Question about myregisteredsite.com
I have forgotten my password on myregisteredsite webmail
I ma sure I am using the correct one but it keeps taking me back to the squirrel mail login
My email is not working help me
Normally most email issues can be resolved by some basic checks to make sure that the settings are correct. In summary we just need to double check a few settings which are very easy to do & can be summarized as:
1. Check Nameservers
2. Check Billing is up to date
3. Check Password for email address
4. Check Email Account Quota
5. Check if disk usage is exceeded
6. Check Configuration
7. Try Server-Name in place of domain name
These steps are detailed below - please take care to go through them in order, they should only take a couple of minutes:
1. Check Nameservers - Check that your domain name is pointing to the correct name servers where your email is hosted.
- if you check your welcome email from when you signed up to your hosting service you will find the correct settings. If you do not have the settings then please ask our 24 hour support team & they will confirm for you.
2. Check Billing is Up to Date - If your Nameservers are correct, please double check that your hosting is paid up to date by logging into your Billing Area
3. Check Password for Email Address - Check that you have the correct user name and password for your email account. The username should be of the format" email_ID@yourdomain.com", and password is case sensitive. The quickest way to check this is to login to your Webmail. You can do this by going to http://www.ENTERYOURDOMAINHERE.com/webmail
(Please replace ENTERYOURDOMAINHERE with your domain name).
You are then prompted to enter the email address & the password. If you are able to login to webmail then this means that the password is valid for that email address so we can proceed to the next step.
3. A. Reset Email Password if Necessary - If your password is not accepted then this just means that you need to login to your Web Hosting Control Panel & reset the password for your email address. To do this, all you need to do is to login to your web hosting control panel & select the "Email Accounts" icon & then select the option to change your password. The following link shows you exactly how to log in to your Web Hosting Control Panel.
4. Check Email Account Quota - Next we need to check if your email quota is full because if this is happening then that will stop new emails from being accepted on the server. To do this, login to your web hosting control panel (see point 3 A above) & select the "Email Accounts" icon & then go down to the list of email addresses & you can see a summary of email accounts & the quota for each. If your email account is full then you just need to either delete some emails via webmail (see point 3 above) or you can simply increase the disk space quota for your email address by selecting "Change Quota" (we do not recommend setting to unlimited if possible).
5. Check if disk usage is exceeded - If your email client doesn't let you connect to the server and throws at you a 'login failed/incorrect password' error, you are likely to have exceeded your disk usage. It's not the quota of any specific email account that has gone over the limit, but the disk usage of your entire hosting account. You should regularly keep an eye on your disk usage to ensure it always stays within the limit. Steps on how to find the disk usage.
You can confirm if your disk usage has been exceeded by simply trying to login to your cPanel. If it is over-quota, cPanel wouldn't let you in. You could then contact support who will look into it for you. Once you have verified that your nameservers, billing, password & quota details are correct we can now run through some trouble shooting to find out where the issue is.
6. Check Configuration - For your email software to be able to send & receive emails then the configuration settings need to be set as shown below. You can find these settings in your emailĀ“s software. For example, in Microsoft Outlook or Windows Live Mail you just need to select Tools/Accounts & then in the Servers tab please ensure that your settings are:
> E-mail Address: Your complete email address (see point 3 above)
> Password: Your email password (see point 3 above)
> My Incoming Server is a: POP3
> Incoming mail server (POP3): mail.domain (eg: if your domain is abc123.com your settings would be mail.abc123.com)
> Outgoing mail server (SMTP): mail.domain (eg: if your domain is abc123.com your settings would be mail.abc123.com)
> Remember password: Select Yes by ticking the box to confirm
> Server requires Authentication: Select Yes by ticking the box to confirm
Then select the Advanced options and check the following:
Outbound SMTP Port: 25 or 26 [Some ISPs block port 25 traffic to reduce spamming. If you are unable to send out mails through port 25, try port 26. ]
Inbound POP3 Port: 110
Do not select the option to leave a copy on the server as this will eventually fill up your web space if you select this option.
7. Try Server-Name in place of domain name - Still not working? OK, it could be that your ISP does not recognize the mail server settings so we will try replacing these one at a time with the main server-name of the server.
To do this please follow these steps:
A. Get your server-name from the product welcome mail.
B. Go back to point 6 above & first replace the incoming mail server (POP3) with the nameserver (i.e. using the example in the above article, we would replace mail.abc123.com with node005.hostingseries.net). Try again.
C. If it still does not work change the incoming mail server (POP3) back to its original setting (eg: mail.abc123.com) & then change the Outgoing mail server (SMTP) to the server name (i.e. using the above example we would replace mail.abc123.com with node005.hostingseries.net) & try again.
D. If it still does not work, please change both Incoming & Outgoing to the server-name (i.e. using the above example
we would replace mail.abc123.com twice with node005.hostingseries.net)
If you still are unable to configure your email, please contact our support team (use the 24 hour live chat service - top right hand side of our website) and they will be able to identify the issue for you.
Nov 21, 2016 | Miscellaneous
Cannot access my account, doesn't recognize my e-mail.
Darlene make sure you are using your outlook.com or miscrosoft account email address.
Mar 05, 2014 | Microsoft Windows Vista Home Premium with...
I can't sign into my webmail account
Webmail is a type of email that allows you to access your messages on any computer with a browser and Internet connection.
Webmail has its advantages over email clients (such as Outlook) in that it allows remote access to your account.
It also is convenient because it does not require extra software to be installed on your computer. It takes a couple of moments to log in to your webmail account.
Open a browser.
Go to your email service login page.
For example, If you have a Yahoo! account, go to http://mail.yahoo.com/, if you have a Gmail account, go to http://mail.google.com/ and if you have a AOL account, go to http://webmail.aol.com.
Contact your Internet service provider if you're not sure of your Webmail login page.
Type your user name and password in the fields provided on the page.
Click the "Go" or "Sign In" button.
You will be taken to your email account where you can manage your messages.
Aug 03, 2013 | Microsoft Office Professional 2007 Full...
I can't log onto my webmail account. I haven't been able to do so for several days...
Which Webmail account >?????
Open a browser.
You will be taken to your email account where you can manage your messages.also
Accessing your webmail account in one of the available ways is simple and should only take a few minutes to set up.
Use a web browser like Internet Explorer, Safari or Firefox to go to your webmail site.
Sign in to your account where you can read, send, archive and delete messages, among other functions.
This is the simplest way of accessing a webmail account and is the way most free web-based email was accessed in the past.
This method is useful if you are away from your normal computer and need to check your messages.
Configure a desktop email program like Microsoft Outlook, Apple Mail or Mozilla Thunderbird to access your Hotmail account.
Using a system known as POP3, desktop email software can access your webmail account and deliver email directly to your computer.
You can use these programs for all the standard features of your webmail service.
See Below for details of how to configure your Hotmail and Gmail with desktop email software.
http://mail.google.com/support/bin/answer.py?answer=13273
http://www.domainmonster.com/editorials/types_of_email /
http://techblissonline.com/yahoo-pop3-and-smtp-settings/
Visit your provider's website for configuration information specific to the provider.
Configure a mobile device with Internet capability to access your webmail.
See Below for how to configure Hotmail and Gmail accounts for your cell phone or PDA or visit your provider's website for information regarding your particular provider.
http://www.google.com/mobile/mail/
Most major webmail providers have free access for portable devices.
Jul 31, 2013 | Microsoft Office Professional 2007 Full...
My mail comes back saying my e-mail addresses have a profile the Internet community may consider spam. I think my e-mail addresses have been kdinapped to do phishing. How do I fix this?
First of all, log in to your email, and change your password, so that no one can use your account anymore. Make sure you choose a secure password.
You should also run a virus scan on your computer. You can try Microsoft Security Essentials.
Do ALL your emails get rejected, or only those to certain people? Which email provider do you use - Gmail? Yahoo? etc.
You may want to create a new email address, and tell everyone you know to start using it. You can set up your old email address to forward to your new one, so you'll still get those emails, until everyone catches on and starts using the new address.
Mar 24, 2013 | myregisteredsite.com
Can't login to my yahoo mail
Please check your internet connection to see if it's working in perfect condition.
If yes, check whether you are correctly typing in your login credentials.
If you have forgotten them, reset them using "Forgotten Password".
This should solve your problem! :)
May 11, 2011 | Yahoo Mail
When i log onto entourage, it has me put in password, (i know its the right one) then a message comes up and reads "mail can not be received at this time, username/password r security settings may be...
Try to login to your Webmail and see if you can login.
when I say Webmail, for example you have a hotmail account, try to login to www.hotmail.com by using Safari or any internet browser.
If you can't login to webmail, that means you're enterring the wrong password. But if you can login, most likely you have a corrupted account profile. Try recreating your account in Entourage.
Hope this helps.
Cheers!
Aug 19, 2010 | Microsoft Entourage For Mac for Mac
My AIM mail won't let me reply back! Please help
Is the problem with the Webmail service or a mail program? If the issue is the webmail, then it's an issue that I can't help you fix; it is on the server.
If you are using a program like Windows Mail or Thunderbird, first have you gotten a message about accessing a security site (to prove you are a real human)? That system has issues and you may need to clear the cache and cookies in your browser before going to that site to unlock the security issue.
Second: make sure you have your outgoing mail correctly set-up. It should have server name: smtp.aim.com port 587. You need your user name and password enabled but not the secure authentication or Connection security.
Finally there have been recent problems on the authentication side of AIM service. I'd seen messages that this problem was fixed but it may wtill have problems. http://twitter.com/aolmail has updates (usually limited to M-F).
I hope this helps.
(If you use IMAP for your incoming mail, you can have an easy work around if the Webmail interface is working. Write your outgoing message in your preferred mail program and save to draft. Login to the Webmail on your browser. Go to the draft folder and you should be able to chose either send message or edit and then send. If you use POP3, it's a multi-step process to cut and paste the message from the draft in a new compose window on the Webmail service.)
Feb 28, 2010 | Apple Computers & Internet
Webmail.talktalk.net does not accept mypass word. Have used it for years,acer laptop
If you normally use POP3 to access your TalkTalk e-mail and haven't used Webmail for a while you may find that you can no longer log in. I have seen just a few isolated cases of this.
I'm not sure why but to fix it log into www.talktalk.net and access the Broadband Dashboard which is located on the left hand side under Broadband / Manage Broadband Features. Choose
  • Now sign in again, SIGH!, using your telephone-number@talktalk.net and your broadband password. If you have forgotten your password then just call 08700 875562 from your TalkTalk landline and follow the instructions.
  • Select the e-mail tab and enter a new password (or even the same password) against the e-mail address you are having problems with and then press UPDATE.
  • Now you can go back to webmail.talktalk.net and you should be able to sign in using the e-mail address and password. If its your first time on the new e-mail platform then you will be asked to fill in some extra details such as your name, gender and date of birth and press submit them.
Webmail should now be working again.
Oct 18, 2009 | Acer Computers & Internet
I am unable to get into my microsoft outlook express email. It says my password is not correct.
Go to OE/ Tools/ Options/ Send tab/ News sending format section: check
plaintext, not html
If its the password for the exchange server authentication, it has to be the same as your webmail account online!
Go to tool> email accounts > reenter the password under the server tab and the settings button against "my server requires authentication" on the same page.
Make sure the passwords you enter here is the same that you used to login to your webmail account with the same e-mail id!
save the settings and restarte outlook express..
Regards,
Ronald.
Aug 19, 2008 | Computers & Internet
myregisteredsite.com Logo
47 people viewed this question
Top myregisteredsite.com Computers & Internet Experts
David Payne
David Payne
Are you a myregisteredsite.com Computer and Internet Expert? Answer questions, earn points and help others
