Question about Actron CP7665 - Autoanalyzer
Display shows 'H' and -1 regardless of rotary position
Fuse blown?
Error Code E0 39 after replacing induction Control module. Our Range is Frigidaire CPCS3085LF, apparently the module is not talking to the panel. is there a fix?
Execute following sequence to force cooktop reconfiguration (Be sure the good ESEC20 UIB is installed into the cooktop)
1-Put all rotary control to the first detent position clockwise (1 o'clock).
2-Put all rotary control to the first detent position counterclockwise (11 o'clock). The system should then reconfigure, showing walking dashes on the cooking zones displays.
3-Put all rotary controls to "Off" position. There should be no more error code and the cooktop is ready for operation.
Frigidaire Range Stove Oven Surface Element Board 318329620 Frigidaire Range Stove Oven Oven Control Board 318347100
Jun 12, 2016 | Frigidaire Kitchen Ranges
QD32 engine how do I know number 1 on injector pump
if the injector pump is an inline pump ( where all the injector pipes are arranged along the top of the pump the no 1 injector is the line closest to the front of the engine . If it is a rotary pump ( where the injector lines mare arranged in a circle at the back of the pump no 1 will be either at the 10 oclock or 2 oclock position. As the injector lines are hard and bent for each piston then the line from no 1 injector will point to the no1 position on the pump regardless of how many cylinders there are. If it is a common rail diesel then it doesn't matter because the injection timing is electronic and set from the crank shaft position sensor.
Nov 27, 2014 | Cars & Trucks
2005 f-150 radio has no display and will not turn on. If I hit the menue button the clock will show and then goes away
Sounds like the hot in accy / run position for the fuse is blown ( the symptom is what the radio does when the key is out of the ign ).
Check ( with a meter ) the fuses in the cab fuse panel :# 22 ( this is the pwoer to the radio from teh accessory delay relay ).
The other fuses : #31, #7 and #1
Fuse #31 should be good, this is hot at all times ( keeps the memory and allows the menu to show the clock to function )
Fuse #7 is only hot in the start position ( not sure what this is for to be honest ).
Fuse #1 is hot in Accy & Run positions.
So the total fuse meter check / replace list is #22, #7 and #1
Oct 28, 2010 | 2005 Ford F-150
Mastercraft maximum rotary tool icd display is flashing a lock in locked postion
Those digital dremel's are touchy when the get hard use. learn to use it without the display or try to return it regardless if it spins, it's fine.
Oct 21, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
If fuse blown error shows, fuse (1.6mamp) if it replaced to (0.5 amp) then it works.
change the fuse with (0.5 amp).
If it doesn't work try this:
From Samsung site:
1 Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2 Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3 Press the left arrow (4 Press ENTER. The operator panel will display [YES].
5 Press ENTER. The toner warning message should be gone.
6 To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Then you don't need to use fuse after that.....
Sep 27, 2010 | Samsung SCX 4521F All-In-One Laser Printer
I HAS A 9-363 FAULT
9-363 Control Logic detected that the Rotary did not reach the Home position
This usually a blown fuse on the Rotary PWB, change that and you are good to go if that's the case. It can also be that you've run too many B&W prints and you need to replace the black developer and change some NVMs if you intend to continue doing that,
Apr 19, 2010 | Xerox DocuColor 12 Color Copier
Possible blown dryer thermal fuse
to check thermo fuse set digital meter to a low resistance setting typical 200 " omega symbol" on most digital meters the 200 setting also has an audio beep for continuity which means that if the fuse is good it will beep and also show on the display a zero out, and if fuse is bad there will be no beep and the display will show a 1. good luck.
Dec 31, 2009 | Actron Digital Multimeter Tester
Rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Feb 06, 2009 | Uniden Cordless Phone
Time delay
1.Position the rotary switch to reset.
2.Press the RH button, with the clockface on it, once for every hour of delay required. The display will change to 1H, 2H etc.
3. reposition the rotary switch to the number of the required program.
4.Washer will start program after the selected number of hours.
NB. If you select too many hours, cotinue to press button as display will count up to a maximum of 24H before retuning to zero again.
Jan 24, 2008 | Indesit 24 in. DE73 Evolution...
Actron CP7665 - Autoanalyzer Logo
37 people viewed this question
Top Actron Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Bill Boyd
Are you an Actron Measuring Tool and Sensor Expert? Answer questions, earn points and help others
