Baumatic BK6EL agitator is loose
I have a baumatic BK6EL toploading washing machine, the agitator panel has come loose and only spins the load if i put it back in position each time, sometimes comes loose completely, i assume i'm missing some kind of bolt or clip but i have no idea where to get one or what to get? help me!!!
5 Suggested Answers
SOURCE: re Baumatic BK6EL, the washer stops at the
Hi Same problem but easy to fix.
Remove back cover of machine. Look to the lower end of the bowl and you will notice a stainless steel wire with hook attached. If this is hanging loose that will be your problem. Reattach the hook to the grey coloured lever , it has a hole drilled through it at the extremity. The wire pulls on this lever to disengage the drum brake during the spin cycle.
Posted on Mar 02, 2010
supertech6
  • 513 Answers
SOURCE: We don't have an instruction manual for our
This has a strong indication that the machine needs a controller. A controller can be from $80 - $400 depending on model and type. Good news is they are generally easy to change. I recommend a new knob with the controller as you will likely break it getting it off without knowledge and special tools.
Check this website for parts:
http://www.prontoparts.com.au/
Posted on Mar 22, 2010
rickead1
  • 1998 Answers
SOURCE: Baumatic BK6EL washing machine will
One of the most common problems encountered with washing machines that need repairs, including Baumatic machines, is no water coming into the machine or the soap not being taken from the soap dispenser box. There are two main reasons why this could happen, 1. because the water has been turned off inadvertently from somewhere, or 2. because the water inlet valve as become faulty or blocked.
If your appliance is not taking in water the first thing you need to know is if the problem is with the hot or cold supply, to find out you can put your appliance onto a white wash cycle and start the machine this should bring hot water into the machine and you will know within a few minutes if the hot water supply is working or not, and to find out if the cold supply is working or not select stop/reset and then select the drain or spin cycle and this will empty the machine of any water, now select the rinse cycle and this should bring cold water into the machine and you will know within a few minutes if the cold water supply is working or not, once you are sure of the results select stop/reset and then select drain or spin again to empty any water that may have entered the appliance.
At this stage you should know whether the hot or cold supply is at fault, the next thing you need to check is that the water as not been turned off inadvertently, check both the stop **** and the washing machine connector valve/s, to see if you can tell if it as been turned off or not, if you think it as, turn it back on and do the hot and cold cycle test above for the cycle that failed, if the water is still not coming into the appliance you know need to turn the water off from the washing machine inlet valve/s one at a time and slowly disconnect the the inlet pipe/s from the washing machine side and point the washing machine inlet pipe it into a bucket and then turn the water back on, you should be checking to see that the water is on and also that the water pressure is OK.
There is a good chance your appliance could be working OK now, but If the test above shows the water is on and the pressure is OK but the washing machine is still not taking in water, you will need to have t the water inlet valve and or the water pressure switch and water pressure chamber tested, the diagnosis procedure covered here will work for Baumatic washing machines that need repairs, it will also work for most other makes.hope this helps
Posted on Aug 11, 2010
quintsmartas
  • 10 Answers
SOURCE: hi i have a baumatic bk6el/6kg washing machine at will not spin out on its final spin.
May be your timer, go to Britishjames.com
Posted on Oct 27, 2012
My baumatic bk6el wont drain sin drain
Drain the machine , drain hose next to drank plug , undo the drain plug and make sure there is nothing stopping the propeller turns using a torch to see with , if all turns and nothing lodged there then it's your pump ps easy job to do and cheap to repair your self , if you need more information get back to me colin evans
Dec 13, 2017 | Baumatic Washing Machines
Machine stops during the spin, especially with heavier loads.
Maybe you overload your washing machine. Minimize your washing machine usage to avoid stopping during the spin.
Aug 23, 2015 | Baumatic Washing Machines
I have no instructions on how to installa baumatic bwr 1206 wasing machine
Hope this helps :)
http://talkappliance.co.uk/downloads/?sa=view;down=103
Apr 23, 2012 | Baumatic BTWM4 Front Load Washer
Re Baumatic BK6EL, the washer stops at the beginning of the spin cycle, showing soak, extra rinse, spin lights all on. Thinking it was just an unbalanced load, I readjust the load and press the start...
Oct 27, 2009 | Washing Machines
Baumatic washer draining but not spinning
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Sep 05, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Need a manual for the Baumatic BK6EL/6kg just bought off Trademe no manual with machine
www.baumatic.co.uk
Should be contact information here to request (or possibly download) a manual.
Apr 19, 2009 | Baumatic Washing Machines
Baumatic washing m/c btwm4
check that the drain filter is clear, if thats ok its probably going to be the electronic module at fault.
Nov 25, 2008 | Baumatic BTWM4 Front Load Washer
Baumatic MEGA WDSS washing machine
go onto manualtree.com type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Jul 02, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
