Question about Garden
Yardman troubleshooting Manuel engaging the cutting blade by pulling the lever across engine starts to stall disengage and the engine runs fine
    Problem Solver:
  • 8 Answers
More than likely the bearings on the mower deck that your lawnmower blades bolt to are seized or are close to it .Disconnect the negative battery cable from battery before you get anywhere near the underside where the blades do there business. Better yet, remove battery completely, and have it tested at AUTOZONE for free. While battery is out , check free spin of deck blades. Any resistance or grinding while blades are disengaged >debris , fence wire , rope tarp, etc.. or bearing failure. [DUE TO THE NATURE OF THIS PROBLEM AND THE POSSIBILITY OF SERIOUS INJURY, I WOULD STRONGLY RECOMMEND TAKING IT TO BE CHECKED AT INDY SHOP. ... ALTHOUGH COMMON SENSE WILL GO FAR IF YER MECHANICALLY INCLINED. .. YOU TUBES VIDS ARE A GOOD STARTING POINT. NOTE:BEARINGS CAN BE REPLACED,, WHEREAS A HAND OR A FOOT ...AINT AS EASY. Good luck
Posted on Apr 15, 2014
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
  • 202 Answers
SOURCE: Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Posted on Jul 24, 2009
SeaDaddy46
SOURCE: Craftsman GT5000: Dies when switch is pulled to engage blades
I have the same tractor. If you have the transmission in <reverse> this will happen every time. It's a safety feature. Be sure the tractor is in <neutral> or one of the 6 forward gears.
Jim Romines
Posted on Jul 31, 2009
  • 636 Answers
SOURCE: craftsman riding mower blades won't disengage
Sounds like the shear bolt is broken, Do you have and owners manual to show you the location of shear bolt? They are easily replaced.
Posted on Aug 15, 2009
Goes dead when disengaging brak
Lawn Tractor stalls after engaging blades or releasing brake ...
www.shopyourway.com > Manage My Life > Questions
Scenario 2: Engine started, as above in scenario 1 and manaul brake lever is engaged. Again ... Lawn Tractor stalls after engaging blades or releasing brake .... I am goingto replace that anyway but it almost seems my problem is electrica
Sep 14, 2015 | Garden
Disengage the blades on a MTD yardman 42 cut 18Hp
There should be a PTO lever on the right side. Slide back to disengage.
Oct 10, 2014 | Garden
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
Reverse operating system
Check the switch down by the gear shift lever, and the wiring to the switch, if one of the wires has come off the switch it will give problems.
May 30, 2013 | Husqvarna YTH22V46 46 inch 22 HP Briggs &...
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
May 14, 2009 | Mtd Garden
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
