Question about Insignia 37" LCD Flat-Panel HDTV
Insignia ns-lcd37-09 Auto Channel Search won't save channels
Every time I do the auto channel search It finds a total of 103 channels. After thats done, I press either channel up or down and it tells me to do the auto channel search, so I do it again, and I get the same thing. I can change channels by pressing the numbers but not the channel button. Its getting kind of irritating. Its also hooked up to standard cable throughout an apartment complex with just a wire from the wall to the tv.
jerryg50
  • 1689 Answers
SOURCE: insignia NS-LCD32 TV
The tuner section, and or the voltage regulator circuit that supplies it is probably failing. The service rep for your set may be able to order a new tuner module and install it. This is not a type of repair you can do yourself.
Jerry G.
Posted on Jun 28, 2008
  • 2336 Answers
SOURCE: Insignia NS-LCD37-09 turns on but no image
If your TV is less then a year old, still under manufacturers warranty. If not under warranty the defective parts could be the power supply or the back light inverter board. Both boards can be replace easily.
The way to know if you have a defective backlight inverter is by shinning a light from a flash light near the screen with the TV on and check in a 45 degrees angle if you have a dark video in the background, if the video is present then you have a backlight board failure. If no video, then is a power supply failure.
I have both boards if you want to buy them.
Let me know if you require further assistance.
Posted on Jan 08, 2009
  • 27 Answers
SOURCE: Insignia TV is acting wierd
the problem lies in themain board in the tv. you can buy one from ebay for around $80 used. its not to bad to replace either. just remove the back panel the main board it the tin/ metal wit hthe ciruit board in it on the left side same side as the power botton just unplug the 5-7 wires and unscrew the 2-3 screws and carfully side that board out and replace with a new workign one and put back together and you should be good to go.
please rate my answer it is much apreceated
Posted on Feb 13, 2009
  • 280 Answers
SOURCE: Hello. I am contaqcting you
you could try a signal booter, sometimes they help. If you still do not get all your channels the tuner may be defective. They work in bands and may get some channels but not others. Low band, mid and high..
Posted on May 01, 2009
  • 814 Answers
SOURCE: the screen is cracked
You can try two sources for parts for your television. Best Buy Parts website. Just google it and put in your The name of the television and the model number. The parts finder will bring up all the available parts and their prices.If you cannot find the part there Try MCM parts (you can google this one too to find it) website and put in the name of the television and the model number and it will bring up all the available parts and their prices.The number for Best Buy Parts is :1-888-237-8289. The Number for MCM customer service is 1-877-626-3532, and for sales is 1-800-543-4330.Hope This helps you with your problem.
Posted on May 13, 2009
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
Auto Channel Search, how do you accomplish this.
Use your Insignia remote to select the initial set up procedure and run auto channel search.
Mar 03, 2015 | Insignia Solutions NS-24E200NA14 24" LED...
How do i finde auto chanel seargh
Auto channel search is how your tv finds channels that are available. Under settings in the menu should be initial set up. There you will find channel search.
Feb 20, 2015 | Insignia Televison & Video
Need to scan channels
you can do the auto search channel. just press the tv menu and then find the channel search and select auto search. so that all available local channel will tuned.
Aug 30, 2012 | Insignia NS-LTDVD19-09 LCD TV
19" LED TV INSIGNIA HD
I have one of the same tvs. Start by going under menu,setup,tuning band and set it up for antenna. When you get that far put in auto channel search. To see how to get best reception where you live go to http://www.antennaweb.org
Comment if you need any further help
Mar 17, 2010 | Insignia NS-LCD19 19 in. LCD TV
Insignia NS-L42Q-10A Setup: Wrong TV Source Chosen
You can change this option by going to the "Channels" menu and selecting "Auto Channel Search." Additional details can be foundat InsigniaProducts.com, under the Support tab for your TV.
Mar 09, 2010 | Insignia NS-L42Q-10A LCD TV
Auto Search Function won't work...."can't set auto search"
Make sure that you have the cable option set correctly before you do the auto search. If this is set to "AIR", you'll only be searching for an analog signal. Hope this helps.
May 24, 2009 | Insignia IS 20" TV040919 TV
Not getting channels....
Hi
Please install the antenna Cable or CTV Cable, then go to settings then run the auto search to find the available channel for your Tv.
Thanks!
Dec 27, 2008 | Insignia NS- 27" TV27 TV
Insignia 37" LCD Flat-Panel HDTV Logo
145 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
