Question about Refrigerators
Dometic rm2604 I have a rm 3605frige that will not light in gas mode. When I push the button the light will not come on and the pilot will not light. I can light the ffrige pilot with a match while having someone hold the button. Can you help me trouble shoot this problem. Thanks in advance. Pat @ fastpat2@gmail.com
  • Charles P Hayes
    Charles P Hayes Mar 24, 2014
    The electronic ignighter is not working. I can light the pilot with a lighter and the fridge works. Where is the ignighter located and can it be tested to see if its working properly?
  • 93 Answers
SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Posted on Mar 15, 2009
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
SOURCE: Refrigerator doesn't work in gas mode
Verify that you have gas at the pilot and that the spark ignitor is clean. Might be a good idea to get a vacum and clean that area out.
Posted on Jul 24, 2009
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
SOURCE: RM 2652 will not get cold
Check the 5 amp buss fuse behind the frig.
Posted on Apr 10, 2010
My camper has a dometic RM2652 refrig. the electric works, but it won't transfer to butane
Most dometic refrigerator have a button you need to push when you shift the mode switch to gas. This button holds the gas valve open until the thermopile generates enough power to hold the valve open. So on most shift the mode switch to gas, hold the button until the flashing light goes out. The flashing light indicates the gas valve is energized and the unit has shifted to gas mode. Depending on when the unit was last used it may take up to 5 minutes for the gas supply to purge the gas lines to the refrigerator. So be patient.
Hope this helps.
Oct 15, 2014 | Dometic RM2652 Refrigerator
Dometic rm2652 check light comes on in gas mode while traveling
possible wind blowing out pilot clean gas line to ignitor
Mar 24, 2013 | Dometic RM2652 Refrigerator
Apr 04, 2010 | Dometic RM2652 Refrigerator
Jul 24, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
