Question about Technics SL-1200MK2 Turntable
Channel not working
Power is on but the light doesnt lite up one channel seems to be out
Can you be more specific? which light isnt on? the power light, the popup light, or the pitch fader light? and what do you mean by the channel? are you using mutiple technics? and are you using serato?
Posted on Mar 22, 2014
    Habit-Forming:
  • 12 Answers
If all the mechanics work as they should , you're in good shape. The right and left audio channels don't even have any circuitry, so the problem must be with the cartridge. (or bad old cables). Take out the cartridge and rub the connectors with a pencil eraser to clean them. Wipe with a rag and reinstall the cartridge...The missing channel should be back. If not you may have to change your cables. (there are tons of youtube video walkthrough.) It's not that hard and you get to upgrade the cheap cables Technics gives you. :)
As for the light, I assume you mean the pop up light? All you need to do is order a new bulb. I suggest LEDs these days. Longer lifespan and BRIGHT as hell. Heck if you feel comfortable with a soldering iron, get the whole LED kit. Any color you want and it replaces all the stock lights with your custom color for about $10. Cool huh?
If not you can just replace it with the original incandescent bulb for about $10 on ebay (oem always costs more than custom)
If the light you were talking about was the strobe, you will need to learn to solder or just buy a new motor board on ebay. They go for about $120, but then problem solved. I hope this helped.
1999 honda accord ac problem, power to the panel of buttons works and then it doesnt, the power seems to be shorting out?
Has the gas charge in the AC system been checked for proper level with a pressure gauge? If it is low due to a leak the system will not engage or cool.
Jun 12, 2012 | 1998 Honda Accord
2002 X-type Jag: Car won't start. The panel lights up - all lights operate correctly - but only one "click" and nothing. Tried to start with booster cables. Not the problem.
my 2002 jaguar is havind problems after changing battery , the tack doesnt work the abs night stays lite speed dom doesnt work abs brake light stays on and no power
Sep 04, 2010 | 2003 Jaguar X-Type
When I turn on my Nintendo DS Lite, the power light comes on but both screens stay black. Can this be fixed?
reseat teh wifi block - if that doesnt work its a faulty motherboard - only way to repair is to repalce the mobo :-(
Jun 11, 2010 | Nintendo DS Lite Console
A 16/4 channel Mackie VLZ bought new 1997 hardly used. Some times a channel goes quiet, sometimes the fault moves to another channel, or while setting a channel input signal the knob seems to work till...
I suspect you MAY have a severe ground loop. The green light indicates channel crossover if nothing plugged in.
MAKE SURE ALL connected equipment is powered from the SAME receptacle. If you service amps from receptacles at one end of the room and this board from the other end, you are ASKING for trouble.
Read up on "common mode" as it pertains to balanced lines. Equipment can be at risk if grounds "bounce" as they often do.
When green light with no inout shows up, slide all faders down first. Then unplug input lines one at a time... turn off the amps and then unplug the output lines one at a time. See if one of these inout or output lines was causing the green light.
You should be using BALANCED lines to your amps... either XLR or TRS types at both ends.
May 17, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
My Nintendo DS lite doesnt turn on
Maybe the baterry doesnt work you could try to buy a new one because at somepoint batteries dont work anymore that happened to me.
Jan 16, 2009 | Nintendo DS Lite Console
Dvd frozen
any storms around? sounds like a power spike tanked it
Jul 26, 2017 | Sony RDR-HX727 160Gb DVD Recorder / HDD...
Kenwood kac 859 amp
hi, note that if you are not using the proper gauge b+ and gnd cable with this amp then the current available at the amp wont be sufficint to keep amp on. also try using this amp while vehicle is idling. if this doesnt work then disconnect all spks from amp and check if red lite stops flashing. if it doesnt stop flashing then amp has internal fault. if lite stays on brite then proceed to check each spk load impedance, then reconnect each spk individually. the minute red lite starts flashing it will give you a clue that the channel or spk load is faulty. cheers
Jul 27, 2007 | Kenwood KAC-859 Car Audio Amplifier
Technics SL-1200MK2 Turntable Logo
65 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
