Question about Bosch PSS 250 AE case Sander
Base plate how do I change the base plate?
Replacing base plate
The base plate for your saw is held in place by a screw that goes through a plate that fits into the raised part of the baseplate with the elongated holes. The nut that holds the screw in place is sandwiched in the base of the two housing halves. The raised part of the base plate and elongated holes are what allow you to tilt the base plate.
Jun 16, 2012 | Saws
I have a Pfaff 1471 which changes programs mid sewing after I have been sewing for a while, or if I leave it on when I am not sewing. The only way I have found to get back to the sewing mod that I need...
It's possible that the base plate, which has your power supply in it, is going out. Sometimes needles have been found inside the base plate from sewers putting pins on the top of the machine, and they fall inside. You might just loosen the 4 straight slot screws on the bottom of the machine, seperate the base plate from the machine to check for any pins or needles inside. Lay the machine on it's back to do this and DON'T forget to unplug it. If you choose to disconnect all the connection cables, be careful when you pry the tab to pull off each cable, cause of the heat created by the base plate the plastic tabs are brittle and they do break.
Apr 27, 2011 | PfaFF Sewing Machines
The needle hits the base plate about 1mm on the far side of the hole.
sounds like a bent needle. did you try changing it to a new one? I have gotten bent needles new in package before so try a couple out...hope it helps
May 12, 2010 | Sewing Machines
Jetta 1991 carb.car does not want to idle after 4000 rpm.changed carb , base plate , gasket on intake manifold.no luck
TOOK THE CAR TO BOSCH DEALER AND RUN A FEW TESTS ONLY TO FIND THAT THE AFTER MARKET CARB AND BASE PLATE DID NOT WORK AS GOOD AS GENUINE VW PARTS.AFTER MARKET CARB HAS 2 VACUMS AS GENUINE VW HAS 1 AND THE AFTER MARKET BASE PLATE IS MORE FLEXABLE THAN GENUINE.I INSTALLED GENUINE VW PARTS NOW AND IT SEEMS MY PROBLEM IS SOLVED FOR NOW.
Feb 16, 2010 | Volkswagen Jetta Cars & Trucks
Hoover Elite Rewind
Something's rubbing. It is probably the beater bar rubbing against the base plate. Remove the base plate and check that your beater bar is back in the sockets of the vacuum frame correctly. If they get installed a bit off, it'll make a LOT of racket. Check it out!
Best regards, --W/D--
Aug 05, 2009 | Hoover Elite U5061-900 Bagged Upright...
Switch a rheem thermostat to a hunter thermostat for heat pump
You can take the front cover off of your programmable thermostat. Unscrew approximately 2 screws that attach the base plate of the thermostat to the wall. Look in the back of the base plate after removing it from the wall to see how the 2 or 3 different colored wires (ex: red, green, black) are hooked up. Make note of this. Remove the wires from the back of the base plate and attach the wires to the same posts that they were connected to on the original base plate you removed. I believe the posts on the back of the base plates are color coded. (Ex: attach green wire to where it says GRN on back of base plate).
Make sure the thermostat that you are replacing and the new thermostat are similiar in shape, otherwise you will have make repairs to cover up a space that may appear around the new thermostat.
May 14, 2009 | Hunter Fan Company 5/1/1 Programmable...
License plate light replacement
The license plate lights are in the ledge above the license plate. 2 screws keep the lens cover in place. Remove the screws, and the cover comes off. Just pull the lamp out (wedge base) and replace.
Apr 13, 2009 | 2002 Chevrolet TrailBlazer
I can't figure out how to change the belt on my hoover bagless Sprint upright. Please help.
1 set up vacume with bottom facing you , making it easy to deal with.
2 remove the 4 screws holding base plate on and carefully remove the base plate, on mine there is a small catch that must be released.
3the belt compartment is on the right, remove the old belt, it's about 1 and 1/4 wide.
4 You have to put the belt on the stainless steel motor spindle first, then work the belt over the plastic drive wheel, and spin it around a few time to ensure it's running on track ok.
5 Replace the base plate , click in the self catching clip last.
6 Replace the four screws and test the vacume.
Oct 23, 2008 | Hoover Vacuums
Bosch PSS 250 AE case Sander Logo
42 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Tom Chichester
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
