Question about Sewing Machines
Need service manual for carpigiani lb502g gelato machine
We are running an american 60 hz machine on nz 50hz. machine will not advance properly through the production process
  • Sewing Machines Master
  • 1,388 Answers
Is it 110v, being a US machine ??
Posted on Apr 22, 2014
2 Suggested Answers
  • 492 Answers
SOURCE: My machine is in need of aservice
Try this site:http://www.sewingdirect.co.nz/
Posted on Apr 30, 2009
We are from South Africa and moved to Canada what do we need to change the volts and hz to use our Bernina Bernette embraudery machine?
probably nothing as they make the machine for the country's utility power supplies
you will have to go to places like JAYCAR to get a step down transformer or go to an electrical retailer to get an inverter to do what you want
go to a sewing machine repair shop and discuss the problem
Nov 25, 2016 | Bernina Sewing Machines
Fashion Mate c123162861 cat wvc 7-8 1.0 amp 60 hz. Where can I get a manual?
it goes by model number,maybe 5500,7256,258,237,362??? you need to know that number and then go here and put it in the box and get your manual there Instruction Manuals
this site has everything about singers,
singerco com
and sewing parts here,
http://www.sewingpartsonline.com/
May 27, 2015 | Singer Sewing Machines
What is the wattage of Kenmore 385.15202 sewing
The wattge used should be listed on the machine or it's wiring. If not, you should go to ( sears.com ) and find support. I do not see a problem using an outlet there from a public power as long as you have set the unit to use the correct cycles which is normally 50Hz or 60Hz. Some electronic devices such as yours will operate on either, but you will normally have a switch to manually set which Hz setting you need. The power you recieve from the utility will be either 50Hz or 60 Hz and you will have to set the unit to match the utilities rating. Best Wishes.
Sep 01, 2014 | Sewing Machines
I have a Husqvarna Classica 105 sewing machine that I bought about 15 years ago in the US and that I use mostly for mending and alterations. It is a great sewing machine and I had it serviced and tuned up...
The pedal is representative of the peal (which does not need a converter), but it is NOT representative of the motor. You need to examine the name plate of the motor itself.
You will discover that you need a converter.
Jun 03, 2011 | Husqvarna Sewing Machines
Our sewing machine is only running reverse (backwards) Can you please provide me we an service manual, type husqvarna 2000, modell 6440
You can find the service manual here.
http://www.sewingnz.com/categories/Husqvarna-Viking/
and a video on this page.
http://www.absolutesewing.co.nz/SewingHusqvarna.html
Your husqvarna 2000, model 6440 machines mechanical parts are in the need for a good clean and oiling. There is an explanation to this on the blog below.
http://sewingnz.blogspot.com/2011/04/repairing-reverse-on-husqvarna-2000.html
Apr 01, 2011 | Husqvarna Sewing Machines
Can I use my EuroPro 416 Sewing machine with 220V electricity?
A transformer will not change the frequency of the supply, only the voltage.
It may be possible to obtain a box of electronics to convert 50Hz to 60Hz, which would solve the problem.
A machine designed to run on 60Hz will run slower on 50Hz and may run hotter. If it burns out due to overheating, then a new motor designed to run at 50Hz should be fitted. You could have peace of mind if you fitted a new motor (which might be cheaper than an electronic frequency converter.
Jul 25, 2010 | Euro-Pro Sewing Machines
My Brother SE270D keeps jamming up and getting thread all tangled up The feed is not advancing either.
Make sure you are using 60 weight bobbin thread only in the bobbin, also make sure you are using only SA156 ( SFB-XA5539-151) bobbins, the size 156A are not for this machine. I have used Singer size 15J bobbins with no problem. The bobbin should have slightly rounded ends, not flat like a regular bobbin. This helps the thread over the bobbin at high speeds.
I threw my machine out of time the first three times I used it for embroidery and decorative stitches. Had I read the manual, I'd have known to use 60 wt bobbin thread. I have also used 90 wt with no problems...60 wt is what comes with the machine.
If you have to take the machine in for service, make sure to take sample of the problem and the embroidery unit, thread you used, etc. Take it all and tell them to test it all.
My Brother dealer felt these Disney machines were great little workers..and said they are not hard to repair...some dealers don't know enough about how to repair the thread cartridge, so tell you the machine is not worth repairing. It is...I've had mine for 4 years.
Hope this helps some. You may have to take the machine in to be timed / cleaned...once that's done and you are using proper thread and bobbins (upper thread - you can use any, bobbin it's 60wt)...you will love your machine.
Apr 14, 2010 | Brother SE-270D Computerized Sewing...
Apr 16, 2009 | Baby Lock Eclipse Serger
Switching from 110/60 to 220/50 power supply
Yes, you will need to get a transformer..try an electrical wholesaler and ask for a current converter.
May 09, 2008 | Husqvarna Lily 540 and 550
Janome memory craft 8000
We have about 30 electroluminescent backlights for the 8000 still available .These are not original Janome parts. You will need a Janome service person to install then for you as it requires taking apart alot of the machine to get to the display. We can provide instructions if this person is unsure how to fit. Once the display is out, the process is simple. They are AUD$60 each including shipping. Email at megan@christini.co.nz
Nov 24, 2007 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
76 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
