Question about Samsung Refrigerators
Rl39wbms power cut out
My Samsung RL39WBMS fridge on m fridge freezer keeps freezing food. Why is this happening all the time and how can I prevent it?
maybe the fridge is set on a colder setting and if that's not it then stick it on the lower shelves and that might help from not freezing because are fridge is the same way when it is stuck by the coolant fan
Nov 02, 2014 | Refrigerators
Emergency power cut now won't start
you cut cord have open circuit.your electrical cord has three wires neutral wire white wire black wires hot wire and bare wire for ground. if you cut either neutral wire or hot black wire in the electrical cord no power can flow to trimmer motor if you cut wire need to fix wire to get trimmer work again.
Dec 24, 2012 | Cars & Trucks
Washing machine cuts out
The pump is over heating and cutting power.
Mar 30, 2012 | Fisher and Paykel Washing Machines
My aquatek 110 power washer keeps cutting out. i have only used it three times and was carefull not to allow it to overheat. the filter is clear, as i checked this as recommended in the user guide but it...
the aquatek 110 power washer has an automatic cut-out for protection function. So its cutting out because its protecting the washer from one damage or the other.
From the look of things, the power washer is faulty, that's why it keeps cutting out.
Take care.
Jul 08, 2010 | Garden
Thermostat keeps cutting power off to elba excellance oven
I have a similar problem with an Indesit oven. There are two thermostats one controlling the oven temperature which i think you have replaced and another over-temperature stat to prevent the oven getting to hot should the temp stat fail to control the temperature. The over- temperature stat could be operating to quickly and this cuts power to the the digital display, oven light, temp light and circulating fan. I am going to replace this over-temp stat
Jan 18, 2010 | Lux Elba OV 5085 LUX
2006 Toyota Sienna..Power cut out during driving. But them works
The power cut of my Toyota Sienna2006 was activated, and the Sienna did not started even with jumper. What can I do? Please help me A.S.A.S.P.
Cynthia
Nov 15, 2009 | 2006 Toyota Sienna
Ice block forms bottom of freezer then leaks on 2 floor
This is usually because the self defrost hose has become clogged. Turn the unit off long enough to defrost the unit and get the ice out of the tube and blow out the tube and turn the fridge or freezer back on.
This should solve it for you.
Cheers
Al
Sep 11, 2009 | Samsung RB2155SH Bottom Freezer...
My fridge compartment is warm and not cold but the freezer section works fine. It's Samsung rl39wbms
Check the freezer for frost on its back wall. The refrigerator gets the cold air for cooling from the freezer section. If you have frost on the back wall you have a problem in the defrost circuit. There are three parts involved in the defrost of the coil. Heaters, thermostat or defrost thermostat, and timing device. If your model has a mechanical timer you can located it and rotate the clutch head screw Clockwise very SLOWLY until you hear one click. This puts the freezer into the defrost mode. After 30 minutes if the defrost takes place and the refrigeration does not restart, rotate the clutch head screw a little more and it will start. This tells you the timer is the problem. If it does restart by itself and defrost does not take place your problem is in the heater of defrost termination thermostat. The timer is generally located near the controls for the temperature.
May 31, 2008 | Samsung Refrigerators
Refrigerators Logo
35 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
