Question about Samsung Refrigerators
Water and ice under crisper
Water pools up under both lower drawers and freezes in less than 24 hours. how to fix?
    Problem Solver:
  • 19 Answers
Replace door seals
Posted on May 22, 2014
  • 42 Answers
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
22yooper
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
  • 112 Answers
SOURCE: ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Posted on Oct 18, 2008
larryyb
  • 291 Answers
SOURCE: Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
Posted on Nov 26, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
Water under produce section
In addition to water under the crisper drawers, you might be getting water in the drawers too, look for any ice/frost in any of the air vent holes just above the drawers on the rear fan cover. This unit was made by Samsung for GE, these are notorious for this issue as the defrost drain tube wick heater is not long enough to work. You will need to turn the unit off for 24 hours, unplugged, doors open to ensure it's completely thawed both behind the cover and drain tube. Part# WR13X10573 (cover assembly complete) gets replaced, and part# 819043 will need to take the place of the existing Samsung one. Pleazer Appliance...
Apr 08, 2014 | GE Profile Pfsf6pkw 25.8 Cu. Ft....
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
Food in crisper drawers freezing
HI. UMMM I WOULD DEFROST ALL FIRST.24/48 HOURS.AND TRY.MIGHT BE PARTIALY BLOCKED WITH ICE IMPAIRING CIRCULATION.GOOD LUCK.ALI
Jul 05, 2012 | GE (GTS16BBS) Top Freezer Refrigerator
Ken more refrigerator has no ice maker but water is pooling under the crisper drawers. Model c21tfa95
Check the drain channel at the rear of the fridge just above the crisper drawers and blow through the drain hole with a drinking straw to clear it.
Jul 02, 2012 | Refrigerators
Can I take the freezer door apart and wrap the water line with more insolation
No, you can't. The line goes into the mold of the machine with no access there.You have either an air leak in the dispenser area, around the ice shoot possibly, or the resevoir, which is located on the refrigerator side in the lower area behind the drawers is freezing, which is most likely the case. There are vents on the lower section for the crisper drawers. If you take out the drawers you'll find a roll of 1/4 " tubing which they call a resevoir that cools the water down. This is probably frozen,and you can insulate this, but I would raise the temperature in the fridge side or close the vents to the crisper area.
May 08, 2012 | Whirlpool ED2FHEXN Side by Side...
Water is pooling and freezing under the crisper drawer
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan,
water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage.
Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Feb 18, 2010 | Refrigerators
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
198 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
