I have a Phillips plasma tv model number - Televison & Video
I have a Phillips plasma tv model number 42PF5521D/10 serial number VN4B0708013071 i was watching it on 1 of the 2 hdmi channels when all of a sudden it just went off when I turned it back on all I had was sound no pic ands its like that on hdmi 1&2 if tried different leads can anyone help thanks in advance
    Habit-Forming:
  • 84 Answers
Does it work on the cable/antenna input jack? Can you get the menu screen to show up? If none of the inputs work and you can't get a menu screen to show up, then it sounds like you may have a bad YSUS driver board.
Posted on Mar 22, 2014
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
TH-42PX60U wont turn on. Blinks 10 times. replaced the power supply board, but the same issue.
What I'm learning is there are several models of Panasonic TV's that have a video card that doesn't play well with HDMI applications and the end result is, you need to call this number and not only make arrangements to replace the bad board,but also this!
Your model doesn't show below,but I'd certinly inquire about the necessity of a "Firmware" update!,,,Panasonic knows FULL WELL they have a HUGE problem here!
Hope this helps!
At panasonic.ca I found the listing for the fw update under customer support-important notices
If you own a plasma TV with model and serial number within the range specified below, please contact our toll-free VIERA Concierge hotline service at 1-866-330-0014. A VIERA product expert will arrange an in-home software update for your TV at your convenience.
Model Numbers Serial Number Range
TH-42PZ77U
TH-42PZ700U **71250001 ~ **80189999
TH-42PZ700UA
Jan 28, 2010 | Panasonic TH-42PX60U Television
Plasma tv just blanked out on me
parts is not a problem.as long as it has the same serial numbers and other specs.
May 29, 2009 | Dell W4201C 42 in. Plasma HDTV
Panasonic home theater
switch the HDMI cable to another HDMI port (if available).
or use and AVI/COMPONENT to make sure the device (HOME THEATHER) is working fine.
Try also another HDMI cable or hook another device into it to see how it works.
If you determine the HDMI port in not working properly, then your Mainboard is damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 14, 2009 | LG 50PG20 50 in. Plasma HDTV
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Need settings because of rubbish picture
There is no right or wrong setting for the TV, but I find the following give about the best results:
  • Contrast - 65 maximum
  • Sharpness - 2 maximum
If these are set any higher, the picture becomes very grainy, particularly around defined shapes.
  • Contrast + - OFF
  • NR - ON (If applicable)
These settings will need to be changed for each of the following:
HDMI 1& 2
  • EXT 1, 2 & 3
  • Analogue tuner
  • Digital tuner
The problem you describe, is usually with a satellite or cable box.
Unfortunately, there's nothing much you can do about the dead pixels, but the settings may make them less obvious.
May 01, 2008 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Lines across screen when using View On Demand channels
Could be a couple of things causing this.
1) Obvious, but I assume that you subscribe to these services, because otherwise it could be the encryption.
2) Make sure that you have the set-top box connected directly to the TV, and not through an external recorder (VCR, DVD etc)
This would be a problem if the services were copy protected in the same way DVDs are.
You could also check the settings on the set-topbox. Make sure the video output is set to RGB.
Aug 05, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Ilo 42 inch Plasma TV
I have a Ilo 42 inch Plasma TV and it just stop playing, the power light comes on but the screen don't light up at all
Jul 24, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
