Question about Tablets & eReaders
Pioneer r-1 tablet won't turn on
Charger fits loose, could that be the problem? holding down power button brings quick white flash after about 8 seconds, pushing reset button has worked before, but now it does nothing...where can I get a replacement charger? this is still under warranty but Pioneer won't get back to me
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
  • Enjoy best product with smart IC intelligent identification your device electricity to protect your device,Intelligently detects your devices to deliver the fastest possible, while avoiding overloading, overcharging and overheating.
Chornic Quick Charge 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Posted on Dec 24, 2016
    New Friend:
  • 36 Answers
Cant you just take it back to shop.
Posted on Mar 22, 2014
SOURCE: I want to hard reset
how to hard rest Samsung Galaxy Tab Tablet PC
press and hold -sound and power for 5 second you well open recovre mod press hard reset and press the long words and write yes the phone well restart and well pe in factore mod
Posted on Jun 05, 2013
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
SOURCE: tablet wont power on. Holding
do one thing Turn Off Your Tablet
-> Hold Volume Button and Power button for 3 to 5 Secs -> You will see a screen with android and triangle with exclamation mark -> you will also see 4 lines of writing in blue. -> use volume buttons to navigate to 3rd option, use home to select it ( warning this will erase your system data if need please take backup) (memory card is not affected) -> now navigate to 1st option saying " reboot to system" use home key to select it.
I hope this will fix things
Posted on Apr 04, 2011
  • 167 Answers
SOURCE: nextbook will not com on
check the battery otherwise it is the hardware problem in your tablet pc
Posted on Jun 26, 2012
andrewpwrp2p
  • 229 Answers
SOURCE: i want to reset my daughters android tablet 4.0
To reset the tablet, you're going to have to do what's called a factory reset. To do this go into the settings, and look for tablet information. Under that it should contain a factory reset button.
Posted on Feb 26, 2013
Wopad 7 TABLET IS A TRIAL version kid destop AND IT NOT WORKING NO MORE HOW TO FIX THE PROBLEM
1) Make sure the tablet is NOT connected to the charger2) Power off the tablet.3) Once it is off, hold down the HOME button and connect the charger whilethe button`s being held down.4) When you see the HKC logo come up, let go of the HOME button.5) Eventually, you`ll see an Android logo with a red exclamation mark. Ifyou don`t, repeat step 3-5.6) If you do see the Android logo, hold down the POWER and HOME at the sametime for one second and just let go of the HOME which should bring upa"Recovery mode" menu with blue letters. Make sure you let go of the POWERbutton as soon as you see the menu pop up, otherwise your tablet will justshut itself again.7) Navigate to "wipe data/factory reset" using the HOME button and selectwith the POWER button.8) Navigate to "Yes - delete all user data" and select it.9) Once it`s done, you should see the menu come up again. Select"rebootsystem now
Jul 28, 2015 | Tablets & eReaders
How do i reset my hkc tablet model number p771a
This should do the trick,
1)
2) Power off the tablet by holding down the power button for about 10 seconds
3) Once it is off, hold down the HOME button and connect the charger while the button's being held down.
5) Eventually, you'll see an Android logo with a red exclamation mark. If you don't, repeat step 3-5.
6) If you do see the Android logo, hold down the POWER and HOME at the same time for one second and just let go of the HOME which should bring up a "Recovery mode" menu with blue letters. Make sure you let go of the POWER button as soon as you see the menu pop up, otherwise your tablet will just shut itself again.
7) Navigate to "wipe data/factory reset" using the HOME button and select with the POWER button.
9) Once it's done, you should see the menu come up again. Navigate to "Wipe Cache" and press the POWER button
10) It should take you back to the recovery menu. Simply press the POWER button while highlighted on the "Reboot system now"
Dave
Dec 03, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Forgot password to get in tablet how do you reset it
RTM. Read the Manual. If you need a manual, google the make and model and manual and you should find a .pdf file you can download. Or go to the manufacture's website and contact them.
Nov 23, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Won't charge
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset. if this doesn't work, your charging port might be loose or damaged. if the reset doesn't work, have a technician check it.
Feb 06, 2014 | RCA CA 7" Tablet with 4GB eory 28458515
My galaxy tablet will not turn on and or charge
hold the power button down for 10-15 seconds to force a power off. When turning back on, hold the power button down until you either feel it vibrate or something comes up on the screen.
Jan 13, 2014 | Samsung 7 in. Galaxy Tab 3, 8GB...
How to reset hkc tablet p886a
ALL CREDIT OF THIS GOES TO HKC...
this 100% works to factory reset if you are locked out of a hkc p886a tablet...
1)
Dec 28, 2013 | Tablets & eReaders
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Tablets & eReaders Logo
248 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
