Question about Prestige Remote Start
Not enough voltage comes out of remote starter to start car
Most of the time the remote start wont start my 1994 Olds Took it to the mechanic we replaced the started and it still has starting problems even with key. Would appear not enough voltage is coming out of the remote to start the car. What can I do
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
Ck. your battery or jump car and see how it starts if the same. you could have cable or connection problem. Could be a bad starter! or battery. Some auto part stores will check it for free.
Posted on Apr 30, 2014
  • 1455 Answers
SOURCE: I have a new prestige APS-57C remote starter
Maybe the installer did not hook up the remote starter unit to disarm the factory security system upon entry or remote-starting. Ask the installer to double check that part of the install as it would cause the factory security to trigger even though you unlocked the vehicle with the remote start unit remote.
Posted on Jan 25, 2011
  • 13 Answers
SOURCE: prestige aps-57 remote start...car won't start
Hello hope this can help you. First check the starter wire, it is tan/lt blue located at the ignition harness. usualy during installation of the remote start system this wire is cut leaving you with two ends. one wire is coming from the ignition switch the other is going to the starter. the brain of the alarm hooks into both of these wires. if the repair man cut the wires from the brain and spliced them together he has just put the system back to OEM status leaving the alarm no way to engage the starter. I believe that may be where the problem lies but if not then I would say check your immobilizer bypass module the repair man mave have diconected that.
Thank you,
Luis
Posted on Dec 04, 2008
doin12volt
  • 233 Answers
SOURCE: Lights don't blink for remote start
If you look at the unit (probably installed under the dashboard, on the drivers side) You can see the wires going into the unit... Follow the wires back and you will find that 2 of them have in-line blade style fuses, it sounds like the fuse in the parking light output wire has blown. if you find the fuse is blown, replace it and the parking lights should be on again when you remote start it.
Posted on Jan 03, 2009
  • 12 Answers
SOURCE: AUDISVOX REMOTE START APS-620 WONT START AT TIMES.
i am an mecp first class certified mobile installation technician with over 10 years experience. email me at face2face11@bellsouth.net and i'll see if i can help
Posted on Jan 15, 2009
  • 87 Answers
SOURCE: My audiovox dealer installed remote starter starts
It dosent sound like there is a transponder bypass installed or installed correctlt, I dont know the year make and model of car but that sounds like what it would be
Posted on Jun 04, 2009
On my 1994 olds 98 it won't start no voltage at the C3i harness connector.
Can we back up??? So there is no Voltage getting to where? Is there Power to the Starter? Power to the Pump? Power going into the Computer but no signal coming out?
Apr 10, 2013 | 1994 Oldsmobile Ninety Eight
1994 olds 88 Wont start up. Battery problems?
Put another battry in and see sounds like battry
Nov 13, 2011 | 1994 Oldsmobile 88
Car wont start..turning the ignition and it wont make any noise at all, absolutely nothing. not even a click. power comes on though. any ideas?
Extremely low voltage from battery. If you are under 9 or 10 volts you can power anything in the car but it isn't enough to engage the starter. Before you buy a battery try cleaning the connection sometimes thats all it takes.
Mar 08, 2011 | 1994 Chrysler LHS
For about 2 weeks my car has been hard to start now it wont start it acts like the starter is not engaging to turn motor over when you try to start it it makes a whinning spinning noise we took starter off...
sounds like the battery wire to the starter is possibly the culprit, it may have a bad spot in it not allowing enough voltage to the starter. also depending on the brand solenoid you purchased it is possible to get a bad one. i recommend borg warner electrical products. i hope this helps.
Feb 13, 2011 | 1994 Lincoln Continental
1994 buick lesabre intermitten no start.how to make sure it is the ignition switch.
What I would check first is the starter, when it don't wont to start, with a test light check voltage down at starter, the small wire on the starter come's from the ignition switch, while some one holds the key to start check voltage at small wire, there should be voltage there as long as key is held on start, on the big wire at starter it should always have voltage with key on or off, if you do have voltage replace starter intermitly going out, now if you don't have voltage at small wire, check or replace neutral safety switch.
Jun 10, 2010 | 1994 Buick LeSabre
Ignition switch problems
2001 gmc jimmy 4wd---put key in ignition--all lights and radio come on--no clicking or noise it just wont crank at all-replaced battery already--what the problem?
Oct 18, 2008 | 1991 Cadillac Seville
Doesn t start
Had the same problem, took it ti nissan service centres 3 times, kept replacing stuff no solution. took it to an independant mechanic, said the voltage that the ignition is sending through to the starter is too high & added a voltage control relay into the wiring.no problem since.
Jun 01, 2008 | 1997 Nissan Pickup
Prestige Remote Start Logo
134 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
xxxxxx xxx
Glen Weitzdoerfer
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
