Question about Acer Aspire X3400 PC Desktop
Power supply my computer shuts down after hour or two. I have to unplug my computer to get it to restart. also my fan is not working. We have cleaned dust from it but this doesn't help.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 59 Answers
Your fan needs to work to cool the processor. Sounds like it is getting too hot and shutting down/restarting. Once it is cool, boot into the OS and check your event logs which should give an indication as to why but it does sound like a heat issue
Posted on Mar 21, 2014
myob247
  • 1342 Answers
SOURCE: Computer keeps shutting off
It is overheating. Make sure the fan on the processor is working. Get a can of compressed air and blow out the inside of your computer to remove dust and dirt which will also cause overheating. If the fans are not working replace them or you could end up replacing your computer.
Posted on Jun 04, 2008
rcampsr
  • 90 Answers
SOURCE: computer shuts down on its own
Hello mr_nasty_72,
Your problem could be several things. Your hard drive is either over 90 percent full and the windows swap file is dumping the computer to shut down. the hard drive has a bad spot i it and when the system writes to it, then computer shuts down. Your memory has a bad spot in it and when the file useage of the memory gets high enough and finds the badspot, the computer shuts down due to the error. I would run a memory test program on the memory to ake sure it is not a memory error. Also rin a utility like spinrite on the hard drive and see if it can repair any bad sectors it finde and recovers any lost information on the drive. If your computer is new enough you cn go into the bios setup and look at the system utility for the power and fan system on the motherboard. This will tell you if the power supply is putting out the correct power voltage for the system. Regards, rcampsr
Posted on Feb 21, 2009
carputers
  • 255 Answers
SOURCE: Computer power on, monitor and fan issues
replace power supply it is weak.
Posted on Sep 08, 2009
Mustgo
  • 2359 Answers
SOURCE: My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Posted on Jul 28, 2011
Geekman
  • 32281 Answers
SOURCE: My acer Keeps shutting down Could it just be dirty or do need to upgrade the power supply
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Aug 18, 2012
Samsung dlp tv shutting down
Short of having a shop look at it make sure all 3 (this one should have 3) fans are not covered in dust or dirty---
other possible issues are the lamp and or the Ballast that drives it.
May 24, 2012 | Televison & Video
Why does my mac desktop computer screen start to flicker then shut off?
Remove the main battery and try again, the power supply adapter may be breaking down under load, there is no reliable way of testing other than subbing another power supply.
Apr 17, 2012 | Computers & Internet
Why my computer shut down every 2 hours
right click on the desktop click on properties select the screen saver option in this option u can see the power option and selcet never option of turn off hard disk and standby options.
Nov 15, 2010 | Computers & Internet
Hello-i have 2 problems with my lexmark 2600 1-printer is only 4 months old. it is always telling me that there is no communication.,i plug and unplug, restart machine, it dosent always work. 2- after...
Hello. Unplug the usb cable from the computer. Reboot the computer. Remove the power supply off the printer. The power supply is the black box behind the printer where the power cord is plugged in to. Reinsert the power supply after 10-15 seconds. When the printer's ready, plug the usb cable back to the computer. Good luck!
Mar 24, 2010 | Lexmark X2600 InkJet Printer
Computer frequently shuts down unexpectedly/ fans very noisy
You might have a cooling problem due to a fan malfunction. It is not clear whether it's the power supply fan or the CPU fan; in the latter case you might also have a thermal coupling problem. The symptoms you describe certainly seem to point to such.
My advice would be to replace the fan (or the whole power supply; you might also want to purchase a "Silent Power" unit for quieter computing). If it's the CPU fan and you are comfortable with, or know anyone comfortable with a bit of PC servicing, you might want to also unmount the heat sink from the CPU and replace the thermal paste between CPU and heatsink. Clean the heat dissipator (the black metal grille over the heatsink) with hot water and a bit of soap and dry thoroughly, or wipe it energically with a dust brush, before mounting the new fan on it.
Feb 28, 2010 | HP KQ499AA Pavilion Elite M9360F Desktop...
Dell 5150c shuts down orange flashing light
It was a faulty or worn out power supply fan. I just replaced it and the computer has been running for about an hour and a half and still no shut down. The system temperature is stable. It runs quieter now. New fan cost 13.88CAD.
Mar 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Presario S4020wm desktop
You need a new power switch. I am currently working on a S4020WM with the same problem. I cut one wire to the power switch, then used a paper clip to make a jumper to start the machine. It has run fine since then. The only trouble I am having is finding a replacement switch.
Sep 04, 2007 | Compaq (480082-001)...
Acer Aspire X3400 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
