APC 10kva displaying a fault light when put on battery
  • 1,162 Answers
Check battery, most likely its bad.
Posted on Mar 24, 2014
I have a problem with 4 XR frames the UPS see's them as 1,4,2,3 instead of 1,2,3,4
well as long as the ups sees them all , im not clear why that's a problem , but anyways this is a common thing that happens when doing a hot swap battery replacement , anyway if you really want to reset them back in order then you'll need to bypass the load (or remove it) power down ups and remove its input power too then remove all four trays of battery's , wait a few minutes till the caps die off and then put trays back in the sequence you wish it to be , then repower input wait 4 it to go online (5 min) and then add back load , this should make it go back to a fresh start up , but yo'll need to do this each time you remove trays
Feb 04, 2016 | APC Computers & Internet
APC SURT3000XL UPS
The fault indicator means that there is a fault in the circuitry of the UPS. It could be the control board or another part of the system. (If the batteries were bad, you would see the Replace Battery light illuminate.) If the SURT3000XL is under warranty, contact APC. The standard warranty period is 2 years for repair/replacement. Note: you'll probably have to pay for the shipping of the unit. If the unit is out of warranty, replace it with a new UPS.
I hope this helps.
Nov 13, 2013 | APC Computers & Internet
Smart UPS VT 10KVA fault "Mains Not Available. Input Freq/Volt Out of Range". All phases input and output giving the expected voltages 240V and frequency OK at 50Hz.
Sounds like you hooked up the input to the UPS on the bypass. Either way either way your input is not there. Also make sure you configure the UPS prior to placing online.
Oct 04, 2013 | APC Smart-UPS VT 10kVA - SUVT10KH2B2S UPS...
Site wiring fault
Hi Viqtah, (<------ Clever!!)
If you hit the ESC key and get to the main menu there is a Setup submenu. In there you can change the line voltage values coming into the UPS. Sometimes a previous owner will change those values and cause the UPS to fault when properly connected. NOTE: A CERTIFIED ELECTRICIAN SHOULD VERIFY ALL CONNECTIONS ENSURE PROPER PHASE ROTATION.
Reply or call if you have any more questions -- 800.260.2259
Light fault
Go into the UPS display or the Software and list the fault. Display Menu -> Fualts & Diagnositics -> Faults
Please list the fault in order to help :)
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Aug 19, 2013 | APC Smart-UPS VT 20kVA (SUVT20KF3B4S) UPS...
Apc 10kva SUVT10KH4B4S problem after changing battery
please you know your topology change battery
Jul 22, 2013 | Computers & Internet
APC 10kva UPS SUVTP10KH1B2S is not turning on
check the battery bank, and the battery must be in good condition
May 13, 2013 | APC Smart-UPS VT SUVTP10KH1B2S UPS System
Hi, We have purchased some APC 10KVa Smart UPSes and the firstone, when wired up to a single phase 63A supply, shows an internal fault (Red X) and battery lights 1 and 4 are on. This looks like a code...
The manual for your model APC UPS is available from their WEB site. Go to this WEB site for the info. your require.
http://www.apc.com/resource/include/techspec_index.cfm?base_sku=SUrt10000xli
May 09, 2011 | APC Computers & Internet
APC BR1500LCD Fault F01
This is a printout of the fault codes
System Fault indicator is on and all other
front panel indicators are flashing.
Internal UPS fault. One of nine Internal UPS Fault Messages is displayed:
F01 - On-Battery Overload F06 - Relay Welding
F02 - On-Battery Output Short F07 - Temperature
F03 - On-Battery XCap Overload F08 - Fan Fault
F04 - Clamp Short F09 - Internal Fault
F05 - Charger Fault
Nov 23, 2009 | APC BR1500LCD UPS System
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
