Question about Siemens WXL142 Front Load Washer
My siemens washer front loader is displaying an E04 what does that mean
It is displaying an EO4 MESSAGE WHAT DOES THAT MEAN
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 98 Answers
Drain is blocked - unplug the auxillary drain plug and check for clog.
Posted on Mar 27, 2014
2 Suggested Answers
  • 6277 Answers
SOURCE: what does an f04 error
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 13, 2011
Testimonial: "Thanks so much. You were exactly right - childs hairclip jamming it. All fine now. Thanks again. "
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
Nov 22, 2016 | Bosch Washing Machines
What does code eo4 mean?
Depends on make and model possibly year. I just googled
"code eo4" and lots of different appliances use that code. So I recommend you add what it is and the code, you may get an answer and a solution.
Mar 11, 2015 | Heating & Cooling
Siemens Wdi 1440 washer/dryer
It means your machine is not draining, Look out for the water exit open to drain water off.
Jul 21, 2014 | Siemens Computers & Internet
Getting a E04 error code
According to siemens website Laundry appliances use many different codes depending upon age and origin. Faults that can be dealt with by the user are normally listed in the instruction book. Link to instruction manual download Flashing LEDs or displays frequently indicate door not closed, low water pressure or a blockage in the drain pump, drain hose or your drainage system.
Dec 09, 2013 | Siemens WFXD5200UC Front Load Washer
EO4 error on Casio CE-700 can you help please?
I have never heard of this model. Did you mean a CE-7000?
Aug 07, 2011 | Casio Parts Cash Register PC Desktop
We get the error code eo4 on our Bosch front loader, and it does not spin.
Hi, "E04" means the "suds or pump is blocked"
Bosch E04 Solution:
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say! I'd guess you could get wet.
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole to 6'oclock and it should come free.
  5. Once the door out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hands. There is a small collector lip at the bottom of the cap, that is where I held my wet/dry vac to catch the water. Unscrew slowly so you don't get flooded. Take your time and keep unscrewing it until it is free.
  6. Pull out the trap that you just unscrewed and you'll most likely see the item that caused the E04 error code. There is an side of the trap that is marked that it needs to be installed facing downward, so watch for that when you put it back in.
  7. Read these direction upside down and backwards to put it all back together.
  8. Run a load and watch for leaks. You could leave the door off until you are sure you screwed the cap in tight enough.
Jun 23, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Heater Mini Max display the fault code EO4. What is the definition.
E04 is an airflow fault. You should hear the fan come on. If not, the fan is bad. If so, then your problem is electronic and beyond the scope of most DIY'ers
Apr 15, 2011 | Pentair Pool & Spa
What does fault code eo4 mean
The E04 is a high pressure alarm which will shut down everything the compressor and blower except the condenser fan motor if is how it is program.
Mar 08, 2011 | Heating & Cooling
What does error EO4 mean on a NT Mini Max Propane heater?
This is a fan falure code, it will mean your fan is out or the air pressure switch has a problem. Ether in the switch or the hose going to it. You can also check where the hose hooks up to the fan housing to see if anything is stuck in the port.
Feb 14, 2010 | Pentair Minimax NT Heater
How do i take the child lock off
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there.
Nov 27, 2009 | Siemens WXLS142GB Front Load Washer
Siemens WXL142 Front Load Washer Logo
370 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
