Question about ASUS Eee 1215N-PU17-SL Notebook
Won't charge battery
Works without battery screen flickers
  • ASUS Master
  • 3,320 Answers
This site carries replacement batteries: Laptop Battery for Asus EEE PC 1215N PU17 SL 6 cell 4400mAh
Posted on Mar 22, 2014
Sometimes the car won't start and the dash lights and the radio lights flicker
Best place to start is the positive lead on the battery . Remove the lead and clean battery pole and terminal using sand paper until you have shiny syrfaces. Replace the lead and tighten the terminal . Check the battery for charge condition as what you describe indicates a flat battery
Feb 10, 2013 | Cars & Trucks
Pentax Optio P80 battery won't charge all the way
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 01, 2012 | Pentax Cameras
Battery won't charge.. dash lights flicker
Hello, guys. You can try these OBD2 tools to find your car problem.
Sep 05, 2012 | 2000 Plymouth Voyager
Laptop screen flickering when battery charging
The power supply adapter may not be delivering enough power when you run it and trying to charge the battery at the same time. The only way to find out is sub another power supply.
Jun 19, 2012 | Toshiba (M305-S4910) PC Notebook
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
. I bought an Amcor AWS090HR a couple of years ago
?Call pridiom group 201-266-8234 option 2 for warranty and service
?*Self Diagnosis Functions*
Our company provides the thoughtful services for customer,air conditioners had been
installed self diagnosis system to display the information for the units.
INSTALLATION & REPAIR GUIDE
Split Wall-Mounted air conditioner
8
*According to the service conditions and operating environment , the inside of the air conditioner
will become dirty after several seasons (3 to 5years ) of service , resulting in decreased operating
performance .Inspection and maintenance are recommended in addition to usual cleaning (The
air conditioner can be used for a longer period and without anxiety .)
*As to inspection and maintenance , consult your dealer or any one of business offices of dealing
companies .(Service charge is required in this case .)
*We recommend to perform inspection and maintenance during an off seasons.
*Choose the place where hot air and operation noise from the outlet of the outdoor unit do not annoy
the neighborhood .
*Things left near the outlet and inlet of the outdoor unit cause malfunction or increased operation
noise . Do not leave obstacles near the outlet and inlet .
*If irregular sound is heard during operation , consult with your distributor .
*Inspection and Maintenance
Note:Above self check information is commonly applicable in our most air conditioners,but some
are special,you can refer to the User's Manual for information or contact the dealer or authorized
maintenance people for help.
Digital self-check code/
(Polychrome screen self-check code)
Hint to defrosting Flicker 1 time/1s
Hint to defense
against cold wind Flicker 1 time/3s
Failure of room
temperature sensor
Failure of coiled
pipe sensor
Abnormality of
outdoor unit
Without feedback of
internal fan motor
Zero crossing signal
without current
External feedback
failure
Overheat protection
Water pump failure
Self-check code of luminotron/
(Self-check code of running lamp)
Flicker 2 times/4s
(Flicker 2 times/8s)
Flicker 3 times/5s
(Flicker 1 time/8s)
Flicker 4 times/6s
(luminating)
Flicker 5 times/7s
(Flicker 6 times/8s)
Flicker 6 times/8s
Flicker 7 times/9s
Flicker 8 times/10s
Flicker 9 times/11s
Self-check
information
Indicates "dF"or defrosting
indicator displays
Fan motor picture not running
E2/(L2)
E3/(L1)
E4/(E5)
E5/(L6)
E7
E6
E8
E9
Nov 30, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
When I plug my adapter in the screen starts to flicker or blink. It has never crashed - and it shows that the battery is charging. I had just replaced the battery and so I thought it was a bad adapter. I...
Bad luck... still you cannot make an omelet without braking eggs... this is the only way to prove things so you were right to introduce a Know Good, into the equation. Sometimes it takes while for battery to charge, make SURE your adapter is OK. Will it work ONLY from adapter? ONLY from Battery?... maybe your power connection in, is broke?
Feb 08, 2010 | Dell Inspiron E1505 Notebook
Flickering screen - Acer (laptop) 1690 series
You have two problems and they are separate issues.
First your battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and as the battery ages the charge capacity will drop. When the battery is worn out, it may not charge at all or show it is 100% charged but when you remove the AC power the laptop will shut off because the battery is dead. A new battery is required to fix this problem.
Second when you connect the AC adapter into the laptop's power socket, and the screen flickers and the charge LED also flicks, it means the power socket is faulty or the power socket has a dry solder joint connection to the motherboard. If you hold the power plug in a particular position you should notice the charge LED will stay on without flickering as well as the LCD screen.
This fault can be repaired, but it requires the laptop to be dismantled completely to access the power socket. I suggest you get a quote first.
Sep 06, 2009 | Acer Aspire One A150-1006 Notebook
ASUS Eee 1215N-PU17-SL Notebook Logo
67 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
