Question about RTO Sole F80 Treadmill
Nothing wrong just irratating, when I set speed at 3.5 mph and time at 60 minutes the program stops at 3.4 miles and doesn't finish lap 14. Is there any way to change the pace from 17:09 to 17:08 so i
Incorrect readout
The track at Oak Middle School is 1/4 of a mile for each lap. Jacob walked around the track and completed 7 laps in 30 minutes. What is the unit rate of Jacob's speed?
I edited the question to show 1/4 mile. Jacob walked 7X1/4 that is 1 and 1/4 miles. 1.25 / 30 = .041 miles in 1/2 hr. .041 x 2 is .082 miles an hour.
Dec 13, 2016 | The Watches
What is the drive cycle for a 2003 Nissan Sentra SE?
Take extra caution while performing dirve cycles on public roadways. Drive cycles can be difficult to follow under normal driving conditions. Begin by: - Start the engine. Idle the engine in drive for two and a half minutes with the A/C and rear defroster on. - Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle. - Hold at a steady speed of 55 mph for three minutes. - Decelerate (coast down) to 20 mph without braking or depressing the clutch. - Accelerate back to 55 to 60 mph at ¾ throttle. - Hold at a steady speed of 55 to 60 mph for five minutes. - Decelerate (coast down) to a stop without braking. If all other emissions systems are functioning properly, completing the drive cycle above will set the "readiness flags" required to pass the smog check. It will not hurt to perform the drive cycle 2 or 3 times before the smog test.
Oct 06, 2016 | 2003 Nissan Sentra
Car bucking at speeds above 60 mph
could be sensor has failed or could be in need of tuneup...
Aug 16, 2012 | 2000 Volkswagen Beetle
Obd2 system rediness status won't clear so I can run the smog test due to replacing the battery.
takes a long time to run the rediness test since there are 6 different tests to complete...
PROCEDURE 1
EVAPORATIVE EMISSION SYSTEM LEAK MONITOR
Inspection Conditions
Engine coolant temperature: 30°C (75°F) or less (The engine is stopped before the test drive is started).
Atmospheric temperature: 5 - 30°C (41 - 113°F).
Condition of A/T: Selector lever D range.
Fuel remained in fuel tank: 30 - 50% is recommended.
Time required: 16 minutes or less after started the engine.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position. Well be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 89 km/h (55 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 16 minutes.
Return the vehicle to the shop, then turn the ignition switch to "LOCK" (OFF) position.
PROCEDURE 2
FUEL TRIM MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or less.
Atmospheric temperature: -10 - 60°C (14 - 140°F).
Time required: 30 minutes or more.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position). Will be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 30 minutes.
PROCEDURE 3
CATALYTIC CONVERTER MONITOR
Drive Cycle Pattern
Atmospheric temperature: -10°C (14°F) or more.
Engine coolant temperature: Not set.
Time required: 16 minutes or more.
Test Procedure
Engine: start.
Travel for 300 seconds or more while keeping the vehicle speed at 89 km/h (55 mph) or more.
Decelerate until the vehicle speed is within 80 km/h (50 mph) or less.
While traveling at 56 - 80 km/h (35 - 50 mph) for 10 minutes or more, fully close the throttle at least once in 2 minutes and decelerate for 10 seconds or more.
Do not repeat deceleration too often.
Vehicle speed may go below 56 km/h (35 mph) after the deceleration.
Stopping and braking are permitted. (If stopped or drive at 56 km/h (35 mph) or less for more than 5 minutes the monitoring may be stopped. In this case please restart monitoring from the beginning.)
After completing the above deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 5 times.
PROCEDURE 4
HEATED OXYGEN SENSOR MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or more.
Atmospheric temperature: -10°C - 60°C (14 - 140°F) or more.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 56 - 80 km/h (35 - 50 mph).
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 - 80 km/h (35 - 50 mph) and travel for 16 minutes or more.
Stopping and braking during this operation are permitted. Keep the accelerator opening degree constant for 1 minute or more after each acceleration.
PROCEDURE 5
EXHAUST GAS RECIRCULATION (EGR) SYSTEM MONITOR
Drive Cycle Pattern
Atmospheric temperature: 5 - 60°C (41 - 140°F).
A/C switch: OFF.
Test Procedure
Engine: start.
While traveling 16 minutes or more at 56 - 80 km/h (35 - 50 mph) with engine speed 2,000 r/min or above, fully close the throttle at decelerate for 5 seconds or more until the engine speed reaches 1,000 r/min or under.
Stopping and braking are permitted (Rapid deceleration and sharp steering are not permitted).
After completing the deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 8 times by fully closing the throttle valve.
PROCEDURE 6
OTHER MONITOR (Main Components, Sensors & Switches, Wire Breakage & Short Circuit)
Drive Cycle Pattern
100°C (212°F) or less (Except engine coolant temperature sensor monitoring).
30°C (86°F) or less (Engine coolant temperature sensor monitoring).
5°C (41°F) or more (Except engine coolant temperature sensor monitoring).
-10°C (14°F) or less (Engine coolant temperature sensor monitoring).
Time required: 21 minutes or more.
Test Procedure
Engine: start
Accelerate until the vehicle speed is 56 km/h (35 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 km/h (35 mph) or more and travel for 16 minutes or more.
Return the vehicle to the shop.
After stopping the vehicle, continue idling for 5 minutes, and then turn the ignition switch to the "LOCK" (OFF) position. Moreover, the vehicle should be set to the following conditions for idling.
A/C switch: OFF
Lights and all accessories: OFF
Transmission: Neutral
Sep 15, 2010 | 1998 Mitsubishi Eclipse
Reset computer in doege stratus wont pass inspection drove 50 miles and computer still didnt reset help
U have to operate the engine at all kinds of diff speeds and drive modes, it is called a OBDII drive cycle, here is how u do one.
1. As soon as the engine starts, idle the engine in drive for two and a half minutes with the A/C and rear defrost on. OBDII checks oxygen sensor heater circuits, air pump and EVAP purge.
2. Turn the A/C and rear defrost off, and accelerate to 55 mph at half throttle. OBDII checks for ignition misfire, fuel2_bing.gif trim and canister purge.
3. Hold at a steady state speed of 55 mph for three minutes.
OBDII monitors EGR, air pump, O2 sensors and canister purge.
4. Decelerate (coast down) to 20 mph without braking or depressing the clutch. OBDII checks EGR and purge functions.
5. Accelerate back to 55 to 60 mph at half throttle. OBDII checks misfire, fuel trim and purge again.
6. Hold at a steady speed of 55 to 60 mph for five minutes.
OBDII monitors catalytic converter efficiency, misfire, EGR, fuel trim, oxygen sensors and purge functions.
7. Decelerate (coast down) to a stop without braking. OBDII makes a final check of EGR and canister purge
Jun 02, 2010 | 2004 Dodge Stratus
I have a 2001 nissan pathfinder 4w. The OBD system-readiness status: Says catalytic converters, NOT READY; oxygen sensors, NOT READY; evaporative system, NOT READY. So did not pass inspection, I was told...
You have to re-set the obd via using Nissan's approved drive-cycle which is;
1. Start the engine when the engine coolant
temperature gauge needle points to C. Allow
the engine to idle until the gauge needle
points between the C and H (normal operating
temperature).
2. Accelerate the vehicle to 55 MPH (88
km/h), then quickly release the accelerator
pedal completely and keep it released for at
least 6 seconds.
3. Quickly depress the accelerator pedal for a
moment, then drive the vehicle at a speed
of 53 to 60 MPH (86 to 96 km/h) for at least
5 minutes.
4. Stop the vehicle.
5. Accelerate the vehicle to 35 MPH (55 km/h)
and maintain the speed for 20 seconds.
6. Repeat steps 4 through 5 at least 3 times.
7. Accelerate the vehicle to 55 MPH (88 km/h)
and maintain the speed for at least 3 minutes.
8. Stop the vehicle and turn the engine off.
9. Repeat steps 1 through 8 at least one more
time.
If step 1 through 7 is interrupted, repeat the
preceding step. Any safe driving mode is acceptable
between steps. Do not stop the engine
until step 7 is completed. If you cannot or
do not want to perform the driving pattern, a
NISSAN dealer can conduct it for you.
Nov 15, 2009 | 2001 Nissan Frontier Crew Cab
RTO Sole F80 Treadmill Logo
61 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
