Question about SRC Refrigeration Refrigerators
Need a Replacement Ballast for a Bs54Gd
Need to get a replacement Ballast for a BS54GD Floral Cooler
2 Suggested Answers
  • 34242 Answers
SOURCE: ballast replacement Glo aquarium light 2 x 54", mod A-3912
If you cannot get the internal ballast replacement from Glo, copy all pertinent information from the old one and check with an electrical supplier.
Posted on Jan 10, 2014
Ballast replacement Glo aquarium light 2 x 54", mod A-3912
Jan 10, 2014 | Televison & Video
What type of ballast is in a Coldtech j1gr-24l
the number of lamps and the size/ wattage of the lamps. it would really help to take the old one in with you.
Mar 08, 2013 | Coldtech J1GR-24L Beverage Cooler
I need a replacement ballast and capacitor for a 400W metal halide outside light, I need to know who would carry it and also a wiring diagram
most home depots will have a replacement ballast for this light, inside of box will have the correct wiring diagram, and how to wire it, if not sure as to how to wire it call an electrician
Nov 22, 2011 | Home
I have a used Beverage Air model # MT17-54. What size light bulb do I need, Lenght and wattage.
I Have The MT15-54 Used The Same Very Hard To Locate Bulbs & $$.
F28T8CW4 is a 28inch, Plus Ballast Replacement Cost(s).
I Got Rid Of That Setup, Removed Both Ballast and Lamp Holders.
Install Two 13W T2 Twister Fluorescent Energy Saving Screw In Bulbs,
I Call Them The Pig-Tail Bulbs, Less Energy & Heat.
Obtain a Dual Levington Incandescent Porclein Bulb Holder Assy, Part# 4005 and Mounted Inside Cooler/Front Side Only/Top Center
Between Evap Coil/Fan Cover & Sliding Door's, Little Room, But
Works Great w/Bulbs.
Lights Entire Inside, Plus If You Like Color Bulbs, Add's a Cool Look
At Night. Use Same Light Switch Installed From Bev-Air OEM.
Jun 13, 2011 | Kitchen Ranges
I have a true GDM-12FC floral cooler that the compressor would not cycle. I just changed the thermostat but compressor would not quit.
You have not said if the cooler is cooling to the correct temperature or achieving the setpoint. Make sure that the correct thermostat has been supplied. Also that the sensor has been installed in the correct location. If all of the above is correct, then I would have the refrigerant level checked.
Mar 09, 2009 | True GDM-12FC Refrigerator
Find locate of lighting ballast in 3 door BevAir cooler
Sometimes they are in the overheade space above the cooler .. if they were inside then they would have to be HO ballasts because of the temperature .. sometimes they are in the moulding strip under the lamp itself.
Feb 24, 2009 | Beverage-Air MT27 Beverage Cooler...
True 2 door light problem
I believe that unit has a ballast tucked in somewhere in the compressor compartment. It may be easier to access from the back of the unit. I don't think it has a starter.
Dec 09, 2008 | True TD-95-38-LT Beverage Cooler
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
Refrigerators Logo
23 people viewed this question
Top SRC Refrigeration Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a SRC Refrigeration Refrigerator Expert? Answer questions, earn points and help others
