samsung Galaxy S3: How to turn it on:
On the right side near the top you will find the power button.. press this down with your right hand finger for a couple of seconds until you see something happening on the screen.. then let go. The phone will power on:
>> While power on the phone make sure you don't do this:
Cradle the phone in your hand, be careful not to press the volume key.. doing so while holding down the power key will affect what the phone does..
Also make sure that your hand or fingers don't rest on one of the bottom (capacitive) buttons (these are buttons activated by touch) near the home button.. it can also affect what your phone does while holding down the power button
I will demonstrate turning on the Samsung Galaxy S2 which is similar to the S3 in the video below:
personalized video tutorial 16.9 MB:
Jan 24, 2016 | Samsung Galaxy S3
My power button is not working my phone was switched off could you pls help me to switch on my phone. power button is not at all working my battery is full and it was switched off.
Sometimes plugging in the phone (into the charger) allows the phone to boot. Maybe your battery is simply empty? Charging the phone is a good idea regardless.
Also, try booting to safe mode to test the power button:
  1. Turn "OFF" the Galaxy S6
  2. Press and hold the Power/Lock button at the same time until you see the "Galaxy S6? logo
  3. When the logo shows up, immediately hold the Volume Down button, while releasing the Power button
  4. Keep holding the Volume Down until your phone finishes rebooting
  5. If it was loaded successful, a "Safe Mode" will show on the bottom left corner of the screen
  6. Let go of the Volume Down button
  7. To exit "Safe Mode" press thePower/Lockkey and then touchRestart
Dec 14, 2015 | Samsung Galaxy S6 Edge
How do I turn off "safe mode" on a Samsung Galaxy S4?
To turn off
Powering down , then back on should do the trick. Be sure to completely down. Do not select "restart". If you still have problems, remove back cover and pull battery from device. Leave the battery out for about 60 seconds, then place the battery back in, assemble the rear cover and start the phone again.
Some galaxy s4 models may require you to press and hold the volume down button during start-up in the same manner as enabling it to exit safe mode.
http://www.technipages.com/samsung-galaxy-s4-turn-safe-mode
Nov 17, 2015 | Samsung GALAXY S4
Hello / I have a Galaxy S. I am having problems getting the phone to charge When plugged into the charger, I see the picture/LED of a dead battery and then it blacks out... or I see a picture/LED of a
I have a hard time keeping the cables working. Try changing the cable out. Also try holding the cable and putting slight pressure upwards on the bottom of the connector. The charging symbol has to be on if it is charging.
Feb 08, 2015 | Samsung Galaxy S Cell Phone
Charging problem
It looks like it's quite discharged
Mar 21, 2014 | Samsung Galaxy S GTI9000 Smartphone
I have samsung galaxy I. my phone was turned off and when i turn it on it doesn't start as it stucks on samsung and doesn't start up. i took off the battery off and on but it still not working
hi,
try to hard reset your phone first by doing this procedure...
To Hard Reset Samsung I9000 Galaxy S
1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
2. Hold the Volume Down button
3. Press and release the Power button
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Press and release the Power button
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If YES is selected, all data including third-party applications will be deleted from your Samsung I9000 Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
if you do the above procedure and nothings happen ,its time now to re-flash your phone to its original version and a certified mobile technician will do that for you...thanks for trusting fixya
Oct 01, 2012 | Samsung Galaxy S GTI9000 Smartphone
Why Samsung Galaxy S keeps freezing and crashing. Like 5 times a day. Sometimes it is just me wanting to open up a application or just in the middle of texting. What is happening?
You should backup your contacts and perform a reset on the phone.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password, then tap Yes to confirm
If that doesn't work, or if your phone is frozen:
If you selected YES, all data including third-party applications will be deleted from the Samsung Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
Aug 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
How to reset my samsung galaxy
METHOD TO RESET GALAXY
STEP 1: Switch off your phone, remove its battery, and then place it back.
STEP 2: Now, hold the Volume Down button and Power button. And then release the Power button while still holding the Volume Down button.
STEP 3: Now you will get a list of options to choose from. Which would be like:
  • Fastbook
  • Recovery
  • Clear Storage
  • Simlock
STEP 4: There, choose the Clear Storage option.
NOTE: Use Volume UP and Volume Down keys for navigation and Power or Home button for selection.
STEP 5: Now confirm by pressing Volume Up button (YES) or Volume Down (NO).
That is it! Now, you Galaxy S will reboot and you will find that you have reset your Galaxy S to factory settings.
Jun 30, 2011 | Samsung Galaxy S GTI9000 Smartphone
I have samsung g 19000 and i have forgot my unlock
hi,
if you forget your lock code try to reset your phone in ths easy way...but i want you to know that all of your data will be deleted...
here is the instruction...
reinsert it
and Simlock
If the above procedures doesn't work, use this second method below,
1. Shut Down Samsung I9000 Galaxy S
2. Now press the Volume up, Home and Power button together.
3. When Samsung Symbol shows up release the power.
4. Then there is a boot Menu. Use the volume up/down to choose and home to select.
fresh state.
Apr 14, 2011 | Cell Phones
Samsung Galaxy S GTI9000 Smartphone Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
