Question about Behringer Xenyx 1002 10-Input 2-Bus Mixer
Can't connect mixer to pro tools
Want to use the mixer with pro tools
    Champion:
  • 219 Answers
Either you got the wrong software (or drivers) or you are using the wrong Operating System (PC / MAC) OR your USB driver is blown on the board by not connecting right. Let me know. Behringer replacements are a pain. PLUS if THAT is the case, you need a savvy techie with the right soldering tools.
Posted on Apr 27, 2014
Where do you connect a midi controller on a Behringer Xenyx 1204usb mixer?
You can connect where it is possible. I hope you will understand.
Aug 04, 2016 | Behringer Music
How to connect behringer xenyx 1204usb mixer to a numark mixtrack pro II dj controller?
you have to tell your dj or studio program which device to use as output, but the dj controller doesn't have an audiocard so now i first have to search myself since my mixers have built in serato and another that annoying native i. No i'm just doing difficult while a numarkx5 stands in front of me and the main outputs go to your mixer and your usb is just for recording , but plug the mixer out in the mixer , main out in your monitors and calibrate the sound, but your studie or dj gear wants to know which channel to use and there fore you need to read the manual of your mixer and behringer. It's easy, but not from here.
Jul 27, 2014 | Behringer Xenyx 1204USB
Can I connect this mixer without having to buy an additional pice of equipment?
You will need speaker(s), amplifier and appropriate wire. I see no problem with the Traktor pro
You can get the manual at: http://www.behringer.com/assets/DJX900USB_P0A56_M_EN.pdf
May 20, 2013 | Behringer Djx900usb 5-channel Dj Mixer...
Power mixer to a power amp.
You have two aux sends on that mixer so quite easy to use one of those to feed the external power amp. You could have one set of spkrs connected to that amp and another connected to the powered mixer. This would give you full independent control over each set.
Aug 09, 2012 | Samson Xm910 8Channel Powered Mixer...
Can i use the 002 rack as a standalone mixer without pro tools running
Unlike some RME products, the 002 rack has no ability to run as a standalone mixer. All routing/mixing is controlled via the pro tools software.
Jan 13, 2011 | Digi 002 Rack FireWire-based Pro Tools LE...
How do I set this up as my main input device in protools?
Early versions of Pro Tools do not support Behringer devices.
The newly released Pro Tools 9 can be calibrated through the Pro Tool Aggregate I/O in your audio/midi settings.
Good Luck, Cody J.
Dec 14, 2010 | Behringer XENYX 2442FX Mixer
How do we connect an m audio fast track pro to my pc and mixer (dp-01fx)?
All you have to do is to connect with 2 cables your mixer's output to the two 1/4” TS plus in the front side of the Fast Track Pro and a usb cable from the rear panel of the Fast Track Pro to your pc's usb port. I suppose that you have installed the drivers for Fast Track Pro at your pc.
Anyway in case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 20, 2010 | M-Audio Fast Track Pro Mobile USB...
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Oct 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Home Studio Set Up
get an other sound card
Jul 26, 2009 | Computers & Internet
Behringer Xenyx 1002 10-Input 2-Bus Mixer Logo
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
