Epson WorkForce WF-3540 Wireless All-in-One Color Inkjet Printer, Logo
t
thomas Posted on Mar 21, 2014
Light line every inch
Has a line every inch
bsla35
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on May 06, 2014
bsla35
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
3228
Points
18
Go to the Epson website (Epson.com) and select your location and feed in the printer model information as requested on the downloads area. Download and install the latest printer software (includes drivers) and see of that cures the problem. Once done, assume it is a newly installed printer and go into the printer's Properties dialogue box, click on the Advanced page and select to run the alignment procedure.
3answers
Copies paper great except leaves a long invisible 1 inch thick line down the middle
You can try to clean the scanner light, but the light does not cast a straight one directional beam. It is more like a flood light, if one spot is blocked it will still cast light on that spot of the paper.
Try checking the print cartridge. Normally if it is an inkjet copier, it will leave a line in one spot if there is a defect in the cartridge or if it is running low on ink.
I woul try another cartridge first, then we can go from there.
I have 96 ford explorer have found a hole in metal brake line this part of the line has some sought of light metal insulation and is only about four inches longhand has two like moulded fittings either...
Any part of the brake line is replaceable. If there are fittings on either end e Than it is as simple as removing the old piece, buying a piece of brake line with the same fittings, bending the new line to fit in the space, tightening the fittings on the new line, and then bleeding the brakes.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
What are the different lengths of
The slim-line edition of fluorescent tubes has a 1 inch diameter, and come in three different sizes, 24 inches, 36 inches and 4 inches.
Aug 21, 2012 • Fish
All printouts have a 3/8 inch wide light vertical line -
Try an old toner cartridge if you have one. Does it do it when you use the copier function. Steven 805-520-3003
3helpful
How do you adjust headlights on a 1993 chevy C1500
if you look at the light, there is an adjustment screw at the top of the light that controls the up and down motion , clockwise will raise the beam, and a screw on the side that controls the side to side motion. the best way to center your lights would be to park the vehicle 25 feet away from a verticle wall. be sure to be very square to the wall and on level ground. make a tape line vertically on the wall in very close relation to the center of the vehicle, and another tape line vertically in very close relation to the center of each headlight. now place a tape line horizontally in very close relation to the center of the headlights. start with low beam adjustment. adjust the high intensity zone to 2 inches below the horizontal line and 2 inches to the inside of the vertical line directly in front of the headlight. for high beam adjustment, adjust so that the high intensity zone is centered on the center vertical line and just below the horizontal line. hope this helps
1helpful
After every line of black text there is a light blue line.
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Line down the center from top to bottom, 1/2 inch very light , NOT folded.
hi swan.. i am doing some homework on this i got a similar set today.. will get back to you shortly
3helpful
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
